Question about RCA TruFlat 27F520T 27" TV
How do you change it to watch a dvd if you dont have the remote? I need to go through the menu on the tv but dont know how.
  • 77 Answers
The only way is if you have a input button or a TV/Video button on the unit itself, if not then you will need to get a unaversal remote.
Posted on Aug 20, 2010
What button gets rid of subtitles that have just appeared on my tv. I must have pressed a button to start them but i dont know which one?
You are referring to closed captioning (CC) which is enabled/disabled by a button on the remote or by selection/cancellation during initial set up.
Oct 07, 2016 | Samsung Televison & Video
While watching a dvd on the Q2035a I was using a seperate dvd player and I use a universal remote for both the dvd player and Q2035a. I began to adjust settings for the dvd player using the univ. remote....
Hello, It sounds like when you pressed the remote you inadvertently changed the scan on the ctv. This can cause the ctv ( colour tv ) to change from say ntsc to pal or similar. Even a reset button wouldnt help as it sounds like it is within the setup menu. You could try, as I have done this myself with a similar problem, disconnecting your dvd and putting it aside. Then, pressing the remote when in tv mode and watch for any change in screen flicker etc. If you have the original remote for ctv use that. If as you say, the tv goes to standby mode, you may have damaged the power supply, as the power supply will shut down to standby at any sign of a short.
Mar 23, 2011 | Televison & Video
Need to program JVC DVD player with RCA system
Go to http://remotefinder.rca.com/default.aspx?site=RCA follow instructions choose remote type you have then type of device u want 2 program remote for and then choose brand of that device and try the codes; simple
Dec 04, 2009 | RCA RCU300WBL Remote Control
I have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Apr 13, 2009 | RCA DRC8320 DVD Recorder/VCR
RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Feb 08, 2008 | RCA RCR311B Remote Control
Sanyo TV stuck on video channel
sanyo ds35590 no remote, tried universial remote still cannot select menu on uvm. What remote do I need? Or can I get into the menu without remote. I am trying to watch a dvd.
Jan 17, 2008 | Televison & Video
Input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
Jan 05, 2008 | Sanyo DS24205 24" TV
DS24205 TV INPUT PROBLEM
if you have a sky remote or know someone who does you could try programming it by using one of these codes, try them all one at a time
Sanyo 0159, 236, 073, 100, 064, 174, 185, 367, 039, 245, 246, 398, 241, 572, 583, 037, 132, 182, 244, 191
TOSHIBA 35 TV 35A44
don`t know if this will work for yours but I have heard of menu coming up all by itself randomly and the fix was to remove the batteries from the cable boxes remote and the tv`s remote, partially stuck on buttons were the cause, replaced the remote end of problem, hope this helps on yours.
Nov 29, 2007 | Toshiba 35A44 35" TV
Emerson Spongbob tv broken remote...cant change input?
Then the only way to reach your tv is through coaxial antenna port. So you can buy an rf modulator ( very cheap) and connect your red yellow and white cables (rca cables from a dvd, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me.
Apr 17, 2007 | Emerson SpongeBob SquarePants TV
RCA TruFlat  27F520T 27" TV Logo
69 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
