Question about Refrigerators
Removal of ice dispensing mechanism from freezer door
The Ice chute door is seems to be broken. It doesn't open when the Ice is coming through the ice shoot. The Ice chute door just flops around in the ice shoot.
Posted on May 26, 2008
Door disassembly
most indoor dispensers are just a pathway for the ice to slide down with a flapper the dispensing mechanism is inside the freezer itself.
If for some reason you need to access the inside of the door it usually means removing the door seal to do so.
Aug 28, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
LG Freezer ice maker makes ice but wont dispense
There is a mechanical flap (trap door) that should open to allow ice that is being pushed by the auger in the bottom of the bin to fall out. Possibly the solenoid that opens the door does not work, or you just have an obstruction (piece of ice) preventing the door from opening far enough to allow the ice to pass through. Here is some helpful information and instructions.
Mar 19, 2014 | LG LSC23924ST Refrigeration : Refrigerator...
I have a MN - TFX24PRXB - BB GE Side by side refrigerator. The Ice maker does not make ice anymore. I have tested the water valve and it is working. If I turn the gears it will start the process to...
Check for freezer temp - if it is not 10 degrees or below the ice maker thermostat will not turn the ice maker cycle on by removing the frozen ice in tray and then refilling it for next dump cycle. And if freezer temp is high you may have leaking door gasket, dirty condenser coils, improperly operating self defroster which raises temps, low refrigerant.
Aug 04, 2017 | GE Refrigerators
Hi Don,
Typically this occurs when the dispenser door does not close all the way.
The dispenser door is located in the freezer door in the chute that the ice dispenses down.
With the freezer door open shine a light up from the outside and look down into the door from the inside. If you see light around the door flapper, you will need to replace the dispenser door, if there is a large gap between the dispenser door and the chute you will need to replace the mechanism that controls the door.
Apr 18, 2010 | Electrolux Refrigerators
Whirlpool side by side with ice maker dispenser not working
Hello, we are sorry to hear that you are experiencing this problem. We would suggest checking the ice chute to make sure that there is no ice lodged in the way of the flap. If the issue persist we would suggest having a certified technician out to look at the Refrigerator. If you would like further assistance you can send your name, phone number, address, model/serial of the appliance and the date on which you purchased the Refrigerator to Thank you.
Apr 17, 2017 | Whirlpool Refrigerators
Maytag MFI2266AEU Water and ice dispenser locked, control panel
Door Panel Locked
Press Door Alarm and Freezer "-" at the same time, then release Door Alarm but continue pressing Freezer "-". You will see PE _ _ _ _.
Press Freezer "-" until PE # # # # shows on the panel.
Using Freezer "+" to move cursor, Refrigerator "+" and "-" to change numbers, bring all numbers to "0". Press Freezer "-" until PE and numbers blink. Unplug refrigerator for 45 seconds, never beyond 1 minute or you'll have to start over.
Look inside refrigerator door and locate the serial sticker. To the right of the serial number is the CODE ####. Plug in your refrigerator.
Press Door Alarm and Freezer "-" at the same time, then release Door Alarm but continue to press Freezer "-". Using the same method as above, enter the four digit CODE number you found on the serial sticker. Press Freezer "-" until PE and numbers blink. You have just reset your panel. Unplug for 45 seconds. Plug in refrigerator and you should now have full use of your door panel.
This unit has a built in safety timer mechanism. If it dispenses water for two minutes, it assumes it is flooding your house and shuts the panel down. If you are filling a pitcher of water, just stop dispensing halfway through to reset the safety timer.
Feb 01, 2010 | Maytag MFI2266AE Side by Side Bottom...
How to get ice dispenser panel off front of door?
if its a whirlpoo at the bottom of the trim there are two slots use a flat head pull down and pry out
Jan 21, 2010 | Whirlpool Freezers
GE gss22sgrf sidebyside water dispenser does not work, ice does
these unit have a problem with the water line freezing inside the freezer door. ge makes a tape style heater that goes inside the dispenser area to give just enough heat to keep it from freezing the water line.
you can try to change the freezer settings, warmer, clean the coils at the back of the unit and leave the freezer door open for 20-30 minute to allow the door to warm up and that will be a temporary fix to allow water to flow until you can get the heater kit.
Jan 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Sounds like a control fault on the microswitch to activate the ice and water line. Access to this is immediately behind the ice dispenser section (just above) on the freezer door. Normal access is two screws located behind the removal drip tray section. Either that or the control board for the ice dispenser as you are not getting water as well. Before taking this section apart though you should hear a buzzing sound when you activate the chilled water, if you do then you may have a water supply problem. Hope this helps.
Mar 13, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Water dispenser won't turn off
Stix: Check behind the dispenser handle the switch or button which is responsible to activate the mechanism of water dispensing. If the switch or button is covered with a reubber you must remove the rubber cap or whatever cover it has. If you have mineral oil or somekind of greasy stuff (vaseline or something similar) lubricate the switch or button. Open the freezer door and activate and deactivate the dispenser several times to lubricate the whole mechanism. SithPitt
Jul 04, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
266 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
