Question about HP iPAQ HX2110 Pocket PC
HELP!!! Last nightI was using my hp ipaq hx2110 and out of no where the touch screen stop working. I put it on the cradle, thinking that it just needed to be charged and I am only getting a steady orange light. What happened? Does it need a new battery? Jenie
I think the battery may be fully dead, test it with a meter, and if it wont charge through the device, take it out, find a charger with a similar output and jam the wires into the correct terminals on the battery (+to+) it'll get red hot but you need only do it once. (I've done it to my psp battery and it worked fine) careful though, don't leave it on overnight or unattended.
Posted on Dec 21, 2008
Tried to update the rom of my ipaq h1940 with the sp26261 update pack. plugged it into the cradle, started the update manager (connection via windows device center on windows 7/64 bit). the update manager...
bad Idea ROM updates.
best is to never do it unless sure it cures a problem that you need fixed.
doing Rom up dates are very risky,
1: battery must be good. and being charged so that the process can not be interrupted.
2: you used XP PC of some kind to program that IPAQ rom?>
that be last choice, of all. after all most XP computers are infected with virus and malware, and is a virus magnet and not support now for 3 long years, (means its worse every day)
why even use any IPAQ,
why not just buy some used Android phone and move on, move up.
its dead product now.
IPAQ is like Elvis, he left the building.. LOL
if really motivated to make any think this old here why not ask
the real form.
Your only recourse now, it repeat the flash over and over
praying it works (with full charged and fully good batterY)
https://h30434.www3.hp.com/
May 15, 2017 | HP iPAQ H1940 Pocket PC
I have an HP rz1710 pocket pc. Can't seem to get battery fully charged. It gotten worse over time. After charging overnight or all day, it still shows low battery, then displays the hp IPAQ screen with...
If the unit will work while in the charger, it is most likely the battery has reached the end of its useful life. If this is the original battery, you are quite fortunate it has lasted this long and have taken good care of it because these batteries seldom last more than a two or three years before needing replacement.
Jan 02, 2011 | HP iPAQ RZ1710 Pocket PC
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
Touchscreen problems (HP RX or HX series)
If I understand correctly your problem, the touch screen of your PDA is not working.
Well, this is a common IPAQ failure. When happens, the only options to repair it are:
1. Soft reset of the PDA. If still does not work, then go to next step.
2. Replace the top digitizer glass.
It requires a very skillful person to do it. If you have not experience with fixing electronic devices, then I do suggest you to send it to repair.
Besides that is necessary to open it, you will require a soldering iron, and desolder the digitizer part and remove it from the LCD screen, which if is not done properly with the right tools, it's easy to damage the LCD screen assembly.
Also, if it's not opened right, is possible to damage permanently the mainboard if is bent or warped.
Also, even though there are a lot of cheap digitizer replacement parts on-line (mainly from China), they have a compatibility issue that prevents to use them in the RX3715 (or RX3115) PDAs.
I have nothing against Chinese manufactured parts, but after buy around 10 digitizers in the last couple of years for different Ipaq PDAs, I found out that only 3 worked fine, so I know what I am talking about.
Best regards,
May 25, 2009 | HP iPAQ HX2110 Pocket PC
Ipaq h5455 wont stop wibrating and i cant reset it
try a hard reset - it will restore to the original state. it removes all files and programs in the memory files in a storage card wont be affected.
Just hold down the calendar and today buttons, these are the two outer buttons on the lower left and lower right, then using a stylus press and hold for at least ten seconds the soft reset button this is located on the lower right edge of the unit. The screen should reset and the iPAQ will boot up again.
Mar 21, 2008 | HP iPAQ H5455 Pocket PC
Ipaq hx4700 dead :(
I would try a hard reset before you resign yourself to HP repair.
Sep 14, 2005 | HP iPAQ HX4700 Pocket PC
HP HX2110 wireless connection
nstall new ROM from this page ==== http://h18007.www1.hp.com/support/files/HandheldiPAQ/us/download/22776.htm l and all will be OK !!!
Sep 11, 2005 | HP iPAQ HX2110 Pocket PC
Reinstallation of app onto iPAQ upon hard reset
In activesync under Tools/Add REmove programs you can check the box and click "ok" that will install the program. For the most part it's best to do it one program at a time. Obviously your PDA should be cradled or this. Most programs will re-install fine this way. Some programs though do require you to re-install from the installtion program directly since active sync doesn't pick up some important parts of the program. The two programs I have that require the special install are: CLC Journal since it has an outlook component and sets up a sync for the Outlook Journal. The Stowaway Keyboard driver since it had to ask me what language (the new driver doesn't do this...) The other 30 odd programs I have install straight from active sync.
My H5450 won't charge!
When you charge up your iPaq, do you use the cradle, or do you use the AC-adapter with the little iPaq power converter that came with the iPaq? Try both, and see if it charges up your pda. Try and borrow an iPaq car-charger and see if it charges up that way (the ones that do not need the iPaq power converter). If you are lucky enough to power up the iPaq even for 2 minutes, enable USB fast charging in the SETTING -> BATTERY. Your USB-data-cable or cradle will then be able to charge it up that way...
Sep 08, 2005 | HP iPAQ H5450 Pocket PC
HP iPAQ HX2110 Pocket PC Logo
184 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
