Question about Carrier 38CKC024 Air Conditioner
Our carrier air conditioner failed to cool down the house last night. changed the filter and still struggling to cool house down.
  • 107 Answers
Is it cooling some at night but none during the day basically ? Outside unit clean also ? Good airflow ? if yes on all of these feel the copper pipes that go inside the house from the outside and once a/c has been on for a few minutes the large line should be very cool or cold to where it would condensate.. Sometimes it may take up to 15 minutes..
Posted on Aug 21, 2010
  • jrosasports Aug 21, 2010
    Copper pipes are still very hot on the outside of the house. Doesn't appear that the fan on the outside unit turned on but not sure if it is always supposed to be going when the unit is on (ran it for about 20 minutes). The air flow under the filter appears okay but not very cold. It's a Carrier brand and the led status light is on, but it's not submitting a code. Read where you can jumper the wires to reset it to get the code, but not comfortable messing with the wires. Could it be the outside unit? doesn't appear anything is jamming it up.
  • Patrick Worley
    Patrick Worley Aug 25, 2010
    It is the outside unit at this point. The main electrical comes to the contactor and that contactor pulls in to give the unit power. From there it would also go through a capacitor. The capacitor is a round or oval silver canister that should be flat on the top.. Is it flat or rounded ? The fan and compressor should be on all the time the unit is calling for cooling with most models.. especially the compressor.. Its either no power to outside unit, contactor or capacitor..
Carrier Air conditioners
change filter and clean outside unit with water. pull the outside fuze before cleaning.
Jul 29, 2012 | Heating & Cooling
I have a carrier air conditioner model 38CKC024340 it cool the house sometimes, then a block of ice will form on the unit outside and it stops cooling, what could be the problem
Have you changed the air filter?
The 2 main reasons for frozen units in cooling mode 1. Not enough air flow. 2. Low on refrigerant.
You can fix #1.
#2 will require a service call.
Jun 02, 2011 | Carrier 38CKC024 Air Conditioner
My AC starts fine. But the compressor will over heat and shut down in higher temperatures (high 80's lower 90's. It has run without issue on some days like yesterday with temps in the mid 80's. The...
Most likey cooling fins are plugged and also my need new compressor or low on refrigerant or refrigerant oil. Could also have plugged intake filters in the intake.
Jun 25, 2010 | Carrier 38CKC036 Air Conditioner
Carrier air conditioner isn't cooling the house. It is blowing air, but it doesn't seem to be cool air.
Check the outdoor unit to see if it is discharging hot air out of the top ofd the unit, check the insulated suction line to make sure it is cold or sweating. Try to listen to the outdoor fan and the compressor to make sure they are both operating
Jun 24, 2010 | Carrier 38CKC036 Air Conditioner
Not cooling the house.
clean or change air filter and if the filter is realy dirty you might need to clean the evap coil
Apr 07, 2010 | Carrier 38CKC036 Air Conditioner
Problem with new Carrier Infinity 96 gas furnace
carrier infinity 96 furnace went to turn down the thermostat and their was no power to it and the furnace doesnt run
Nov 14, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Comfort 13 Puron model 24ACA3 / FV4NB006 installed 3/18/08 no longer cooling. Carrier AC1-100 Thermostat checked per manual - all default settings intact. Test override did not turn unit on though....
Verify 24 volts at the low voltage transformer inside the air handler. If it is OK, jump out the red/green and yellow thermostat wires. If everything comes on, replace the thermostat.
Jun 07, 2009 | Carrier 38CKC036 Air Conditioner
I need an instruction manual
If you have a good model number for the unit in question you should be able to contact carrier themselves or google the manufacture and download it if they offer it but more than likely you will have to contact the manufacture for assistance. The number is 1-800-CARRIER
Feb 15, 2009 | Heating & Cooling
Air conditioner
Yes, first turn your thermostat to the off position. Try to reset both fuse boxes again. If the ac comes back on problem solved, if not fuses and or breakers may need to be replaced. Let me know if this helps and we can go futher into why the ac is not only reaching the temp at night. Thanks
Aug 10, 2007 | Haier Energy Star ESA3183 Air Conditioner
Carrier 38CKC024 Air Conditioner Logo
153 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
