Motherboard biosversion VA84510A.86A.0008.PO3 is outdated. how to update. Memory Clock has expired. to be updated.
4 Suggested Answers
R_K__KEYAN
  • 9 Answers
SOURCE: Update my Intel D845GVSR Bios Version to VA84510A.86A.0056.P20, then my USB driver is not working at all.
1.Change the BIOS Jummper pin to Recovery Mode ( without Jummper pin )
2.Start the computer,Press F2 go to CMOS Setup Screen
3.You See USB Setting Options then Change the Correct Settings & Press F10 Save Changes.
4.Shutdown the PC.Change BIOS Jummper pin to Normal Mode
5.Agian boot the PC go to CMOS settings
6.set SETUP DEFAULTS Settings & Press F10 Save Changes.
7.This Solution 101% Working.I am alreday See This Same Problem & Fixit.
Best Of Luck.
Posted on Sep 29, 2008
I followed the suggestion of changing the BIOS configuration to the recovery mode, however one thing was missing - it required a startup disk and I didn't have one. I then changed the BIOS configuration to the config (pins 2 & 3) mode, booted up and went to the BIOS/CMOS setup and a new menu tab appeared called "maintenance". I went to the advance tab and selected USB configuration and, instead of a blank screen, there appeared a selection for USB support and it showed disabled. I changed the setting to enabled and three more lines of information regarding USB came up, but required not further changes. I went to F10 and saved and exited and I now have me USB capability back.
Posted on Apr 01, 2009
  • 13433 Answers
SOURCE: Dear Sir I want to upgrade my hard disk to SATA 320 GB or SATA 250 GB. But my Motherboard is Intel Corporation D845GVSR and Bios Version is VA84510A.86A.0030.0402160229 System Bus Speed is 533 MHz Sys
No, don't use a convertor. Please buy a SATA PCI addon card.
like this http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=pci+sata&x=0&y=0
the above card will do alot better job than a converter, if you don't have sata and you don't have room for the card then its best that you buy IDE drive which 250GB or more.
thanks and good luck.
Ekse
Posted on May 13, 2009
My kaspersky was snoozed how can i unsnooze it
It may many cause but mostly cause for snoozing here:
1.Update your kaspersky,may be database would be outdated.
2.Scan your computer and remove unwanted threats.
3.May be it expired so renew it.
Mar 02, 2016 | Audio Players & Recorders
Audiodriver not instal
Well you didn't hear this from me,but download driverguide pro from demonoid.com. Other solution is to try to find the driver on Asus's website,good luck with that. I tried for ya.
Jun 23, 2009 | ASUS P5S800-VM Motherboard
Ekse
May 13, 2009 | Intel D845GVSR Motherboard
INTEL D845gvsr motherboard not installing audio driver properly
hi,
u must rbuy a new moter board to solve your prolem
coz ihave that problem too
now my pc works good after i replace my board
have a nice day!!!!!
Apr 06, 2009 | Intel D845GVSR Motherboard
Memory Bank 1 Not Installed
remove the cmos battery for about and hour make sure that the power is unplugged from the pc then reset your bios options
if that fails , use the new ram by itself first if all ok
then use the old ram in the second slot..
hope this helps
Dec 31, 2008 | Intel D845GVSR Motherboard
Even i experienced the same problem after updating BIOS....
There is a simple solution for it..... Just reboot the system and enter to Bios setup by tapping Del key
Press F9 key and set it to default settings... Just save and exit.... USB Ports works fine.....
Mar 17, 2008 | Computers & Internet
Mar 10, 2008 | Intel D845GVSR Motherboard
Problem with intel d845gvsr display driver
download the driver from these websites and uninstall the old1 and try installing new 1..
bios-and-system-update.free-driver-download.com/Intel/19970/Intel-D845EPI-D845GLVA-D845GVSR-Express-BIOS
www.opendrivers.com/driver/230315/intel-d845glva-d845epi-d845gvsr-express-bios-va84510a.86a.0052.p19-free
www.nodevice.com/driver/company/INTEL.html
www.techtree.com/.../jsp/list.jsp?list=asktt_allcomments_list_notsignedin&q=1&answer=N&cat_id=41
if the same problem persists then there may be problem with operating system just reinstall it...
may be due virus attack some system files have became unstable so try reinstalling os...
and also after reinstalling just install some good antivirus............
Feb 10, 2008 | Intel D845GVSR Motherboard
Computers & Internet Logo
105 people viewed this question
David Payne
David Payne
