Question about Fuji FinePix A500 Digital Camera
Changing from windows XP to Vista
I recently purchased a new computer which has windows Vista. I put the cd in so I could run the setup so I could hook my camera up to this computer to copy my pictures to it but it said it only works with XP. How an I get my pictures onto my new computer??
  • 537 Answers
Which camera do you have? Unfortunately some hardware vendors never supplied their customers with WinVista drivers. You might try the WinXP drivers anyways with your Vista OS.
Posted on May 03, 2008
I have purchased an hp550 computer with the Vista operating system. i wish to downgrade to the win XP operating system. how is this done ?
Greetings.
There is no direct path to downgrade Vista to XP. You can’t simply insert the XP installation CD media into the CD-ROM drive and hope to ‘upgrade’ and replace the Vista with Windows XP usual install routine because Vista won’t allow it to be overwritten. XP will treat Vista as ’superior’ operating system and refuse to install over it. There’re actually few options available instead of completely uninstall Vista as listed below. But if you decide to downgrade from Vista to install XP, there is also a simple guideline that you can observe to ensure that the migration goes smoothly.
Option 1 – Dual Boot:
It’s by far the easier and best method to run XP instead of Vista if you have another partition or hard disk. Simply boot up any XP setup media and install XP into different partition or hard drive than the Vista installation. Once completed, you can choose to boot up either XP or Vista, and has the best of both world.
Option 2 – Virtual Machine:
Install VMware Server or Virtual PC 2007 (both free) or any other virtualization software, and then install Windows XP into the virtual machine
environment. You will get XP which runs inside Vista, with minor compromise on speed, performance and have to go through Vista first on every bootup.
Option 3 – Format the Hard Drive, Wipe Off Vista and Install XP:
For those who totally fed up with Vista and just want XP, or prefer a clean installation of OS has only this option to rely on. To downgrade to XP from Vista, you have to basically delete the whole hard disk that installed with Vista, and start anew with XP. Here’s a simple guide and procedures that you can try to follow to switch to XP. However, each system configuration is different, so you may have to adapt the steps to suit your own need.
1. Download all drivers for your system for Windows XP from the manufacturer’s website(in case if you don't have the CD/DVD installers). Copy the drivers files to a USB flash driver or external hard drive or burn them to CD/DVD.
2. Find a Windows XP installation CD (should be pretty easy to find or else you can search in torrent sites such as Demonoid to download via BT network such as uTorrent and BitComet or search and download via ED2K network client such as eMule. You can also use Volume Licensing (VL) CD, retail (FPP) disc, or system builder hologram CD provided by Microsoft.
3. You will also need a XP product key even if you legally can downgrade from Vista Ultimate or Business edition. The Vista serial number won’t works with XP. (try to search for XP product key on web).
4. Backup to USB flash disk, external portable hard disk or CD/DVD every data files and any other things such as documents, downloads, pictures, movies, programs and etc that you need and want to keep. You can also create a second partition with disk management utilities such as Acronis Director or Partition Magic, and then move the data files to the new partition.
5. Ensure that also you have CD or DVD setup media for the software applications that you want to install and use after wiping off your system from Vista.
6. If your OEM doesn’t provide you with recovery CD/DVD discs and Windows setup media discs (it’s because they’re stored in the hard disk in hidden location), you may want to burn a copy of recovery CD to CD/DVD first before you proceed, just in case the hidden partition is lost and you want to recover your computer to original state. (How-to Guide: IBM/Lenovo ThinkPad recovery CD)
7. If the system has SATA (Serial ATA) hard drive, locate the driver for SATA controller and put it in USB flash drive, diskette or CD first. If you have PATA (normal IDE) hard disk, simply go to BIOS CMOS to disable SATA or Native SATA mode if you don’t want to install XP on SATA hard drive. Else, you can also create an XP install disc with the SATA drivers integrated by using tool such as nLite.
8. In the BIOS, also set the CD or DVD optical drive as the first boot device in the boot sequence.
9. Put in the Windows XP installation CD into CDROM drive and boot up the computer by using the CD. You probably need to press a key when prompted with “Press Any Key to Boot from CD…”.
10. If you’re using SATA hard disk with driver on external media (not integrated into XP setup disk), remember to press F6 when you see the message at the status base: “Press F6 if you need to install a third party SCSI or RAID driver…” during the very initial stage of setup to load the SATA driver so that the SATA hard disk can be recognized.
11. Run through the setup wizard at per normal. However, when prompting for where to install Windows Vista, delete (by pressing D and then confirmation), create and format the Vista disk drive or partition (if you have multiple partition). And then choose to install on that just formatted partition or hard drive.
IMPORTANT: If you choose the wrong hard disk or partition with data to delete, you will lose your essential data.
Note: If the setup does not allow you to delete or format the Vista partition or drive, you will need to find a third party software that can recognize and read NTFS filesystem to clear the drive or partition first.
12. Enter any product key for XP. Vista product key will not work.
13. If you own a legitimate Windows Vista edition that allows for downgrade (See Vista downgrade rights), call Microsoft after performing the clean install of Windows XP Pro to activate the XP installation. Notify Microsoft that you’re downgrading from Vista and require to activate XP Professional or other version allowed newly installed. You won’t get a new Windows XP product key though. You will have to read out the long Installation ID plus your original Vista serial key, and Microsoft will provide an activation ID that will make the XP usable.
14. Install the drivers for your system devices.
15. Reinstall any software programs that you want to use.
16. Move back the data files and documents.
Thanks
Nov 03, 2009 | HP Business Notebook 550
I recently changed to a windows vista computer and the installation software that came with my Olympus camera is not installing properly. It shows that its there but it won't detect my camera when...
The CD provided may not have seperate driver for vista.
1.Try downloading the latest drivers for vista from Olympus website.
2.or Before running the setup.exe from CD, right click it -> properties. In that Compactibility tab, select the check box "Run in compactible with " and select windows XP in the list. After that try reinistalling the driver by running the setup.exe in CD
Aug 12, 2009 | Cameras
Can't install new OS
you need to install directly from the vista disc when the computer is powered on, put the disk in and it should ask you to press any button to start from cd..
if not then the computer is not set to start up from a cd, you can either enter the setup / bios to change that setting OR right when you power up the computer look at the screen it will say what button to press in order to enter boot menu, it will very likely be button F12 or similiar, it should say on the screen when you power on.
if it doesnt, then you need to go into the bios and change the boot order so that the computer starts from the CD first. the computer should say what button to press to enter bios or cmos or setup when its turned on
after that you should be able to start from the cd and install the OS (Operating system, eg.Windows)
heres some info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
ones you get into the vista setup you can empty the hard drive, getting rid of windows xp and then install windows vista over it.
Let me know how that goes,
Thanks,
Ekse
Jun 03, 2009 | Toshiba Portege R100 Notebook
Reboot
To Reboot a computer is to turn it off, wait at least 20 seconds, then turn it back on.
A.If you're thinking of Reboot, as to reinstall the Operating System, you use a Restoration Disk, (sometimes listed as Recovery Disk), insert it in your CD/DVD drive, and restart your computer.
(Just press the CTRL, ALT and Delete keys AT THE SAME TIME.
Not shouting. Windows XP and Windows Vista are examples of an Operating System)
B.If you're trying to install an Operating System, from a CD disk that you bought, I suggest you go into BIOS Setup, and in Boot Order, change the first boot device to CDROM. Insert the CD disk in your CD/DVD drive, and restart the computer.
If you buy a Full Installation CD disk, as listed above, you have to change the Boot Order.
For example:
1.You have Windows XP on your computer now. It has problems, and doesn't work correctly. Instead of getting the Restoration Disk from your computer manufacturer, you decided to just buy a genuine copy of Windows XP, and install it. (This is a Full Installation Disk)
The Windows XP you have installed now, will not let the one you bought install over it, by just putting the disk in the drive. Change the first boot device, in Boot Order to CDROM, and it will. The Windows XP you have now, will 'see' the Windows XP you're trying to install, as just the same version. You have to install a better version of Windows, in order for it to write over what is installed.
Such as Windows Vista.
2.You have Windows Vista on your computer, and are not happy with it. You would like to put Windows XP on instead. Windows XP is considered a lesser version, and Vista won't let it write over it.
Go to BIOS Setup, change the first boot device in Boot Order, to CDROM, and it will.
May 10, 2009 | Compaq Presario R3000 Notebook
Changing operating system from windows vista to windows xp; how to install a bluetooth device
You can change your OS from Vista to XP by try to follow the ff. steps:
1. turn on your computer then press Delete key to enter in BIOS Setup as to set your system 1st boot to CD thru the BIOS advance feature or you may press F8 key to select the CD 1st boot device. then F10 to save changes in your BIOS setup.
2. then, insert you CD with XP operating system in your computer CD/DVD device & just read / follow the next steps that will appear on Screen.
Hope this would help. Best regards.
Apr 22, 2009 | Computers & Internet
I recently purchased from Avanquest Who do you think you are? Family Tree Maker Deluxe Edition New Version. My computer when when I made the above purchase was running Windows XP, I have changed my...
I have Professional Business Cards which I bought while running XP and installed it when I bought a Vista machine without a hitch. Avanquest and MySoftware have always been supportive and there is one sure way to find out so go for it. ~Steve Medley
Oct 21, 2008 | Computers & Internet
Changing an english computer over to spanish
to change your operateing system language you need to get the windows in that language. There are many difrent versions of windows in difrent languages.
If I want my xp to be in finnish I have to get my hands on a CD which is in finnish. IF I want english I need a english version of the cd.
You will need a spanish xp setup cd.
also it may be possible to convert xp into another language. with some
Windows XP Multilingual User Interface (MUI)
I hear it costs money and I haven't used or tryed it.
Jun 27, 2008 | HP Pavilion dv6000z Notebook
XP and Vista
If you have the installer of windows xp you can change the vista to xp. First check if the booting options is set to cd/dvd boot. In the cmos setup change the booting option from hdd to cd or dvd. Then insert the xp installer to the cd in follow the setup instruction
Apr 14, 2008 | Computers & Internet
Fuji FinePix A500 Digital Camera Logo
57 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
