Question about Lightning Audio LA1.300.2 Car Audio Amplifier
I WAS WONDERING IF YOU COULD HOOK UP THIS AMP WITH A HOUSE STERIO?
Sorry, its not feasible, your home stereo and speakers are on AC power while your car amp runs off of DC power.
Posted on Aug 20, 2010
Fuse keeps blowing to my dash guages in my 95 gmc sierra why?
have you recently installed a new radio ? I have knowen people to install radiosincorectly the dim wire behind the radio shows as a earth. however when you turn headlights on this becomes a positive. if you have wired this wire to your sterio this is whyyour dash lights & internal cab light etc keep blowing.. if your wondering why sterio still works is because its earthed through the aerial or mounting bolts.
Jan 05, 2013 | 1995 Chevrolet Silverado 2500
I have a 1000 watt sony explode mx-2165gtx and i have 2 12inch rockferd subs all hooked up in my truck. i turn on the sterio and turn it up just a little bit and it goes into protect mode i cant figure out...
Sounds like you're overloading the amp. Which rockford subs are they exactly? I can find the specs and see if theyre just too much for the amp or you just have to hook em up to the amp different so the amp wont go into protect mode
May 22, 2011 | Sony XM-2165GTX Car Audio Amplifier
Is it possible to hook the infinity bu-1 subwoofer to a home theater system where the subwoofer output is straight power say it"s like 25 watts coming out of that one channel and before the original...
In general higher speaker impedance is safer than lower impedance for the amp. Don't expect anything impressive re: audio output from a passive (unpowered) sub if your HTS says it pushes only 25 watts. Without frequency bandwidth and distortion noted the spec is virtually useless as a comparison.
The BU-1 is a powered sub that accepts either RCA Line Level or HIGH LEVEL amplifier power. If you use the latter, impedance is a non-issue because the input feeds the BU-1's internal amp, not the speaker directly. You should be okay.
Perhaps if we knew some specifics about the HTS we could do more than guess.
Jul 21, 2010 | Infinity BU-1 Speaker
Ow do i hook it up to my home sterio system?
Not really possible, as a car amp requires a remote signal (usually a 'pulse' of 5 to 6 volts), to turn on.
Maybe you could wire up a small homemade battery/switch box to the amp to pride the switch on signal?
Apr 12, 2009 | Lightning Audio B4.250.2 Car Amp
Can I hook up regular sterio speakers to RCA 52 digital HD TV
yes the itc has the option to hook external audo amp to the tv..
Apr 05, 2009 | RCA R52WH76 Television
I cannot connect my amp to my pc
Make two audio cables L+R hook up the cable from your Audio AMPLIFIER, lift and right if your amp is sterio, connect the other end of cable with stereo jack to your PC audio output,and play it,
Thanks & enjoy,
Jack
Jul 20, 2008 | Packard Bell Computers & Internet
Wires
red= accessories power on
yellow= power always on memmory
black= ground
blue white= amp switch this goes to amp
blue= power antenna
the other wires are speaker wires top is for the fronts
the bottom set is for the back speakers this is simple
suggestion if you dont know the wire hook up i suggest taken the wires and sterio to certified car sterio installer pay 5 bucks and have them splice the wires together for you so you dont screw up your vehicle wireing or your sterio this is crucial
Jul 07, 2008 | Clarion DXZ365MP CD Player
Got a deck...need to install myself
the best way is to buy a wire harness tomatch your cars then all you do is match the colours from the wire harness provided and the one for your car but if you do the wir cutting method then
Yellow is your constant wire
Red is your accessory wire
Bllack is ground after that there will be a orange wir e that is optional hook up to run the sterio with the dash dimmer 2-3 blue wires which you can use for AMP remote wire or elctronic Antena
then there are the White and white with black stripe
Green and green with black strip
Purple " "
Grey " "
are your 2 front and 2 rear speakers
which go where i always for get but when your installing the sterio you can set the sterio to run frount let and then hook the wiers for that speaker up when you fin the right one
Feb 22, 2008 | Audiovox MVP300C Complete Mobile Video...
Running amp in house
its very tricky to use a car amp in house, your going to need a power converter and deck for the house, plus car audio is not made for home, the sound is going to be off cause car audio plays a differ frequencys the home sterio.
Nov 12, 2007 | Kenwood KAC-X401M Car Audio Amplifier
Lightning Audio LA1.300.2 Car Audio Amplifier Logo
Top Lightning Audio Car Audio & Video Experts
80stech
Tygh Duval
Tygh Duval
Mark Skinner
Are you a Lightning Audio Car Audio and Video Expert? Answer questions, earn points and help others
