Question about Mitsubishi WT-46809 46" Rear Projection Television
WT 46809 Big Screen
Recently starting with the bowing of the picture intermittent. Watching the television tonight and it suddenly went off. Now it will not power up. What's wrong?
  • Anonymous May 26, 2008
    mine is doing the same thing
  • Will Kibler
    Will Kibler May 11, 2010
    Have there been any brown outs? How old is the set?
    Sounds like the power supply.
  • 927 Answers
Good Day y'all;
When the is picture being intermittent and bowing then the most common problem is that the convergence circuit has failed or is failing. If you don't get fixed, the will go DOA soon.
Good Luck, big IRISH.
Posted on Jul 15, 2008
SOURCE:
Mitsubishi problem
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
    Colors don't line up
    One or more colors can't be adjusted when using the convergence menu.
    Screen is bowed or warped.
    No Audio / No Video
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 25, 2009 | Mitsubishi WT-46809 46" Rear Projection...
WT-46809
When you press the Volume Up/Down buttons does it show anything on the screen (like the level indicator bars...)?
Nov 07, 2007 | Mitsubishi WT-46809 46" Rear Projection...
It is starting to have a convergence problem, for a short time then go back to normal. There is a big bow in the middle of the screen.
carefully remove the back of the tv and look for the convergence panel then make a note of where the plug/socket connections go then remove
once you have done this use a good soldering iron and re-solder any bad connections on the panel
that should sort it , post back if you have any more questions.
Sep 15, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi tv model wt 46809
Good Day, sam;
Sam it depends on "smudge".
If it's an oily type; then a mild soap, like dawn, on damp, warm soft cotton type cloth may remove it.
There are products found in most large best buy, circuit stores that sell a screen cleaner. It's sold in a small spay bottle, about 2-3 ounces. Always spray onto cloth NOT screen. Always wipe/clean with up & down strokes, NOT side to side or at an angle.
If the screen is smudged after attempts of trying to 'cleanning' a scratch, then only replacing the screen will fixya problem, cost will be in the range of $100.00-$250.00.
Good Luck, hope this was helpful, big IRISH.
Jul 15, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Goofy intermitent picture (bows with wiggly fibers across screen)
Convergence amps are going bad replace these and you will fix your intermittent problem.
josh
Mar 02, 2008 | Mitsubishi WT-46809 46" Rear Projection...
No sound
have you tried dvd or other sources?
Mitsubishi WT-46809 Intermittent color problem
I have the MITSUBISHI WT-46809 46" HDTV CONVERGENCE IC PROBLEM as well. I just ordered the STK392-570 IC for 7 bucks and I am going to attempt to switch them both out (two of them). I am getting the overstated "bow tie", "RBG separation" issue that you are talking about. I am going to attempt to de-solder the intergrated chips and put new ones in. I figure it is worth the shot, insted of paying 350-650 bucks to have some **** with average skills do the same I figure it is better to have this **** with average skills do it and keep the cash. I will let you know how it goes.... DJ
Feb 24, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Mitsu. 1080 Problem -- Green squiggly lines
if no one answered then hear my thoughts.  odds are it is 2 ic's
I say that because that has been the problem with mine,
except it was the red.  it happened in 2000 when I bought the tv
and just now.  its going to cost me about 400.00 to have someone fix it.  I'm getting it fixed because it's been good to me. I watch dvd's vhs's and laser disks and feel it has plenty of life in it.
good luck
Mar 02, 2007 | Mitsubishi WT-46807 46" Rear Projection...
Picture on my WT-46809 not centered
How much did they charge you to do it? I am going to replace them myself....just wanted to see how much I will save. DJ
Dec 17, 2006 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
