Question about Whirlpool Dryers
My whirlpool dryermodel#lew0050pq2 when turned on the drum rotates but blower does not engage ,i looked at the capacitor and it looked like it was oozing ,the motor moves slightly, is this aproblem with the capacitor or do i need anew motor drive
  • Whirlpool Master
  • 8,220 Answers
If it is oozing yeppersmy whirlpool dryermodel#lew0050pq2 when turned - 80e8d55.jpg
Posted on Aug 20, 2010
  • Dan Webster
    Dan Webster Aug 20, 2010
    These newer caps ain't got PCBs in em. They don't hold up well as the older one did. My opinion till I find out better. LOL
How do I fix my whirlpool cabrio dryer model wed6200swi so that it stps the noisy squealing sound when it runs?
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
Mar 04, 2015 | Whirlpool Dryers
Kenmore dryer won't come on but make a low buzzing
Motor is not running. Could be bad motor (or motor capacitor, if one), or the blower, belt, drum are not free to rotate. With the power off, reach in to turn the blower wheel, motor, belt, or drum to make sure they are not bound. If free to rotate, investigate the motor.
Oct 17, 2014 | Dryers
Whirlpool lew0050pq2 electric dryer
very good chance that is it
Apr 06, 2014 | Whirlpool Dryers
Whirlpool dryer model #wed7500v the blower motor stops working and the capicitor keeps needing relplaced?
Your capacitor is a "starter".
It gives the motor a "shot" of extra energy to start only, it is not for running.
Here are a couple things.
I have to wonder if either the motor is a problem, or if the dryer has a problem elsewhere.
The motor could be overheating from lint.
Blow it out with a high pressure air hose.
Perhaps the motor itself is bad.
Perhaps the dryer drum is not rotating freely which would demand more power from the motor.
The dryer drum should turn really freely all the time.
Motors for dryers are much stronger than they need to be to turn the drum.
Be blessed and you look further.
Jan 27, 2013 | Dryers
Dryer has electricity but the drum will not spin
Hello there:
If your dryer doesn't tumble, check these:
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Sep 27, 2010 | Whirlpool LER4634J Electric Dryer
I have an older whirlpool dryer when you turn it on it hums but doesn't spin.
Three possibles here:
1) The motor is running but the belt is broken not allowing the drum to turn.
Try to turn the drum by hand and see if it rotates very freely and takes a while to stop. if so, your belt is broken. If it feels like there is a good deal of resistance on the drum and stops as soon as you let go, your belt is functional.
2) Something is stuck (probably in the blower wheel) not allowing the motor to start up. If as you attempted to rotate the drum in #1 above it did not turn at all, this and #3 below are possible.
You'll need to disassemble the unit to get to the blower wheel and verify it's clear.
3) Motor is bad (common with older well used dryers) and needs to be replaced. This may also cause the drum to be locked as above.
That's all I can think of that will cause the motor humming but not having the drum to spin.
Nov 01, 2009 | Whirlpool Dryers
Whirlpool dryer will not spin
Since your dryer is "new" it is under warranty. I will explain the possible reasons why it will not spin. Then you can decide whether to make the warranty call or not.
Belt
Motor
Door switch
Click here for a belt installation diagram.
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
May 21, 2009 | Dryers
Drum will not rotate in LEW0050p Dryer
hello is the door making the switch if thats ok check wires see if any are loose if thats ok .at the bottom of the machine next to the motor theres a part callled a capacitor its got 2 wires coming off it this can stop the dryer rotating i hope this help
Jan 28, 2009 | Whirlpool LEW0050P Electric Dryer
Dryer not turning. belt is good
  • Remove the belt.
Dec 17, 2008 | Whirlpool Dryers
Dryers Logo
132 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
