Win XP M/Board Change
Blue screen flashes and machine reboots after I have installed a new motherboard?
    Sergeant:
  • 221 Answers
Check to make sure the power supply is connected securely to the motherboard and all of the peripheral devices. Sounds like a possible power issue. If you have a power supply from another computer, try swapping the two and see if the same problem occurs.
Posted on May 03, 2008
Cant install os on this board
Try to find a copy of win XP ser pac 3 and reinstall
Dec 04, 2013 | Biostar M7nba Rev:1.2 Socket 462...
I bought a LENOVO B 450 laptop. The dealer installed WIN 7. But in WIN 7 Tally 7.2 will not work. So I wish to install WIN XP. But when I tried to install WIN XP there shows an error message and a blue...
Please note that installing an operating system on an OEM machine OTHER than what was factory-installed on it may void either phone support for the customized OS or the warranty itself.
Lenovo Machines, like most new OEM models are set, by default to run their hard drives in AHCI mode for better performance & power management. Go to the computer's system setup F1 or Del while the computer is starting up to locate the Power, Hard drive or System configuration (Lenovo computers have different System Setup formats for each model so you'll have to navigate around a bit since they may be labeled differently).
Once you find it, you have to change the setting from AHCI to IDE or Compatibility, whichever option is available (once again, each model has a different format & labeling convention). Save the changes & exit the setup & retry the installation. Should work.
Aug 13, 2011 | Computers & Internet
BSOD keeps on flashing during installation of Win XP
I think the problem is with your RAM installed, try to swap other memory on your computer or try your RAM to other PC to determine if its working.
Jul 11, 2010 | Asrock P4VM8 Motherboard
MSI K8MM-V motherboard doesn't work after BIOS update
First of all never update or install the new bios.. plz let it be geniune .. another thing is that you have to now do the following which might help.. not sure but should
  1. Open the case
  2. look for the jumper on the mother board.
  3. when found take it out
  4. and the reboot or boot your machine
  5. then check if bios options and windows have started
  6. if windows does not appear then install new OS recommended windows 7.
  7. after this plug the jumper back into the motherboard back.
Now this won't work then it can posibly have damaged you motherboard...
Jun 23, 2009 | MSI K8MM-V Motherboard
Blue Screen
OK, so I took out the added RAM, changed the internal RAM to a new 1GB stick. The machine booted, windows started, I logged on, then blue screen. I put the old internal RAM back in, changed the hard drive, same result. This test suggests that the RAM is fine as is the hard drive as the blue screen appeared with different hardware. My next step is to replace the motherboard as the appears to be the issue. I'll let you know how I get on.
Jul 17, 2008 | Toshiba Computers & Internet
Making a bench machine on the tyan dual core pentium III mother board
Howzit
If you had no problems installing the XP second time around your problem is definitely not the harddrive. Suspect that that error you got was a blue screen. You problem most probably lies with your memory modules (RAM) if you are using more than one memory module then you need to check that they work on the same frequency (probably not since you are having this problem) If you are in fact using more than one module try just using one. If you only have one then you might try another as this one could be faulty. As to NTFS it is the best suitable format for XP therefore that is not a problem. Let me know how things turn out. Thanks
Regards.
Oct 30, 2007 | Tyan Trinity 450 (S2507S) Motherboard
Computers & Internet Logo
David Payne
David Payne
