Question about Belkin (F5D7230-4) Router (587009)
So i recently purchased a belkin router. i set it up and my laptop can work but my ipod touch can't work. like it will connect to my server successfully but always says when i go on safari or youtube "can't connect to server" i tried changing my security mode to 64bitWEP and disable the wi-fi protected setup like one person said on one forum but if i do that, my laptop won't connect. i have windows 7 hp. and my ipod touch has software of 3.1.1. do i have to update my ipod touch to os4? anyhelp to connect my ipod and laptop so they can both work? thank you.
Use WPA/WPA2-Personal(PSK) as your security mode, then WPA-PSK for the Authentication and TKIP for Encryption Technique. You should be able to use your Ipod or any handheld devices to your router.
Posted on Aug 24, 2010
Do i have to have a router to connect to belkin wifi on my ipod touch?
Yes you need wireless router to use wifi in ipod touch or on laptop.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method.
Then click on wireless and enable it.
. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Mar 17, 2011 | Belkin (F5D7230-4) Router (587009)
I have just purchased a bELKIN SURF N300, installed the disc. nothing is signing on the internet. lap top, Ipod ..nothing works, they recognize there4 is a signal, but will not get on internet.
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Oct 18, 2010 | Belkin (F5D7230-4) Router (587009)
All green lights are on but laptop can't connect
With your laptop, you must in any event turn off, DHCP, START>>RUN>>services.msc enter... then scroll down to DHCP, and set to OFF, & Disabled. Check that hasn't somehow been re-enabled. You may just have to note down your settings and re-setup your router again... then using the connect to internet wizard, use that to connect to router, this will re-initialize everything.
Mar 01, 2010 | Belkin (F5D5231-4) Router
Ipod touch will not connect to belkin wireless router.
If your Ipod touch will not 'find' your Belkin N router - or it did and then vanished forever try this- it worked for me.
1.Turn wifi off on your computer, ensure you have the latest firmware on your router,reset the router to factory default.Do this using a wired connection from the admin page.
2. Change the SSID name from what it was previously say from Belkin xyz to my router.
3. Power down the router wait about 30 seconds then power it back up.
4. As you reset to factory setting you will need to put in your internet access info again - do this from the admin page. Also set up your security at the same time.
5. Restart the router from the admin page.
6. Unplug wired connection start wifi and connect to your computer -make sure that you have full internet access from you computer - dont forget you need to connect to the newly renamed router.
7. Take ipod and make sure wifi is off.
8. Clear network settings.
9.Turn wifi on and it should find your newly renaned router - join and enter your pass key.
Why it does it I have no idea neither do Belkin or Apple but it worked for me - a trial and error solution !
Good luck
Mel
Jan 25, 2010 | Belkin (F5D7230-4) Router (587009)
Can't get IPOD touch to connect to internet but laptop does
Susan
did you solve our Ipod problem, I have the same one,
any assistance would be appreciated
thx... Dave
dmc142@yahoo.com
Apr 23, 2009 | Belkin Computers & Internet
Unable to use other wireless devices with belkin f5d7630 router
Make sure that the wireless devices which you want to connect has the faciltity of accepting the security passwords of the router
Dec 29, 2008 | Belkin (F5D7230-4) Router (587009)
Having Trouble Connecting iPod Touch to Airtunes Network
try setting it up on your iPod Manuel instead of selecting the router from your iPods list hit the other box the enter your routers name encryption type and your password and see if that works hope this helps
Dec 22, 2008 | Apple iPod touch
I just bought a belkin g router so i could get wifi on my ipod touch. my ipod says its connected with the network but the internet wont work on my ipod.
Do you have a modem?Did you subscribe with an internet service provider? If no then you need to subscribe to an ISP because the router alone will not give you internet. If yes, you have an ISP, then tryTry to isolate the problem by using a wireless laptop, if you can connect wirelessly on your laptop and go online then there is a setting to be check on your IPOD,. If you are not online with the laptop you have to make sure the router is configured correctly or check if you can go online directly to the modem.
Jul 24, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin can't work it out!
If u r wi-fi router uses encryption u have to put it in u r connection wizard and trying putting DNS servers of u r service providers.
Oct 24, 2007 | Belkin (F5D7231-4) Wireless Router
Belkin (F5D7230-4) Router (587009) Logo
79 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
