Question about Timex 2J611 Watch
I bought the self adjustable bracelet watch but do not know how to adjust it to make it tighter on the wrist
  • 831 Answers
Self-adjusting bands usually feature easy to remove links that simply snap out. They usually look just like the main clasp or blend in with the band. Simply locate these links and undo the closures to remove or add them.
Posted on Aug 20, 2010
Adjust the bracelet
There are tiny pins either side of the wrist band next to the clasp. Remove these pins and you can take out up to two links (and a half link on some models.)
A jeweller could do it, needs a special tool to tap them out and put them back
Nov 03, 2013 | Rolex Oyster Perpetual Submariner Date...
Brasalet unlocks all the time by inself ,I need new brasalet or lock replaced, how I get the parts.
mcdevito75 here, Many times the Bracelet clasp can be adjusted. Look for a small watch repair shop in your area. approx, fix price, $10.00--$20.00 chaeper than new, if bracelet can be adjusted.
Jul 18, 2010 | Wittnauer 12E08 Wrist Watch
I bought a Michael Kors watch and need HELP!
Have you thought of changing the band to a leather one?
This would allow you to make holes in the best place to give the correct length for you.
Alternatively you might be able to get an expanding metal type which would solve the problem. This type can also be adjusted for length.
Mar 19, 2010 | Watches
Adjust-a-Casio-S-1087DY-Watch-Band
On most brands, there are pins that form hinges for the links of strap. You need to push them out to remove links. Usually you would find arrows marked from inside of the metal bracelet which show you the direction in which to remove the pins. You can remove it if you have a small watch maker's screwdriver but you have to be careful. or get one of these ..
http://www.amazon.co.uk/Watch-bracelet-link-adjuster-remover/dp/B001ZKIL2S/ref=sr_1_1?ie=UTF8&s=watch&qid=1254695541&sr=8-1
which should help you to remove the link pins safely without scratching.
Aug 31, 2009 | Casio Edifice EFA110D-1AV Wrist Watch
Seiko kinetic stainless steel bracelet has snapped pin (both snapped ends still visible and flush in last flared bracelet link between watch body and start of bracelet.) How do I remove snapped pin ends...
There are several easy to follow tutorials on u-tube. It's easier for you to look at these than for me to describe how it is done. Just search "adjusting steel watch straps"
Sep 23, 2017 | Omega Seamaster 2541.80 Wrist Watch
Self-adjustable bracelet watch
If you are ready to take that risk, here is how you can do that.
First- get watch on your wrist and by squeezing the bracelet count how many links you have to take out to make it tight enough (say 4 for example).
Check the sides of a bracelet. You will notice that the upper bands metal is flipped over the bracelets side. Take tweezers or small pliers and unbend one of these. Try to do as little damage as possible.
When it's done, you will see two metal staples inserted into the bracelet. You have to pull them out. While pulling out, remember how they where positioned, as you will need to drive them back in the same manner.
So, when the staples are out, do the same on the other side of bracelet. Now you have bracelet in two halves.
Count off 4 links and undo the staples in joint of 4th and 5th link in the same manner as previously.
When links are out, take the staples and drive them back into the bracelet koining two ends together. You have to do that exactly the same way and position as you took them out.
When all staples are in place, bend the metal back over to the bracelet sides.
BE WARNED: as you gonna do it first time, be ready that you can damage the bracelet or can not put it back together.
Good luck.
Rate me, please.
Mar 19, 2009 | Timex 2J611 Watch
Fossil watch me1001 bracelet adjustment
I took mine to a watch store, and had them remove a link.
Dec 08, 2007 | Watches
Remove few pieces in my Casio AW-SD bracelet
What u can do is call casio tech support and give them ur email address and they can send you the instructions to adjust your band.
Jun 07, 2007 | Casio AWS90D-2AV Wrist Watch
Timex 2J611 Watch Logo
1,943 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
