How to set up remote to turn tv on and off - Televison & Video
  • 550 Answers
This is a generic answer that applies to many multi unit remotes
Many remotes have to be trained. the user manual contains a list of code series that identify to the remote what equipment the remote is intended to control. changing batteries may erase the prom that this information is recorded in.
From either the printed manual or by looking up the manufacturers web site from descriptive labels on or in the remote, you can determine the (usually) 3 digit code for your tv dvd video audio units and the button that begins programming mode sop that you can press the unit button, enter the code, press the button to confirm. and be done
My specific remote requires
Hold [menu] untill the red lamp flashes 3 times
press [dvd]
enter the code on the number pad
press [dvd]
press [tv]
press [tv]
press [vcr]
press [vcr]
press [audio]
press [audio]
press [aux]
press [aux]
press [menu]
thankfully the remote recharges on the dvd player, and I only did that once
Posted on May 03, 2008
I need step by step instructions to program the codes into my One For All universal remote URC-4220 to my JVC tv.
The code for a JVC TV is 0053 (non-combination TV). To program the remote, turn on the tv manually. Then press the TV button once. Then press and hold Set until the LED blinks twice. Then release Set. Aim the remote at the TV and enter the four digit code. The LED should blink twice again. Press the power button on the remote. The TV should turn off. Turn it back on and check if the remote does the other functions that it should for the TV.
There is a manual code search option. Press TV once, then press and hold Set until the LED blinks twice. Release Set and enter 9 - 9 - 1 . Then aim the remote at the TV and alternate between pressing Power and TV. When the TV turns off, press Set to save the code. Turn the TV back on and check if the remote performs other functions. If not, repeat the above steps until another code turns off the TV.
The manuals for All-for-One Remotes are available here: http://www.oneforall.com/support/manual . Choose universal remote control in the top drop down and then the URC-4220 in the second.
Please note that universal remotes only have codes for devices released 6 months of more before the remote was programmed. If your TV is newer than your TV, then you may need a newer remote.
I hope this helps.
Feb 12, 2011 | One For All URC4220 Remote Control
Urc-3021Boo one for all set up and codes for a sanyo tv
To control a Sanyo TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
2) On the remote, press the TV key once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the code 0154.
The LED will blink twice.
If it does not blink twice, go back to step 2 and try the same code again.
5) Aim the remote at the TV and press POWER.
The device should turn off.
If it does not turn off, try the auto-search function.
To search for a code for your TV:
  1. On the remote control, press TV once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Hope that helps.
Oct 17, 2009 | One For All URC-3021 Remote Control
IR Remote control 103781
OK first and foremost not all tvs are supported by Dish remotes. This is especially true of combo units bbut here is the easiest way to program the remote if the tv is supported:
Press and hold the clear tv button on the top of the remote until all buttons across the top light up.
Now press the smallred tv button and release it.
The top tv button should be lit constantly now.
Now press the arrow up key slowly until the set turns off.
Once it has press the arrow down button once and then the arrow up button to see if tv turns on.
If it does press the pound key and release.
The topmost tv buttton will flash three times.
You are now ready to press the SAT key on the top of the remote and watch tv as usual controllling volume etc with the remote.
If the set turns off but you can not get it to turn back on turn the set on manually and start the process again- it will not go back through the codes you already had tried.
If you notice the tv button flashing rapidly it means you are at the last code and need to go back the other direction or that there is no code for your set.
If the set turns off but will not turn back on then you have a partial code which will not perform properly. Thanks for using Fix Ya.
Mar 12, 2009 | DISH Network IR Remote Control
Universal remote px-rc1
Hi! This worked for me! I'm Leyz/leheart from the Philippines. I'm typing in CDRKing or CD-R King or CDR King Universal Remote Control PX-RC1 so that these keywords will show up if someone's looking for it too.
Mcneileric is right!
Real TV should be on! On the remote, press and hold the SET and DEVICE TYPE (in my case TV) at the same time. (Note: SET button is not any other button but the one with the word SET on it. You might have been searching on youtube and found that they are pressing other SET buttons but do press the SET button with the SET word). Then press SET again. Press the POWER button then + CHANNEL button then POWER button then +CHANNEL button then POWER button then +CHANNEL. (This process is so the remote could look for the code while you are pressing the +CHANNEL and the POWER is to see if the tv will turn off/respond to the remote). Do this repeatedly until the time that when you press the POWER button, the real TV turns off which means the real TV now responds. You will be shocked so DON'T press the +CHANNEL button anymore as this will instruct the device to look for another code. Instead, press the DEVICE TYPE button (TV for my case) to finish the set up.
NOW YOU CAN USE the REMOTE! Press the POWER button and this will turn on the TV!
Again...
TV onPress and hold SET button (yes, the button with the word SET) and DEVICE type button (TV/VCR,etc) at the same time for about 3 secondsPress SET againPress Power to check if the TV turns off^^If nothing happens, press +CHANNEL to search for codePress Power again to check if TV turns off^^If nothing happens, repeat the step between ^^ and ^^If the TV now turns off after pressing the POWER button, press the DEVICE type button to finish the setup.
Mcneileric, THANK YOU!!!!
Aug 22, 2008 | Radio Shack 15-2142 Remote Control
Child lock will not allow my tv to turn on
i was programming my television by hand because i do not have a remote to my television and i accidentally set the child lock and now my tv will not turn on what can i do to fix my tvtv is on standby, standby light is on. can turn tv on with programable remote after pressing on button several times to set code on remote. press any function button and screen says child lock is on. can't get anywhere pressing any buttons, turn tv off with on/off button and tv goes back to stand by. don't have magnavox remote any ideas?
Jul 19, 2008 | Philips Magnavox 20MS3442 20" TV
Remote not working, TV won't turn on.
Some TV sets have a vacation switch in the rear of the set. This is to allow it to be in standby but not turn on. Check for this feature if your set has it, and it is turned on.
If the set has failed:
It sounds like something in the TV failed. Common failures in these sets are the power supply and scan circuits.
Jerry G.
Apr 13, 2008 | Televison & Video
Progaming the remote
1. Turn on the device you want to set-up (ie: TV, DVD, etc).
2. On the remote control, press the device key for the device to be set-
up. For example, to set-up a TV, press the TV key; to set-up a DVD,
press the DVD key, etc.
3. Press the "SET" key and hold until the small light ("LED") on the
remote control blinks twice, then release.
4. Enter the Code for your device. If you've done it correctly, the "LED"
light will blink twice. (Note: 'Codes' are listed in the instruction booklet).
5. Press the "POWER" key and the device will turn off. codes follow
Mar 02, 2008 | One For All URC4220 Remote Control
Silly remote
press and hold "set" then "TV" (or whatever device) then press "set" again. Point the remote at the device and press repeadly the power button until the device turns on. Press "TV" again to complete the programming procedure.
Done.!
Jan 14, 2008 | Televison & Video
My tv will not turn on.
First of all, forget about the remote and see if the TV functions normally using the buttons on the front of the set itself. If the TV will not power on with the power button on the set itself, then something is wrong inside the TV. If the set works fine from the front buttons but no longer responds to that remote, then the remote has either gone bad or was accidently set to a different brand. In this case, look for the original book that came with the remote (or TV if it is the original remote) and follow the instructions for setting the remote back to Zenith. Try that and post your results here.
Aug 09, 2007 | Zenith C27A24T 27" TV
Televison & Video Logo
242 people viewed this question
Top Televison & Video Experts
