Question about Refrigerators
My Hotpoint refrigerator makes a loud clunking noise when it turns itself off.
  • turtleluvr2 May 03, 2008
    Do I need to buy a new refrigerator or can I replace the compressor? It cools and freezes very well. It was built in 2001.
    Genius:
  • 1,073 Answers
It has a brolen spring in the compressor it may run for several more years if you can put up with the clank
Posted on May 03, 2008
Why does my whirlpool refrigerator makes a very loud clunk noise when it turns off
Try looking for any pipes that are rattling against the cabinet , if not, I'm afraid compressor problem.
May 02, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hotpoint fridge makes clunk-clunk-clunk noise when it shuts off
You need a new compressor. Probably time for a new frig.
Nov 18, 2011 | Hotpoint Refrigerators
The refrigerator makes a loud noise about every two hours. What is wrong and how can I fix it?
Here is a tip that I wrote about the clunking or thumping in refrigerators...
Refrigerator Clunking in back
heatman101
Mar 10, 2011 | GE Refrigerators
There is a loud clonking noise several times a day. What is this?
heatman101
Feb 13, 2011 | Hotpoint FFU00 Side by Side Refrigerator
"clunking" noise when it turns itself off
the compressor mounts are bad . or the internal insulators in the compressor are bad . . is sounds like the internal mounts . at 9 yrs . . mm hope this helped . ,mm
Feb 03, 2010 | Refrigerators
My Kenmore refrigerator is making a loud noise when running and when it shuts off it makes a loud clunking noise. Also, it is running about every 10 minutes. The refrigerator is 7 years old.
it sounds like the compressor insides are loose and you will be needing a new compressor, but just check and make sure the rubber mounting feet on the outer compressor base where its mounted to the refrigerator base are all tight and the rubber shocks are all good
Nov 17, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Makes a loud clunk every now and again. It
That's usually mounts inside the compressor. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Sep 04, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerator makes fairly loud noises of a clunking kind but runs and stays cold.
Clunking noises usually comes from the rapid stop of the compressor. It will not hurt a thing. The rubber grommets which the compressor sit on for cushioning, have most likely hardened and are transferring the noise to the frame or casing. The compressor runs at 3600 rpm's and when you tell it to stop on a dime, it can't. The result is a couple of clunks or so. Also check the drip pan for improper positioning. I have seen them make noise also.
May 04, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Loud clunking noise underneath fridge
its sounds like a spring is broken inside your compressor this you cannot repair you need a commpressor replacement or you can check if your fridge is levell sometimes by levelling the fridge it may reduce the sound thans from gilles
Dec 10, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Refrigerators Logo
236 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
