I have a DG33SXG2 motherboard. I need a diagram to show how to connect the wires from the front of the case, (power, led, etc.) to the motherboard. thx
  • 85 Answers
You can just visit this site and solve your problem http://www.pcityourself.com/building/frontPanelConnections.php
Posted on Aug 20, 2010
How do i wire-up the: ( eg. power l.e.d., HD led, reset led ect. to the board
The various wires from the case front panel should be labeled to indicate power LED, HD LED, etc.
The motherboard front panel jumper pins should be grouped together and the pins should be labeled to indicate PWR, HD. RST etc.
You can go to the motherboard manufacture's WEB site to download a diagram of your model motherboard and it will show all the locations of the connecting pins.
Jan 30, 2011 | Chaintech MP4M266A Motherboard
How to connect led wires like HDD Led,POWER Led,POWERSW, RESETSW...........................etc
Your cases installation manual will have a pinout diagram for you to use when connecting these pins from the case to the motherboard.
This diagram is very important as the connections differ based on the model of the case itself in many cases.
If you can't find it, search the model number of your case on google and see if you can find the installation manual on the manufacturer's website.
Dec 20, 2010 | Intel Motherboard
I had a friend transfer my computer components eg. motherboard, HDD, Ram etc, from a ugly computer case to a nice looking one, she got as far as screwing in the motherboard and hooking the HDD...
Hi:
To solve your puzzle, you need to find the manual for your motherboard. If you don't have it still, almost all of them are available online at the manufacturer's support website. The manual always has the pin out diagram for the motherboard, and from there its just a matter of plugging the small connections together. Remember that connections for LED lights have polarity, meaning that they need hooked up one particular direction for the light to work, but any switch connection doesnt matter.
Hope this helps
Oct 22, 2010 | Computers & Internet
How to connect power sw and led and reset sw and hd led
You'll need to go to the Elitegroup website and download the .pdf file showing a diagram of the motherboard wiring layout and pin connections and then connect the wires from the case to the proper locations.
Oct 07, 2009 | EliteGroup 865G-M8 (V1.0) (MB865GM8)...
Need front panel connection diagram power switch lrf connectipns on 9 pin connector on motherboard
Hi u can easily solve this problem.
open your computer cover and and see the motherboard front panel connectors. a use of screw driver touch any two front panel connectors if any led or switch working this condition you can note this and connect successfully. one by one touch all penal connections and u will be solve ur problem thanks mukesh kumar
mukesh_ibm@yahoo.com
May 12, 2009 | ASUS Computers & Internet
Lost in the wiring :(
Hi bossman9628A, normally its the wire colors that messes everyone up when trying to connect the front case wires to the motherboard. The MSI RX480 Neo2-F, AKA MS-7151 MB is no different but does use a second set of pins just to help you get more confused.
Gather up all your case wires. You'll notice there is one color that is common. Chances are that color is white & is being used for the ground wire. Other colors like blue, green, red, light blue, light green & light red ECT are used for positive. The speaker uses black for ground/negative.
So looking at JFP1 at pin 1 is positive +. Pin 3, which is to the right of pin 1 is negative -.
The manual does show you which pin is negative & which is positive. Pin 1 = (HD_LED_P). The _P stands for positive.
Pin 3 = (HD_LED_N). The _N stands for negative. Do not connect the Power led at JFP2. Keep the power led connected at JFP1.
Do connect the case speaker at JFP2. Most cases do use 2-pin connectors but others use 3 & 4 pin connectors. If your case is such you can remove a wire from a connector by using a decent needle. There is a small black tab that you can pull towards your self while pulling the wire out. You can than slide the wire back into the connector where you need it. You'll know the wire is inserted correctly because you'll hear or feel it snap into the connector. If by sme chance you get a led backwards, don't freak out. The leds use 5v DC. Just shut down the system & turn that led 180deg & reconnect it.
Good luck bossman9628A!
More questions?
Mike
please vote....
Jan 02, 2009 | Matsonic MS9087C Motherboard
Connection of wiring to board
6a98a1a.jpg For the usb connectors you can follow the diagram above:
For the rest of the connectors I need to know the model number of your motherboard
Nov 23, 2008 | Computers & Internet
Front panel connectors
hi im wesley. ok the power and audio connecters is very simple if you look at the bottom right of the motherboard you will see you can plud them and it says the name of witch is the power and witch is audio and it doesnt realy make a difference witch way you put them in just as long as they are on the right pins. the usb might be a little more tricky unless it says witch connecter is the usb 1&2 then its the same as the power led but if you dont come right i will try to get a diagram for you or draw one up but it might not be as accurate tho as i do not own a asus motherboard but i will do my best.
Jul 11, 2008 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Compaq for Evo D300 Motherboard
The manual can be found here. There is a numbered diagram inside. http://www.eserviceinfo.com/downloadsm/5105/Compaq_Evo%20300-500.html Hack
Jul 09, 2007 | Compaq (281946-001) for Evo D300...
Computers & Internet Logo
945 people viewed this question
David Payne
David Payne
