Question about HP DeskJet F4280 All In One Printer InkJet
Ink has leaked from the cartridge into the deskjet f4280 all-in-one. It cant be a bad ink cartridge b/c it is both the color and black in that has spilled. I replaced them both 2 days ago. I have replaced my ink before so I don't believe I did it wrong. This makes me think it is the hardware. What, if anything can I do?
  • 27 Answers
The cartridge may be overfilled try to sucking ink from the cartridges and try printing again
Posted on Aug 20, 2010
Why does my HP Deskjet F4280 Show an E in the Start/Copy screen??
Regarding your recent inquiry about the HP 60 cartridge error message ("E in display window") and inability to print with your HP Deskjet F4280 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside the cartridge itself (please note that it is very rare for both ink cartridges to electrically fail at the same time). An electronic failure of the cartridge would be unrelated to the ink cartridge refill process; these same failures can (and frequently do) occur with brand new ink cartridges.* To help identify the root cause, please run the 'Tap 41' cartridge's electrical / diagnostic tests below (refer to B. and C), this will identify which ink cartridge is causing the issue:
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
As a temporary workaround, or if you are unable to determine which cartridge is causing the issue, remove one of the ink cartridges from the printer....this might place the printer into the 'single cartridge printer mode'....print jobs may then be executed from the computer (only):
An internal electrical failure of a cartridge can be confirmed by performing the following corrective/diagnostic steps:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B.Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test:
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
      1.While holding the Power button, press Cancel (X) button 4 times, then press the 'Resume' button once.
        --- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
        ---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For any additional questions please contact us directly: Inkjet411help@gmail.com
To purchase the lowest cost ink cartridges available in the USA (remanufactured in the USA) please visit: http://www.inkplicity.com/
-Thank you
Aug 14, 2014 | HP DeskJet F4280 All In One Printer InkJet
What is the cartrigenumber l used for HP deskjet F4288 all-in-one model
Found a HP Deskjet All-in-one F4280 on hp.com that uses
. HP 60 Black Ink Cartridge
. HP 60 Tri-color Ink Cartridge
Jun 28, 2012 | Office Equipment & Supplies
Will HP 60 ink cartridge work with HP Deskjet 2460? Tnx.
This is all HP recommends for the HP Deskjet 2460, so I wouldn't suggest buying anything else. First of all it might not fit and second, even if it fits, other issues may come with using those. If you can't see the list here it is:
HP 21 Black HP 21 Black Twinpack HP 21/22 Black/Color Combo HP 21/22 Quad Pack HP 22 Tri-color Twinpack HP 22 Tricolor HP 58 Photo
Jun 23, 2011 | Office Equipment & Supplies
Am trying to install HP 60 ink cartridges in my wife's F4280 printer. They don't seem to easily fit. Is there a readable graphic to assist me?
You have the wrong cartridges, that model uses the 300 or 300XL cartridge http://www.internet-ink.co.uk/hp-ink-cartridges-f4280/
http://www.amazon.co.uk/Original-300-Black-Ink-Cartridge/dp/B0019TUUJW/ref=dp_cp_ob_computers_title_0
http://www.amazon.co.uk/Original-300XL-Black-Cartridge-Capacity/dp/B0019TUUME/ref=dp_cp_ob_computers_title_1
regards
Jan 27, 2011 | HP DeskJet F4280 All In One Printer InkJet
How to change color printer hp f4280 to only print black because color cartridge is empty?
Click Start
Click Control Panel
Click Classic View
Click Printers
Right-mouse click on the icon for your HP printer.
Click Properties.
Change from "print in colour" to "print only in black".
Click OK.
Now, your printer *might* print, or it still may demand that the "empty" ink-cartridge be replaced.
Sep 24, 2010 | HP DeskJet F4280 All In One Printer InkJet
F4280 DeskJet All In One Printer InkJet: There is ink in cartridges, ink light display's em...
First make sure you are placing the right
color cartridge into the right slot.
Most Printers are touchy about the
installation of ink cartridges. If the
instructions say to press the cartridge
into the slot until you hear a loud click,
that's what they mean. If at first you
don't succeed, remove the cartridge and
reinsert it into the slot again and press
on it hard till it clicks.
Then your printer should work properly.
Hope this is of some help. Bud
May 18, 2010 | HP DeskJet F4280 All In One Printer InkJet
Error of colored and black ink
if ink cartridge already replaced, try to clean up pins for possible dust or waste ink. if ink cartridge refill you need reseter to reset counter from empty to full.
Mar 23, 2010 | HP DeskJet F4280 All In One Printer InkJet
HP DeskJet F4280 All In One Printer InkJet Logo
93 people viewed this question
Seeker5211
Seeker5211
