Question about Sony Playstation 3 (PS3) Console
My ps3 will power on and i can feel that the disc is turning but my tv reads no signal. it gets overheated quickly and the 4 red lights on the remote are constantly flashing....what do i do?
  • 1,472 Answers
Casey_lannin
It sounds like you are having a video problem. So the first question I have are you using the HDMI connection or are you using the AV cable.
If you are using the HDMI connection I would connect the AV connection to see if this is just an issue with your HDMI port.
Next I would reset the video setting of the PS3 by holding down the power button until it beeps at you twice. Then reconnect the HDMI cable. If the connection still does not work I would try another cable and another TV or monitor. If the HDMI still does not work but the AV do then you have blown out the HDMI port on your PS3.
Let me know how things go
Issken
http://www.fixya.com/users/issken
Posted on Aug 20, 2010
Hi I have a vizio tv control with the key board and it all just stopped working so I thought it was the batteries changed them still not working ????? Help Please
Test ur tv remote control first see,if it is working,malfuctions or completely dead?U have a Digital Camer wright?Yes.Digital Camera can read Infer Red signal Output by the tv remote.Yes?Turn the Digital Camera on and take the tv remote point it at the Digital camer and pushes all the remote buttons the Infer Red signal will read all buttons Infer Red signal flashes u can see on Digital Camer viewing screen.Pushes all remote buttons see flashes of white lights.Mean the tv remote control it it good or not.Take some cottons ball soak it with some rubbing alchachol clean the tv Infered Red sensor on the tv frame near the power LED incation light.Might be dirty,Still not reading the Infer Red signal.If 100% it is the tv remote control is the cause,it CPU is dead.Try website like Remotes.com to buy another the tv original remote.
Jul 29, 2011 | Vizio VO47L 47 in. LCD TV
I bought an xbox360 and i get the RED lights flashing on it and as soon as you turn it on the lights cme on. so it does'ent work what should i do?
Nearly all of the lights are caused by overheating - you may have the 3 red lights which is caused by the GPU and the CPU overheating or 2 red lights where the console will feel hot.
Then you can get freeze ups and disc reading problems as well.
How many red lights are showing on the power button?
You can fix all of these errors from home using a good repair guide or send it in.
Apr 27, 2011 | Microsoft Xbox 360 Console
When my son plays his PS3 after a while the screen goes blank and the message: check signal cable appears. His PS3 is connected to tv with an HDMi cable and the cable that fits into the AV with the three...
Try these steps:
1. Before resetting cables, make sure PS3 is turned off using the main power switch on the back.
2. Unplug the power cord of the PS3 and TV from the wall socket.
3. Connect HDMI cable to HDMI Out on back of PS3
4. Connect HDMI cable to HDMI Input port of the TV
5. Plug the PS3 and TV back in to the wall socket
6. Turn the main power switch on the back of the PS3 on.
7. While the PS3 in standby mode(red light on) hold down the on/off button on front of system until the system goes into standby mode again. (So the light cycle would go red light-green light-then back to red. This will ensure you held down long enough to reset video output settings.
8. Turn on the PS3 and once the system finishes powering up, the video output settings will automatically reset.
Mar 02, 2011 | Sony Playstation 3 (PS3) Console
The PS3 works fine but freezes in career mode of MLB 10 The Show. Is this also an over heating issue?
It doesn't sound like an overheating issue, more of either a disc read issue or firmware issue.
Please try my following tip for re-installing the firmware. If this does not fix it then try cleaning the laser lens.
Failing that, if it is an overheating problem usually it will tell you with an onscreen prompt or shut down with a flashing yellow light
Step 1.
Turn your Playstation 3 off into standby mode (red light on)
Step 2.
Press and hold the power button. The Playstation 3 will beep when you first press it, then beep again 5 seconds later and then beep once more and turn off back into standby mode (red light on). You must now release the power button.
Step 3.
Press and hold the power again. The Playstation 3 will beep when you first press it, beep again 5 seconds later then there will be 2 quick beeps together. When you hear these 2 quick beeps release the power button.
Step 4.
Your Playstation 3 will now start up with a screen asking you to connect a controller via USB. Connect your controller and then press the PS button.
Step 5.
A menu will now be displayed on screen. Select option 3 "Restore File System". This will then ask you to confirm that you wish to go ahead with the system restore. Accept whatever the Playstation 3 says
Hopefully this will cure the problem on its own.
Hope this helps
Jan 29, 2011 | Sony Playstation 3 (PS3) Console
It wont read any discs?
If your PS3 won't read your disc, then try the tips below. They may help you fix your PS3.
Firstly check the actual disc that you are trying to play for scratches, smudges and dirt. If it is smudged or dirty clean it (instructions are in the PS3 user manual). In any case, try another disc in the PS3 and see if that works. If it does then most likely the cause of your problem is the disc. It may be too scratched up, from the wrong region - [many discs are locked to a certain region and will not play on a system in another region], etc.
If your PS3 will not read any disc, try turning it off and on again - Place it in standby mode (when it shows the red light) and flip the switch on the back, or if it is a slim place it in standby mode and unplug it. Wait a couple minutes and turn it back on again.
Unfortunately if that doesn't work try resetting it may fix the PS3. Press and hold the power button for 5 seconds until you hear 2 beeps. This will reset the PS3's settings.
If your PS3 will not read disc still then the lens may be dirty. You can fix this by getting a lens cleaner. Most electronic stores sell them. Follow the instructions on the lens cleaner.
However if your PS3 will not read disc, then you have a more major problem. In order to fix your PS3 you will either have to send your PS3 to Sony for repairs, or get a good PS3 repair guide and fix it yourself.
If your PS3 is still under warranty, then I would recommend that you send it to Sony for repairs since you will void your warranty if you open your PS3.
However if your warranty has expired, the fastest and cheapest option to get your PS3 working again is to get a good, step-by-step PS3 repair guide and repair it yourself. You see, if you were to send it to Sony, they will charge you around $150 and there will be a 4-6 week wait to get your PS3 back, or you will get a refurbished unit. Good repair guides costs downwards of $75 and offer 1 hour fixes so that you can get back to using your PS3 as quickly as possible.
My playstation 3 wont turn on. The console beeps like normal, then the light quickly turns from red to yellow then immediately back to a blinking red. What does this mean?
If ur ps3 console wont start up....then the things to check are>>> 1.check ur power cable 2.check whether u have inserted the disc properly and precisely. 3.check the insertion of memory card... 4.check the video port.......
check your console and making sure those fans are not blocked off. If you notice a lot of dust on the console, clean it off right away. Once you fix the blinking red light of your ps3 and your console is working again, you will want to keep the vents clean and unobstructed.find the hard drive on the side of your console and remove it. Wait a few seconds and replace it. In some cases this may fix PS3 red light. If you still see the blinking red light, there is a chance you have more substantial damage inside your unit.Then unplug the console from the wall for about half an hour and then plug it back in. This doesn't always work, but some people have had success with problems other than overheating.
click here to download ps3 repair guide
Dec 26, 2010 | Sony Playstation 3 (PS3) Console
While playing a game console turned off and game disc is stucked inside, turn power on and light turns green for couple seconds then flashes red and turns back off, no chance to eject game disc.
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly over heated. This may be caused by poor ventilation or the vents may be blocked.
The blinking red light is infact a general hardware failure message. In this particular case, his hardware failure is with the blu-ray drive, that's why the system does not shut down until the drive is accessed. if the system is overheating, it will tell you so in the top right hand corner. It will say the system has overheated and is shutting down to avoid further damage.
Provide a proper vent for the system...
Hope this will help...
May 28, 2010 | Sony Playstation 3 (PS3) Console
Console will not accept any discs. triple beeps and red light starts blinking
Hello new club member. thank you for not willingly joining the "da-gumit my ps3 is flippin broken club" please read on for details.
You have the dreadful blinking red light of death. Long story short the system is broken due to overheating and heat damage to the motherboard and you have a few options:
1. send the system to sony and receive a refurbished system for $150.
2.find a local to do it for much cheaper
3.watch vids on the web (youtube.com) and fix it yourself but it is fairly difficult
4.buy a new ps3.
I hope I have helped and please feel free to ask me any questions and let me know how it goes.
Jan 04, 2010 | Sony Playstation 3 (PS3) Console
My play station 3 kept freezing up then went off all together will not read disc
do you get the red flashing light? or the yellow.
feel the back of the ps3 , is it overheated?
let it cool down for an hour, is it still got warrenty? oif not i would suggest opening up and giving it a good clean. and maybe cleaning the therman payste
Nov 09, 2009 | Sony Playstation 3 (PS3) Console
No signal to the tv
You have to take the system apart yourself and take it out or send it in to Sony
Jul 23, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
18 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
