Question about Maytag MER6875A Electric Kitchen Range
How do i remove the glass top from a maytag electric range?
jsrock516
  • 5911 Answers
SOURCE: Gemini Range Dual Burner
Unfortunately, you cannot repair one element of a dual burner. It all comes as one unit. When one portion of a dual or triple element goes bad, you must replace the whole element. I believe the part number is 1032746 and runs about $70. You will have to lift the glass top to access the burner elements. If you decide to pursue this on your own follow these steps: 1. Unplug range and/or turn off main breaker. 2. Open oven door to access screws under front edge of cooktop. Remove two screws and the top should tilt up. 3. The top will not stay up on it's own, so you will need some assistance holding it up. Some ranges have a couple of disconnect plugs that you can unplug, so you remove the entire top and lay it somewhere to work on. If this is the case with yours (as I suspect it is), lay some soft towels down on the kitchen table or counter top and lay the cooktop upside down. This will make it much easier to work on. 4. Remove affected element by disconnecting the wires first. You may want to write down how they came off, so you can be sure to reconnect them in the right order. 5. Remove mounting brackets holding element in place. Pay particular attention to the numbering scheme on the bottom of the element and where the brackets are mounted. The new element usually doesn't come with new brackets which means you have to take the brackets off the old element and put them on the new element. Make sure you install them in the same numbered holes as they were located before. 6. Reconnect wires and reinstall cooktop, making sure you reconnect the disconnect plugs if equipped. Now, be careful when working on the cooktop while it is upside down. Make sure you don't apply too much pressure on the glass or you could crack it. Also, use extreme care NOT to touch the element surface as the oils from you hands can cause hot spots and effectively ruin it. The bake light material in which the element is mounted is also very fragile. DO NOT put to much pressure on it or it may crack and break. Once you get the cooktop reinstalled and power reapplied, op test it to make sure BOTH elements are working. It is normal to see a little bit of sparking at first with new elements and/or an odor. Test the entire range of the element and make sure it regulates like it should. I hope this helps you.
Posted on Aug 04, 2007
SOURCE: Maytag Gemini oven glass door panels impossible to clean
We had an ugly spill of hot grease/water from a roast, and lots of it ran right into the vent holes on our oven door, covering various layers of glass and other parts inside the door. Yuck. Thankfully we found this site!
"fixetheoven" was certainly on the right track, but missed a key step that makes this job much, much easier. (Maybe they had a few too many sips of wine during the process?! :-)
Anyway, the key to make the job easy, and do-able by one person, is to pull the door off the hinges before starting to remove any screws! Here's how we did it:
1. Open the door about four inches or so, it will stay in place. Hold the door at the sides and lift it up, sliding it right off of the hinges! Now lay it carefully face up on a table so you have easy access to the screws, and no danger of the glass dropping out of the bottom of the door (as apparently happened to "fixedtheoven".)
2. Remove the two screws that hold the panel on one side of the door. (One screw is halfway up the side panel, the other is on the bottom edge of the door.)
3. Slide the panel off, paying close attention to how it fits into place so you can return it to its original position later!
4. Remove the two screws that hold the panel on the other side of the door, and slide that panel out as well.
5. Remove the three screws that hold the panel across the bottom edge of the door, and remove that panel.
6. Now you can slide the front glass out from under the top edge of the door.
7. Clean the front glass, the side panels, and the bottom panel, as needed.
8. There will be another layer of glass inside the door. If it needs cleaning on the underside, remove the screws from one of the metal brackets that hold the glass in place. You can then slide this piece of glass out from the metal bracket at the other side.
9. After cleaning everything, reassemble the door by reversing the above steps.
10. Lift the door by the sides and carefully slide it back into place on the hinges. Be sure it is properly in place and being held there before you let go!!
11. Now go pour that glass of wine and sip to your heart's content, while admiring how clean your oven door is!
Posted on Jul 29, 2009
jumptrout51
  • 3361 Answers
SOURCE: How do I remove the top on a Maytag range
Unplug the range from power.
Open the oven door. Look on the right and left sides of the oven frame just below the top. Remove the 2 screws. Pull the top forward. Remove the wiring harness connector at the back.Lift the top up and off. Set the top aside.
Posted on Nov 11, 2009
SOURCE: I need to replace the glass cooktop on my Maytag electric stove
  1. Open oven door and remove two screws that secure top.
  2. Lift up front and slide forward about 8 inches so that you can disconnect two wire couplings.
  3. Place on table upside down(I put newspaper down to catch the broken shards of glass) and remove burner unit (1piece, 4 screws).
  4. Place old burners on new stovetop in the same position as original.
  5. Remove 4 white plastic shims (round) from old stovetop and put on new stovetop.
  6. Tighten all screws and then sit it back on stove (two front tabs fit into slots) and then insert screws into holes and tighten.
  7. Took about 20 minutes, including vacuuming broken glass from inside burners and cleaning grease form crevices between burners and old stovetop.
  8. Wrap old stovetop in the newspapers that are underneath it and place it all in a plastic garbage bag to avoid any broken glass from falling out.
Posted on Jan 26, 2010
  • 58 Answers
SOURCE: We laid a ( fairly new ) hot cookie sheet atop our
The manufacturers warranty period is only through the first year. So unfortunately you either have to live with it or replace it.
Posted on Sep 18, 2010
Can you replace a Maytag smooth top on a slide in range?
Yes it is replaceable but expensive. Approx $334 plus shipping at sears. The glass top unbolts at the front then lifts off at rear but all the burners must be removed and mounted to the new top.
May 31, 2014 | Maytag MER5775Q Electric Kitchen Range
Can a glass top be replaced on a Maytag electric stove?
yes you can Check with AppliancePartsPros.com. You might save 50 or sometimes as much as 250 on a new glass top. They won t even charge you extra for shipping
Oct 17, 2011 | Maytag MER6769 Gemini Electric Kitchen...
Remove and replace glass top
Hello and sorry to read about your problem.
You might want to think about a new unit. a glass replacement, can run $600.00 to $900.. and more. and that's just for the glass....
I tried to help you.Please help me and vote/rate my response thanks
Dec 22, 2010 | Maytag MER5775Q Electric Kitchen Range
How to clean glass cooktop maytag electric Model
Hello. Maytag has a special cleaning cream just for their glass cooktop. You can get it whereever the stoves are sold or at this link http://www.buzzillions.com/reviews/maytag-cooktop-cleaning-creme-smooth-top-ranges-reviews
Joe
May 07, 2010 | Maytag MEC7536WS Cooktop
Jan 21, 2010 | Maytag MER5775Q Electric Kitchen Range
I NEED TO REPLACE BROKEN GLASS TOP OF MAYTAG MODEL
ITS A LITTLE TRICKY, WHEN YOU GET YOUR NEW ONE LAY DOWN A OLD BLANKET PUT YOUR NEW ONE UPSIDEDOWN ON IT DISCONECT POWER THEN REMOVE YOUR OLD ONE .OPEN THE OVEN DOOR THERE IS 2 OR 3 SCREWS ON THE TOP OPENING HOLDING IT DOWN REMOVE THEM AND SLOWLY LIFT TOP UP AND SLOWLY PULL FORWARD. YOU WILL SEE A CONNECTOR TO DISCONECT ALL THE WIRES THEN LAY COOKTOP UPSIDEDOWN NEXT TO THE NEW ONE. SLOLY REMOVE SCREWS THAT HOLD BURNERS ON BRAKETS. I MARK THE HOLES ON THE BURNERS WITH A SHARPY
Jan 17, 2010 | Maytag MER5775Q Electric Kitchen Range
Glass is shattered to to replace
To replace the door glass do the following:
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Remove the inner screws. Keep all set of screws ordered, and take noteof the order you remove them. You will follow reverse order inreassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
dd5ebd3.gifclick here
Inner Door Glass
May 15, 2009 | Maytag MER5765RAW / MER5765RAQ /...
Broken glass top on my Maytag Schott Clean (upper
u have to replace the whole top and its about 400 to 500 dollars just for the part cheaper to buy new
Mar 20, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Burner on glass stove top has turned black
The nice grey-flecked surface coating is very thin; the solid black is underneath. You've "cleaned" the coating off -- that's why further scrubbing just makes it worse. We did the same thing :-(
Dec 06, 2008 | Maytag MER5770 Electric Kitchen Range
Maytag MER6875A Electric Kitchen Range Logo
47 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
