Question about HP OfficeJet 7410 All-In-One InkJet Printer
Replaced cartridge's. error says remove and check cartridge on right.
    President:
  • 1,961 Answers
Try to clean the contact terminal of the cartridge use a cotton swab dip in an alcohol wipe both the printer terminal and the cartridge..
Posted on Aug 20, 2010
Hp 3600 54.17 error
54.XX ERROR An error has occurred with one of the tonerlevel
sensors.
XX Description:
15 Yellow
16 Magenta
17 Cyan
18 Black
1. Make sure that connector J1020 on
the DC controller is seated correctly.
2. Replace the DC controller.
Dec 12, 2012 | HP Office Equipment & Supplies
How to remove and insert catridge on right
Switch on printer, wait up to initialize, lift cartridge access door located at right side of the printer(check snap shot)wait till cartridges stayed at right side,gently push cartridge down wards to un lock, take out cartridge, replace desired cartridge..close the door & check display for ready mode...Note: Used cartridges & refilled cartridges may give error message to replace it.. If you are replacing with new one, printer will print align page to align cartridge.. For aligning the cartridge put printed paper in face down condition in scanner & scan it.. 5_25_2012_7_00_52_pm.jpg
May 25, 2012 | HP Officejet 4355 All-In-One InkJet...
I am getting an error message remove and check right cartridge?
Replace the right cartridge with a new genuine HP cartridge.(not a re-fill)
If still does it check that the contacts are clean where the cartridge seats.(wipe with a q-tip)
Aug 31, 2010 | HP Officejet 7210 All-In-One InkJet...
Error message says "Remove and check cartridge on right" Its a new cartridge I've been using for a few weeks and it has been working fine. I have removed cartridge several times and even cleaned contacts....
The electronics on the cartridge have gone bad. Sometimes cartridges short. Take the cartridge back to where you bought it (they should give you credit for any remaining ink) and buy a new cartridge.
Aug 10, 2010 | HP Photosmart C4180 All-In-One InkJet...
ERROR signal - Remove and check cartridge on right - checking
YOUR PRINTER/SCANNER MIGTH BE UVER USED AND HAS TO REPLACE SOME PARTS
ROLLERS, GEARS, OR PUT SOME GREASE TO AVOID TOO MUCH FRICTION
Mar 18, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Remove and ck right cartridge
    Once remove both the cartridges from the all-in-one and then clean the copper contacts of the cartridges and then put only black cartridge and check for the message displayed on the all-in-one if it even reads check right cartridge then the issue is with the all-in-one hardware. If it reads insert right or color cartridge then the issue seems to be with the cartridge.
    Remove the cartridges from the all-in-one and power cycle the all-in-one and then reset.
    Now insert the cartridge and check for the result. If the issue still persists then check the expiry date on the cartridge and once replace the cartridge and check for the result.
    May 27, 2008 | HP Officejet 7210 All-In-One InkJet...
    Hp7310 printer remove and check cartridge on right error
    I know this might not sound like a good thing to do, but it fixed it for me. I licked my finger and rubbed it on the circuit board on the cartrige, then put it back in the printer. It seems to be working fine.
    Dec 28, 2007 | HP OfficeJet 7310 All-In-One InkJet...
    HP OfficeJet 7410 All-In-One InkJet Printer Logo
    107 people viewed this question
    Seeker5211
    Seeker5211
