Question about Proform Sport 1000 Folding Treadmill PFTL91205 - !
My treadmill is sticking when I am walking causing me to fall forward. What is going on with the treadmill?
  • 218 Answers
SOURCE: treadmill sticks on my Epic Treadmill
replace the drive belt
Posted on Aug 13, 2010
roadtech7
  • 293 Answers
SOURCE: Describe your proform 765 ekg
The problem you have is one of two things. 1 you have a loose walk belt, or 2 you have a spun front drive pully.
You need to remove the front cover to be able to observe the drive belt as it is turning on the drive pully( on the LH side of the front roller) try to stop the walk belt while traveling at speed setting 3. Hang on to the side handles, if the drive belt runs as normal, watch the front roller it will be slipping. If this happens you will need to replace the front roller.
Posted on Nov 05, 2010
  • 1702 Answers
SOURCE: when walking on treadmill its
Hi, You need to do some lubrication on moving parts such as bearings, motor (use a light oil).
Some disassemble is required. Good luck
Posted on Jul 13, 2011
FirsLonewolf
  • 186 Answers
SOURCE: Is there a weight limit
not sure if there is a weight limit but did you check the belt tension.
front or rear roller should have an adjustment screw on both sides to tighten the belt. this could be the solution to your problem
Posted on Aug 24, 2011
ercupa190
  • 12223 Answers
SOURCE: The belt on the Epic
Dear Sir:
I will try to help you:
1.
Slow Walking Belt
o 1
Check that the surge protector meets the specifications listed in the manual.
o 2
Remove the key from the console.
o 3
Unplug the power cord.
o 4
Turn rear roller bolts 1/4 turn counterclockwise using an Allen wrench.
o 5
Keeping the walking belt centered, you should be able to lift each edge of the belt 2 to 3 inches.
o 6
Plug the power cord back into the surge protector.
o 7
Reinsert the key into the console.
o 8
Repeat the process if, after the treadmill has run a few minutes, the walking belt is not properly tightened.
2. Walking Belt Slips
o 1
Remove the console key.
o 2
o 3
Follow the same steps used for a slow walking belt.
See the videos:
http://www.youtube.com/watch?v=38w4PkiWIBY&feature=related
http://www.youtube.com/watch?v=yX_0vRPdMfU&feature=related
http://www.youtube.com/watch?v=E5aWisfhT3Q&feature=related
http://www.youtube.com/watch?v=wjrVjYe2LYQ&feature=related
With this you will fix it.
If you need further assistance, please reach me, sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Posted on Oct 24, 2011
On full speed belt sticks causing me to jolt forward. My roger black gold treadmill
Of you wish to get some details about treadmill repair then check the following link
http://electro-medical.blogspot.com/
Sep 20, 2016 | Exercise & Fitness
I have tried every recommendation as to how to unlock my Nordic Track 1000 from the storage position and nothing works, I am facing the back of the belt of the Nordic Track and pushing forward with my...
Corrine, That knob is spring loaded. You need to pull it out...Hard. Before you do this ,support the walk board/deck frame. It will be free to fall down after hou pull the storage/locking pin out. You need to pull the pin out and hold it until the walk board clears the upright. Then be carfull and lower the walk board/deck/belt.
Hope this helps.
Matt
Dec 08, 2011 | Nordic Track Nordictrack Exp 1000...
Belt on treadmill is moving towards the right and bunching up
you need to adjust the travel of belt. to do this you need a allen wrench that came with it. if you have it run treadmill at slow speed,go to the rear right at the right end cap there is a hole, use the allen wrench and unscrew slowly while watching the belt until returns to the middle. if it slips when walking go back to rear and adjust by screwing in one turn on each side until belt wont slip.
Feb 09, 2011 | Proform 380 Treadmill Walking Belt
While walking on my tredmill the belt jerks
Sometimes mine can "****" when my body weight on the front foot slightly slips the belt forward before I put full pressure on it and it slides back into normal walking. Don't know what your natural walking style is like, but this tends to happen when I am "heavy" on my heel with that forward step. Could also be that your belt needs lubricating (buy from sports stores).
Nov 27, 2010 | RTO Image 15.0R Treadmill Walking Belt
Describe your proform 765 ekg sticking Problem When I am running on the treadmill, the belt sticks/stops and I about fall off. It happens just for a second, but it causes me to lose my balance. Someone...
Nov 05, 2010 | Proform 760 CrossTrainer Treadmill
My treadmill belt keeps slipping, i cannot run on it without feeling like i'm going to fall down.
Your unit has likely one of 2 problems. It most likely needs a new motor belt installed. The micro V belt can be ordered from ICON for about $20. The other possibility is the walking belt tension is too loose. Lift up the edge of the walking belt firmly in the middle and you should be 2-3 inches above the walking board. Don't overtighten the rear roller screws to increase the tension beacause it will make the motor work harder and if it is a worn motor belt, the extra tightening won't make much of a difference.
Oct 02, 2010 | Proform 650 Crosstrainer Treadmill
The belt on the treadmill is sticking when i get on it but not if its just running on its own.
UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 inches above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened
Apr 11, 2010 | Nordic Track /proform Treadmill...
When i walk on it the belt sticks in places and i cant let go of the rails
If your belt is sticking there are 2 possible causes. Either the walking belt itself is loose or the drive belt. The way to check is look at the front roller when you step on the walking belt. If the walking belt stops, but the front roller continues to spin, the walking belt is loose and needs tightened. If the front roller stops when you step on the walking belt, then the drive belt needs tightened or replaced. The walking belt can be tightened fairly easily, there are bolts at the rear of the machine that adjust the rear roller. The drive belt is a little more involved and requires removing the motor hood. Check to see what the front roller is doing and I'll help you further.
Mar 10, 2010 | Proform Exercise & Fitness
Proform Sport 1000 Folding Treadmill PFTL91205 - ! Logo
63 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
