Question about EliteGroup NFORCE 570 SLIT-A Motherboard
SATA drive stops or hangs . . .
My system:
NFORCE 570 ****-A V5.1 MB
Intel Pentium D 830 3.0gGHz DT 800FSB Socket 775
MemoryPRO 2GB Dual Channel Kit (1GBx2) DDR2 PC2-5300 DDR2-667 CL5 240-Pin DIMM Memory
Hitachi 320GB 0A33435 - SATA2 U300 7200rpm 16MB
BFG NVIDIA GeForce 7300 GT 512MB PCIe
The problem: When i built this pc, i originally installed Win XP HE on this sytem. I eventually set it up to dual-boot with Vista Ultimate. It worked great until the system was just shut off one day, when i started it back up, it would no longer recognize a SATA drive.
i thought maybe the drive was bad, then i bought a Maxtor 320GB SATA and i was going to install Vista on this machine, however the set up nor my BIOs detected this drive either.
So, i contacted ECS and there support is reeally slow, so i decided to check thier site for a BIOs update which did exsist, i did the update so now i am running v5.2e , however the BIOS sees the drive only every other boot up, and if it does see it, it will not boot to it. i can boot to the IDE drives all day without a glitch. The SATA drives are enabled in BIOS, BIOS functions properly, everything else with the pc works fine. I just can not get this SATA thing figured out. HELP!
Thanks
Alex
  • fadetoal May 03, 2008
    Thanks Mike, i thought i did all i could. I really love this board and hate to part with it, i hope if i get a new just like it that the bugs are worked out. i apreciate your time, i thought i would get a 2nd thought on it and go from there. You were helpful!
    Alex
    President:
  • 2,351 Answers
Hi fadetoal, it's not you or you're drives. It's the onboard SATA controller. When a board is SATA compatible & the bios does not see the SATA drive (List the SATA drive), the fault is the board. You're board goes one farther than normal. Bios see's the drive but can't run. All you're going to do is pull you're hair out trying to get the board stable. Hope its still in warranty.
RMA time: http://www.ecsusa.com/ECSWebSite/Support/rmamb.aspx?MenuID=25&LanID=9
Best of luck!
Mike
Posted on May 03, 2008
Pentium d cpu clock speed 3.0
CLEAN THE CD/DVD-WRITTER WITH CANED AIR,AND CLEAN
CD WITH A FINE BRUSH NEVER AGAINST THE TRACKS
HOPE IT HELPS.
Aug 31, 2013 | Intel Gigabyte GA-8I945P-G Dual-Core CPU...
Ms 7529
Hello here are the supported cpu list for your mainboard:
http://www.msi.com/product/mb/G31M3-F-V2--3-Audio-Ports-.html#/?div=CPUSupport
You maybe have to upgrade the bios to support the new cpu.
May 25, 2012 | Intel Motherboard
My Ram is 512MBytes and Motherboard Chipset model is i945GZ. Can i use 2GB Ram?????
Hardware Support
The Biostar i945GZ 775 SE supports RAM a maximum of 2GB using its two 240-pin DIMM slots, each can be populated by a 1GB stick. The board supports DDR2 400 or 533. With two identical RAM sticks installed, the board will switch in dual-channel mode operation.For the support of processor, the board can accommodate Intel Pentium 4, Core2Duo and Pentium D, even Celeron D, all with clock speed up to 3.8GHz; and all are based on a LGA775-pin socket architecture. use an Intel Pentium D 820 2.8GHz (dual-core, Smithfield) processor on this board. use the following components to complete the system: CPU: Intel Pentium D 820 (Smithfield) 2.8GHz, dual-core
RAM: Hynix PC2-3200 2x512MB (1024MB) DDR2 400 HD: Seagate SATA-I Barracuda 7200.8 250GB CD/DVD-ROM Drives: HP dvd640, Phillips DVD-ROM
Oct 10, 2011 | Intel Computers & Internet
Is there a way to put more than 2 Gigabyte of RAM onto an Abit LG-95Z motherboard?
No, the mainboard does not support more than 2 gb of ram.
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?fMTYPE=LGA775&pMODEL_NAME=LG-95Z
CPU
  • LGA 775 Socket for Intel® Pentium® Dual-Core / Pentium® D / Pentium® 4 / Celeron® D Processors with 800 MHz FSB
  • Supports Intel® Hyper-Threading Technology
  • bullet_31.gif Chipset
  • Intel® 945GZ / Intel® ICH7 Express Chipset
  • bullet_31.gif Memory
  • 2 x 240-pin DIMM sockets support max. memory capacity 2GB
  • Supports Dual Channel DDR2 533 Un-buffered Non-ECC memory
  • bullet_31.gif Graphics
  • Integrated Intel® Graphics Media Accelerator 950 (Intel® GMA 950 )
  • bullet_31.gif LAN
  • On board 10/100M PCI controller
  • bullet_31.gif Audio
  • On board HD 7.1CH Audio CODEC
  • bullet_31.gif Expansion Slots
  • 1 x PCI-E X1 (Wi-Fi Accessories)
  • 2 x PCI
  • bullet_31.gif Internal I/O
  • 1 x Floppy Port supports up to 2.88 MB
  • 1x Ultra DMA 100/66/33 IDE connector
  • 4 x SATA 3Gb/s connector
  • 2 x USB header (support 4 ports)
  • 1 x FP-Audio, 1 x CD-In
  • bullet_31.gif Back Panel I/O
  • 1 x PS/2 Keyboard, 1 x PS/2 Mouse
  • 1 x Serial port, 1 x Parallel port, 1 x VGA connector
  • 4 x USB 2.0, 1 x RJ-45 LAN connector
  • 7.1 CH Audio connector (Front, Line-in, MIC-in, Center/Subwoofer, Surround, Rear Surround)
  • bullet_31.gif Serial ATA
  • 4 x SATA 3Gb/s offer by Intel® ICH7
  • bullet_31.gif Form Factor
  • Micro ATX form factor 244 x 244mm
  • PCB Color: Blue
  • Aug 21, 2011 | Abit LG-95Z Motherboard
    Im trying to stall 4 module by kingston khx6400d2ll/1g but the computer only pickup 2-248 g
    Follow all the instruction bellow.When you install the ram follow the bus speed because memory speed can not excite the limit from 800mhz.
    Elitegroup Computer Systems is known for their array of products from desktop computers to graphics cards and motherboards. At hand today we have their NF650iSLIT-A motherboard, which is powered by NVIDIA's nForce 650i Chipset and caters toward the computer enthusiast crowd, but can it really deliver?
    Processor
    · LGA-775 Socket for Intel Core 2 Extreme, Core 2 Quad, Core 2 Duo, Pentium 4, Pentium D processors
    · FSB 1333 (OC), 800, 667, 533MHz
    · Supports Hyper-Threading Technology
    Chipset
    · NVIDIA nForce 650i SLI
    · NVIDIA C55 + NVIDIA MCP51
    Memory
    · Dual-channel DDR2 memory
    · 4 x 240-pin DDR2 DIMM
    · Supports DDR2-800/667/533MHz
    Audio
    · Realtek ALC883
    LAN
    · Marvell 88E1116 Gigabit
    System BIOS
    · Award BIOS with 4Mb Flash ROM
    Hope it will help you.
    Jan 07, 2011 | EliteGroup NF650iSLIT-A (V1.0) Motherboard
    Dell optiplex gx280 OG8310 desearia saber si soporta dual core
    dual core not supported but
    You can use any of the following processors:
    Prescott P4 Kit, 520, 2.8Ghz, 800FSB, 1MB
    Prescott P4 64bit Kit, 521, 2.8Ghz, 800FSB, 1MB
    Prescott P4 Kit, 530, 3.0Ghz, 800FSB, 1MB
    Prescott P4 64bit Kit, 541, 3.2Ghz, 800FSB, 1MB
    Prescott P4 Kit, 540, 3.2Ghz, 800FSB, 1MB
    Prescott P4 Kit, 550, 3.4Ghz, 800FSB, 1MB
    Prescott P4 Kit, 560, 3.6Ghz, 800FSB, 1MB
    Prescott P4 Kit, 570, 3.8Ghz, 800FSB, 1MB
    Nov 15, 2010 | Computers & Internet
    Drivers for msi 848P Neo-V Pentium 4 800FSB Prescott Ready Socket 478 Motherboard w/SATA OEM
    hi
    go to following link you will have your MSI M/B Drivers
    http://driverscollection.com/?H=848P%20Neo-V&By=MSI%20(Microstar)
    Aug 30, 2010 | MSI 848P Neo-V (MS-6788-040) Pentium 4...
    Dell E210882 Socket 775 PC Computer Motherboard MB SATA can this surport daul processors
    it only support socket 775 single core pentium 4 or celeron processors IT DOES NOT SUPPORT ANY DUAL CORE CPU'S SUCH AS PENTIUM D OR ANY DUAL CORE OR CORE 2 DUO PROCESSORS
    Nov 21, 2009 | Computers & Internet
    Motherboard specs JM679 m6300
    According to DELL, the compatible processors with this unit are the Intel T7700, T7500 & T2750, also model T1300
    Sep 18, 2009 | Dell Precision M6300 Mobile Notebook
    Does msi motherboard P4M900M3 support this cpu Intel Celeron D CPU 3.20GHZ 512 Socket 775
    MSI has two boards P4M900M3-F, P4M900M3-L.
    Both of this will support your CPU
    Nov 26, 2008 | MSI Computers & Internet
    EliteGroup NFORCE 570 SLIT-A Motherboard Logo
    216 people viewed this question
    Top EliteGroup Computers & Internet Experts
    David
    David
    Alun Cox
    Jerry Umali
    Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
