Question about Car Audio & Video
How to charge and hook up a capacitor for a scosche kpca4
3 Suggested Answers
  • 85 Answers
SOURCE: i trickle charged a new scosche 500k micro farad
do the rca's work and does the speakers work on the radio. if the rca's don't work the rca's do have a fuse inside right next to the rca's on the circuit board. it is a small black rectangle soldered on both sides and has the letter f on it. if no sound comes from the speakers on the doors the output on the radio is probably damaged. the item number of the part is tda 7856
Posted on Sep 08, 2009
djheathen
  • 21 Answers
SOURCE: How do you hook up scosche 500k micro farad digital stiffening capacitor? Read more: http://wiki.answers.com/Q/How_do_you_hook_up_scosche_500k_micro_farad_digital_stiffening_capacitor
you hook it up like a battery. positive to positive supply, and negative to negative supply, or ground. it may require a remote turn-on from a head unit, if there is a digital display on it. usually, it is the tiny screw, that looks like it holds the plastic cover on.
Posted on Sep 04, 2012
I need instuction manual for FAL-3 output subconverter
http://www.scosche.com/car-audio/downloads/dl/file/id/667/slc_4_instructions.pdf
The FAI-3A is just the "Walmart exclusive" version of the SLC-4. The two products are identical except for the model number.
Jul 20, 2015 | Scosche Industries Scosche Fai 3a Oem...
Aug 31, 2012 | Car Audio & Video
How do you hook your compacitor to your amp
take your main power/ground leads,put them on the capacitors terminals,then take how ever many feet of wire needed to go to your amp,put the ground on ground and power on power.
Jul 10, 2010 | Scosche Industries EFX Amplifier Wiring...
Describe how to connect a scosche 500k micro farad
Put the capactior in parallel with your battery right before the amplifier. So Postive lead of cap to your 12 Volt line and negative lead goes to ground. It is also suggested that you charge the cap before placing it directly in parallel with the 12 volt rail. yo ucan do this by using a 1000 ohm resistor with a power rating of 1 watt. Disconnect your amplifiers so it is just your cap and battery. Replace the fuse with the 1000 ohm resistor. Once the resistor is in place hook up your cap. It will take a little bit for it to charge. RC time constant is T = Reistance X Capacitance. So 1000 ohms X .5 Farads = is about 8 minutes, or you can just measure the voltage with an volt meter and when the cap reads 12VDC you can then hook it up. BE CAREFUL NOT TO SHORT TERMINALS. THIS CAPACITOR I STORING A LOT OF CHARGE.
Jan 26, 2010 | Car Audio & Video
I trickle charged a new scosche 500k micro farad capacitor and when i hooked it to my trucks system it threw my amps into protection. so i replced both subs and got rid of cap.now the cd reciever plays but...
Sep 08, 2009 | Sony Car Audio & Video
I installed a scosche 500k micro farad capacitor in my truck. i have a 800w sony explode running a volvonhag 12" sub, the doors are run by a rockford 40i amp. sounds great till capacitor hook up. amp cuts...
You need to put the capacitor after the in line fuse/ distributor block. Because you are putting it on only your subs you are running it into fail because of a negatuve ground loop which is why they play low then cut out. Also check your grounds for both amps after rewiring and make sure they are tight.
Sep 07, 2009 | Car Audio & Video
Wiring the scosche fai-3a to a pioneer two channel amp
the 2 left and right dont matter, it only matters when ur hooking up a 4 channel amp.
all u do is connect one of the channels to it but it would be best o buy a stereo ull have alot of engine nose and vibration on ur speakers and a thump every time u turn on ur car but itll sound ok for now ti
Jul 07, 2009 | Scosche Industries Scosche Slc4 Speaker...
Iphone avic n4
Apple in there infinate wisdom have decided to change which pins on the ipod connector do charging for the Iphone / Itouch / newer nano's. This means that if you had "old" iphod accessories, you need to buy all new ones in order for your iphone to work. What a neat neat trick for generating revenue - huh!
Thankfully scosche has made an adaptor that just flips the pins around so all your older ipod adapters work with iphones. The part is called the Scosche passPORT Charging Adapter for iphone 3G. It can be found for about $20 online.
Jun 13, 2009 | Apple iPhone 3G
Lanzar amp
If it keeps blowing fuses then #1 its internally damaged or "blown" .. Or #2 i would make sure you have the battery power hooked up to the + terminal and the ground wire running from the car body to the - terminal.. so if its hooked up correctly and keeps blowing fuses then it requires repair.. I wish i had better news but thats all it can be...
Aug 20, 2007 | Scosche Industries Scosche High...
Car Audio & Video Logo
234 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
