Question about Maytag MSD2756G Side by Side Refrigerator
The fresh food side is not cooling, but the frozen side appears to be working fine. There also is water dripping from the corner of the freezer side and puddling up on the floor. Is something froze up, and if so, will simply unplugging and thawing work?
  • Maytag Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Aug 20, 2010
E402b freezing food
there is a little door between the freezer and the fresh food usually when that happens the motor on that door is bad and sticks open and allows the fresh food to get to cold since your freezer actually cools the fresh food side, sorry i cant tell you where it is on yours since they are are different, it will be where the cold air blows in the fresh food side and the part is not usually expensive and fairly easy to replace.
Mar 23, 2014 | Fisher and Paykel Active Smart E522B...
Frozen water lays in the freezer bottom. unit is a KXX not the KXK
I have seen this before. Instead of the water draining out the drain hole it puddles between the freezer and fresh food department. The freezer is fine but the cold air from it cannot get down there and cool that fresh food!. Solution: Thaw out the whole ice box and clear the drain hole of the obstruction and party on.
Dec 30, 2010 | Whirlpool ET1FTKXK Top Freezer...
Will freezer side work if frig side is out
The freezer will appear to still work for awhile after the fresh food side fail to maintain a cool temp, you will need to remove the back in the freezer section and see if the fan motor is turning, if the fan motor is not turning you willl need to replace the fan motor and this will correct the problem and allow cool air to circulate to the fresh food section and cool the fresh food side of the refrigerator
Apr 17, 2010 | Refrigerators
GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side by side,water drips from bottom freezer door
I have the same problem. Just talked to a friend that's a great appliance repairman. he said I have to remove the panel in the back inside of freezer and there is a drain that gets clogged up, a little hole or tube.
clean that and should work fine and stop leaking. I haven't had time yet, but this weekend I'll do the deed. Hopes this helps ya!
Kitchenaid KSRA25IL Freezer working Fine - Refrigerator not
many times when a unit has a defrost problem the coils freeze up and do not allow the fresh food side to cool properly...check for a build up of ice on the inside back wall of the freezer compartment. if there is a build up of ice, you have a defrost problem. Also, check to make sure the evaporator fan in the freezer is blowing the air into the fresh food side.
Dec 26, 2008 | KitchenAid KSRS25IL Side by Side...
Fresh food section not maintaining cold temp
You're frozen up.  Defrost completely.  Then, clean your condenser.  Make sure to never leave open containers in the fridge...water condenses into ice.  If you still have problems, you may be low on gas.
Nov 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
FRESH FOOD COMPARTMENT TOO WARM
it could be a defrost heater problem . the heating cycle is not defrosting the ice that is why your having frost build up. the heater could be damaged, thermosdisc damaged, electronic timer module damaged.try thawing it up by unpluging it for a day or two until there is no more water dripping at the back then try it again, im sure the refrigerator section would cool again for a week or two before it wouyld go back to the same problem. dont forget to bring back the setting to 5 for freezer and 35 for refrigerator in order for the thermostat to work.
Feb 04, 2008 | GE GSS20IEM Side by Side Refrigerator
Admiral - GC2224GEKB
Does freezer cool like the cold food section? Did this suddenly happen, and frozen food began to thaw?  Most freezers control the cooling in the cold food section. The freezer must work fine before the cold food section will work fine. Let us know more, Thanks JT
Oct 24, 2007 | Admiral 26 cu. ft. Side-By-Side...
Maytag MSD2756G Side by Side Refrigerator Logo
104 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
