Is the CANON printer MFC4150 the best value for money for a printer for secretary duties, and also to design notice papers for Masonic orders
    Novelist:
    Scholar:
  • 148 Answers
To answer weather or not it is the "best for your money" it would be good to look at your specific printing needs vs. the price of the supplies rather then the initial cost of the unit.
For that printer a black and white cartridge will run around $60-80 and yield about 2000 copies.
Other printers on the market such as an HP P1006 will run $100 for the printer and $60 for the cartridge which will yield about 1500 prints. Whereas a BROTHER HL 2140 will run about $119.99 and need a separate drum and toner cartridge tho the high yield ink cartridge will yield 2600 pages and run $50
It would also be good to recognize that cartridge yield is largely determined by how much ink is used per page. So if you are doing normal letters with little to no graphics the yield numbers will be fairly close.
The MFC4150 appears to be a good "Middle of the road" small business printer which will not require separate drum and toner cartridges and yield a good amount of prints for the money.
Posted on May 03, 2008
  • 156 Answers
Yes that is actually a VERY great deal... most comparable printers are around 499$ 599$... I'm taking it you found this one on clearance for like 150$-200$? If so BUY it.
    Genius:
  • 1,447 Answers
I'll say that it is but check this site for info about buying printer specially all in one printers, www.castleink.com. this site will give you info about laser printers ( cons and pros)
pls rate solution as fixya, thanks!!
  • Edgar Allan Pagayona
    Edgar Allan Pagayona May 03, 2008
    Click on this link so that youll know which printer to get fo a home office equipment
    INFO ON WHAT TO BUY
    and here are the spefication of your printer
    Print,
    Copy, Fax and Scan with the imageCLASS MF4150 Laser Multifunction from
    Canon. Benefit from the convenience of having the office functions you
    require in one reliable solution.
    Packed
    with terrific features like a 35-sheet Automatic Document Feeder,
    250-sheet front-loading paper cassette and the Single Cartridge System,
    you no longer have to waste time in front of old, slow office machines.
    Load the originals in the document feeder and off they go. Your prints
    and copies will be made at up to a fast 21 pages-per-minute, and when
    faxing or PC faxing, documents will be transmitted through its Super G3
    modem at up to 33.6 Kbps.
    Featuring
    Duplex Output! The imageCLASS MF4150 provides two-sided capabilities
    for printing, copying and receiving faxes, enabling customers to
    significantly reduce paper consumption. Simply use the 35-sheet
    automatic document feeder (ADF) or letter sized platen glass to print
    on both sides of a single sheet of paper.
    This
    compact desktop design also incorporates Canon's Single Cartridge
    System"The easy-to-replace cartridge that simplifies maintenance by
    combining the toner, drum and other moving parts into one unit
    resulting in excellent image quality retention and eliminating the
    complication of purchasing or storing separate toner and drum
    consumables.
    When
    scanning documents, you will achieve remarkable tone-on-tone clarity
    with color scanning up to an enhanced resolution of 9600 dpi. Overall,
    your imageCLASS MF4150 will complete projects quicker with the USB 2.0
    Hi-Speed interface.
    The
    imageCLASS MF4150 will assist you with your business needs, and if
    sharing its productivity is a requirement, an optional print server is
    available.
    Features:
    • Fast 21 ppm / cpm laser output
    • Duplex (two-sided) output
    • Up to 9600 dpi color scanning
    • 33.6 Kbps Super G3 fax
    • USB 2.0 Hi-Speed for optimal performance
    • 35-sheet Automatic Document Feeder
    • 250-sheet front-loading paper casette
    • Single Cartridge System
This started out as error 5200. Now, my Canon MX340 printer isn't connecting to the computer. The computer acts like the printer hasn't been installed. I tried to remove the printhead and restart...
Issue: How do I align the print head?
Solution: Perform a Print Head Alignment (Windows)- MX340
Aligning the Print Head Position Print head alignment corrects the installation positions of the print head and improves deviated colors and lines. The procedure for performing print head alignment is as follows:
alignike.gif Print Head Alignment
  1. Open the printer driver setup window
    • In Windows Vista, select the Start menu -> Control Panel -> Hardware and Sound -> Printers.
    • In Windows XP, select the Start menu -> Control Panel -> Printers and Other Hardware -> Printers and Faxes.
    • In Windows 2000, select the Start menu -> Settings -> Printers.
  2. Right-click your model name icon, and then select Printing Preferences from the displayed menu.
    The printer driver setup window appears.
  3. Click Custom Settings on the Maintenance tab.
    The Custom Settings dialog box opens.
  4. Check the Align heads manually check box.
  5. Click Send, and click OK when the confirmation message appears.
  6. Click Print Head Alignment alignike.gif on the Maintenance tab The Start Print Head Alignment dialog box opens.
  7. Load three sheets of A4 size or Letter size plain paper into the rear tray (3).
  8. Execute head alignment Make sure that the machine is on and click Align Print Head.
    Follow the instruction in the message.
  9. Check the printed pattern
    Enter the numbers of the patterns with the least amount of streaks in the associated boxes.
    Clicking the patterns with the least amount of streaks in the preview window, will automatically set their numbers in the associated boxes.
  10. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
      (A) Less noticeable vertical white streaks
      (B) More noticeable vertical white streaks
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white streaks.
      (A) Less noticeable horizontal white streaks
      (B) More noticeable horizontal white streaks
  11. Confirm the displayed message and click OK.
    The second pattern is printed.
    Important: Do not open the Scanning Unit (Cover) while printing is in progress.
  12. Check the printed pattern
  13. When you have entered all the necessary values, click OK.
    Note:
  14. Confirm the displayed message and click OK.
    The third pattern is printed.
  15. Check the printed pattern
    Enter the numbers of the patterns with the least noticeable horizontal stripes in the associated boxes.
    Clicking the patterns with the least noticeable horizontal stripes in the preview window, will automatically set their numbers in the associated boxes.
  16. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white stripes.
      (A) Less noticeable horizontal white stripes
      (B) More noticeable horizontal white stripes
Note: To print and check the current setting, open the Start Print Head Alignment dialog box, and click Print Alignment Value.
Aug 11, 2011 | Canon PIXMA MX340 Wireless Office...
Everyone with canon pixma mx320 is having same problem where paper will feed in faster on one side and eventually give you a paper jam. why can't you guys put a solution for that?
I am a Canon engineer who actually works for canon and goes out in the field and repairs Canon equipment. I can assure you there is no problem of skewing in the paper feed of any of the current canon range. Paper skew is always down to the paper hitting an obstruction in the feed. Also if you are using paper of less than 80gsm in weight then skew can occurr. Most of us "Guys" offer this service totally free and make no money from Fixya. I am one.
When your machine jams, pull the paper back out SLOWLY and look for a "Nick" in the leading edge of the sheet. Place this back in the tray and you can now see where the obstruction will be because the nick will line up with the obstruction. Any money you like and you will find either a drawing pin (Usually a cork notice board is above and behind the machine on a wall) or a staple or paperclip will be jammed in the sheet feeder.
Good luck.
Jul 13, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Brand new today. Photos print with vertical lines, equal distance of about one and three quarters of a centimeter apart. Looks like presure as it is more noticable on the darker colours. Is it how the...
I have the same problem with my Canon MG6150. Lines a bit narrower, but still. Only noticable on the dark colours. Try the cleaning program, as it is probably a clogged nozzle. It helped for me, a bit.
Sep 20, 2010 | Epson Stylus 2200 InkJet Photo Printer
I RE FILL MY CANON MP145 USING INK MAN BUT MY PRINTER DID NOT READ THE INK STILL KEEP ON TELLING NO INK
Best solution i think
How to reset the Canon MP150 (also worked with my MP140 so it might work with others as well) after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer's power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
Printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed Printer with paper.
7) Press the power button twice and then press the colour button once. The printer will print a some stuff. Don't worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which explains why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open Printer's cover cover (not the scanner cover) and remove the cartridges. With Printer still open, disconnect the power outlet.
9) Close the lid and turn on The printer.
10) Refill cartridges and place them back in their nice little abode in The printer.
Sep 16, 2010 | Computers & Internet
MP970 Photo All-In-One InkJet Printer: The printer head alignment is off. I have tried to...
  1. Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Rear Tray or Cassette.
  2. Open the Paper Output Tray, and then open the Output Tray Extension. (1) Put your finger in the center of the top of the Paper Output Tray and open it gently. (2) Open the Output Tray Extension.
  3. Press the Paper Feed Switch to select the paper source where you have loaded paper.
  4. Print the print head alignment pattern. (A) Press the HOME button. (B) Select Settings , then press the OK button. (C) Select Maintenance , then press the OK button. (D) Select Manual head align , then press the OK button. (E) Select Yes , then press the OK button. (F) When " Did the patterns print correctly? " is displayed, confirm that the pattern is printed correctly, select Yes , then press the OK button.The input screen for the head position adjustment values is displayed.
  5. Note:If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
  6. Look at the first printout, and then adjust the print head position. (A) Check the printed patterns, and use the or button to input the number of the pattern in column A that has the least noticeable vertical streaks. (B) Repeat the same procedure until you finish i nputting the pattern number for columns B to F, then press the OK button. (C) Confirm the displayed message and press the OK button.
  7. Note: If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
  8. Look at the second printout, and then adjust the print head position. (A) Check the printed patterns, and use the or button to input the number of the pattern in column G that has the least noticeable vertical streaks. (B) Repeat the same procedure until you finish inputting the pattern number for columns H to K, then press the OK button. For column K, the best pattern will be smooth and have no streaks in the border indicated by the arrow. (C) Confirm the displayed message and press the OK button.
  9. Look at the third printout, and then adjust the print head position. Check the printed patterns, and use the or button to input the number of the pattern in columns L and M that has the least noticeable horizontal streaks, then press the OK button.
Source
May 16, 2010 | Canon MP970 Photo All-In-One InkJet...
My printer crumbles the paper
i tried everything. i notice alot of complaints with canon. mine crumbles the paper too not even a year old. i WILL NEVER BUY ANOTHER CANON ANYTHING
Sep 27, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I have a brother hl-5250dn with an extra tray for legal size paper. I have a problem printing loan documents sent via swiftview or elynx. I can only print on letter pages or legal pages but not both and...
Sounds like your secratery's printer is set to ignore paper mismatch errors. It depends on the setting you have in your driver. Can you set your driver on your printer to ignore paper mismatch errors. If not when your printer errors, just try hitting the go button and it should print the document any way.
Sep 07, 2009 | Brother HL 5250DN Laser Printer
Paper jammed error notice appears but there is no paper jammed
let print head cool first now disconnect and reconnect the device>>>press on /off remove the paper slowly and softly and reset the cartridge these are best probable step to fix such problem
May 12, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon Pixma MP830 printing red/orange hue on glossy photo paper
are you using geniune canon glossy paper??? it is designed for the printers and really is the best for the machines
Apr 08, 2009 | Canon PIXMA MP780 All-In-One InkJet...
100 people viewed this question
jasbo
jasbo
