Question about Samsung BL103 Digital Camera
My camera was dropped in the sand awhile ago. I blew some air in it, and got it to work. After about 2 weeks I was able to start the camera but then it shut off on its own and now the silver lens part won't go back in. I have tried everything to get it shut again. And still nothing. When I press the power button, it clicks twice and then it beeps three times. Can you help me with this, when I bought the camera, there was no warranty offered. This is the 3 Samsung camera that has broke in the past 2 years. And the last one was never dropped. I have the Samsung BL103
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after the sand particles have jammed it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 20, 2010
A few weeks ago, shortly after I'd taken a pic, the lens refused to retract and the camera switched off. It has never been dropped or had anything spilled on it. Strangely, when I press the button...
Sounds like a lens error. Look for sand particles around the gaps of the lens barrel (a single particle can jam it). Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Jul 31, 2011 | Kodak EasyShare V1003 Digital Camera
Hi, my Kodak easyshare MD41 will turn on but when i do it retracts the lens right away. i took it to the beach, so im guessing sand or the sand dust got in it. Is there a way i can fix this without having...
You are right it got some sand into its eyes. You know that canned Air you can get at the office supply stores I used it to blow out the sand. Remember it will blow refrigerant out if you shake it, or turn it upside down. I set it on a table so I could blow straight at it instead of down on it and I blew it off, then blew it off while I tried to open it then opend it and took out the battery to keep it open and blew it evry where i could immagine air might go and put the battery back in and :-)
Feb 20, 2011 | Kodak EasyShare One Digital Camera
When turn camero on the light blinks and says lens error restart camera...just purchased cannon 105 two weeks ago..
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jan 08, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Lens error canon powershot sd1100 is
Apparently, you missed some sand and it just took a while to work its evil way into the works of your camera.
Aug 11, 2009 | Canon PowerShot SD1100 IS Digital Camera
Canon lens cover won't open
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 09, 2009 | Canon PowerShot A630 Digital Camera
Problem with the lens
Apr 25, 2009 | Cameras
Heater, 35,000 BTU Reddy Heater won't fire up.
there is only one adjuster screw in the back of the unit.most likely your problem is in the rotor.you need to take the back plate off then you should see 6 more screws on the metal plate.remove them to get to rotor.the air vains should drop to the bottem without any help.usualy they pick up moisture for the air from sitting.pull the out and soak them in lacquare thinner for a few minutes then wipe them off with a paper towel.install them one at a time and check to see if they drop or not,if they don't i use a piece of 280 grit sand paper and carefully sand the marks off them.don't get to carried away though.sand a little then try them.once you get them to drop by them self reinstall the cover and try to ignite the unit again.
Feb 19, 2009 | Reddy Heater-30-55,000 BTU Variable
Nikon Coolpix s210
Hey SandyG1019,
If you just purchased this camera 2 weeks ago it might still be within the retailers return/exchange period, and I would suggest you just exchange it for a new one. This error message should mean that something is obstructing the movement of the lens (i.e. sand), but could also be do to a problem with the lens mechanism itself. If you choose to try and resolve the problem you could try blowing compressed air into the side of the lens to try and dislodge whatever is stuck in the lens. This being said I would suggest instead having the camera looked at by an authorized service technician since the camera is most likely covered under a manufacturers’ warranty, and the repair would most likely be free. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 29, 2008 | Cameras
Samsung BL103 Digital Camera Logo
52 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
