Question about Garden
Uneven cut on Toro Time cutter 42 recycler - Garden
  • 333 Answers
Check tire psi. or could b bent blade or bearing going out on blades
Posted on Aug 20, 2010
Toro 50" ss5000 time cutter with Kawasaki 22hp engine battery wont charge. Allow me to only cut about 3 times before battery is drained.
Take battery out, charge with 12v auto charger. In a couple days check voltage 12 or better
Jun 23, 2016 | Toro Garden
Uneven Cutting with my Zero Turn 50"...Possible Causes?
First is being sure all your tires have proper air pressure and you don't have a bent blade. Then while parked on flat concrete and both outside blades at 3 and 9 o'clock measure blade height far left side of deck and far right side and compare. I there is a difference the entire deck is out of level and should be adjusted. Then remove the blade drive belt from one of the pulleys so everything is slacked. Grab each blade and see if it wobbles or has excessive play and check the spindle housings for cracks or breaks. If you find a housing with wobble or play the bearings in that spindle are shot ( this is a lot harder to detect with the belt tension on the pulleys) and should be replaced. If you find a broke or cracked housing the housing will need to be replaced. Either one of these situations may not be obvious with the mower at rest but the blade will wobble at speed causing uneven cuts.
Aug 25, 2014 | Garden
Toro 50" time cutter when engaging blade loud
I would remove the deck and belt, then spin each blade to isolate the loud noise. Also, make sure the blades are not bent hitting the deck. I always balance my blades after sharpening as well. By isolating the bearings spinning them one at a time, this will tell you where your problem lies. Hope this helps!
Aug 10, 2013 | Garden
I only have control of left side of my time cutter
You might want to post this question in the lawnmower section so that the proper expert sees it.
Sep 04, 2012 | Toro Mowers - Time Cutter SS4235 42""...
Lawn mower repair
You might want to post this in the lawnmower section so the proper experts will see it.
Sep 03, 2012 | Toro Mowers - Time Cutter SS4235 42""...
Cant turn toro time cutter to the right
Sep 02, 2012 | Toro Mowers - Time Cutter SS4235 42""...
Uneven cutting
Make sure the wheel adjustment is the same at each wheel. Also checl that blade is secure.
Apr 07, 2010 | Toro Lawn Mower With Toro Power Tools
Uneven cutting with the center blade
Bent or dull blade.
Have it checked, or replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 01, 2009 | Toro Lawn Mower With Toro Power Tools
Dual blade mower leaves uncut strips between blades.
Had same uneven mowing problem with new Toro Z4200 XTR mower. Problem was one side of the U-shaped rear deck hanger rod had popped out of its chassis mount (did hit something with mowing deck). Removed hanger chassis mount & its bolt. Put end of U-shaped rear deck hanger rod back in the chassis mount and remounted hanger chassis mount & its bolt. Z4200 now cuts lawn evenly again.
Jan 05, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
90 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
