Question about Proscan 40LD45Q TV
How do I hook up an old A/V Receiver to TV when only audio out is headphone jack.
  • 490 Answers
You can find a cable at your local hardware or electronics store that will solve that in one step. It has either a mini din or full sized headphone plug on one end and a pair of red and white RCA type plugs on other end. It can be really fun to have your TV audio output through your old, tough receiver. Good luck:)
Posted on Aug 20, 2010
My remote is working fine with other models of the TV which am using, but failed to work in mine...could u pls help me out in finding the cause for this and if so how can I get rid of that prob.
Thanks in Advance.
Posted on Mar 23, 2011
    President:
  • 1,961 Answers
There is a connector adapter available in an electronic supply store you can use the adapter from babyplug (earphone plug) stereo type to RCA plug there is a ready made cord for that or you can have it aseembled by an electronic technician..good luck thanks for asking!pls help me by rating my solution..
I want to connect a Sony Wireless headphone to the receiver w/o disabling the speakers.
Normally you shuould connect the headphone inserting the plug in receiver's jjack. If you've gou no jack, you can't use the headphone
Jun 02, 2015 | Onkyo TX-DS474 Receiver
Pioneer VSX-456 headphone jack problem
No the headphone jack doesn't disable the speakers. There are two switches in the lower middle of the receiver that are labeled speaker A and B. Pushing one of these should disconnect the speakers from the receiver.
Feb 16, 2014 | Audio Players & Recorders
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
Sennheiser 126 connect to tv
You should be able to hook the tv to the cable box the cable box should have your A/V jacks. If so unplug the PS3 plug in your receiver to the cable box and run the PS3 through the receiver. Also check the side of the tv for HDMI inputs if you have HMDI you can go to Radio Shack and get a converter to go from HDMI into A/V
Nov 07, 2013 | Sennheiser Audio Players & Recorders
I have recently purchased SONY MDR-DS6500 wireless headphones. Wireless transmitter have two inputs (1) Audio In : Optical Digital Input (2) Analog Stereo Input mini jack. I would like to hook it up to my...
Its all about the quality of the converter in the Headphone unit.
If the quality is lower than the quality of the converter in the receiver, then using the head jack is a better idea. Since there is more room, power, and money going into the receiver, it may be better
I do not believe that there is a cheap way to connect to the headphone with optical audio
The only way to be sure though, is to test it and see. Connect your computer to the receiver with HDMI, play audio through, and compare it to when you just connect your computer to the headphones, via optical audio
Oct 21, 2013 | Sony Audio Players & Recorders
Hp input cycles on and off and there's no volume on my denon aver 1610 receiver
Headphone jack is bad. Two ways to fix: Either replace the headphone jack, or if you don't plan on using the headphones, unplug the cable going to the headphone jack pcb. There may be two cable on that board, unplug the one that is closest to the front panel. This will affect nothing else except disabling the headphone jack.
Mar 05, 2013 | Denon Audio Players & Recorders
I have a set of T 912 wireless headphones. I am unable to set them up on the TV. I am using the white and red cables from the base station to the TV audio red and white. Do you have any instructions on...
The audio jacks on the TV are most likely inputs, not outputs. They're meant to take the audio signal from something like a DVD player, along with the video input on another jack, so you can play it through the TV. There isn't an audio signal coming out from those jacks, and if you connect your headphone transmitter to them all you'll get is silence. Almost all sets now have at least one set of AV inputs, but most don't give you outputs. The manufacturers figure the TV is just a display device, and not a signal source.
Unfortunately, there isn't any easy way to connect your wireless headphones if the TV doesn't have audio output jacks or a headphone connector. If you're comfortable with soldering and willing to do some modification to your TV, it's possible to add a headphone jack. Most people don't want to start tinkering with their sets, though.
If you're using your TV on a cable system without a converter box and the cable hooks right to the set, you're out of luck unless you're willing to add a headphone jack as I mentioned before. But if you have a cable converter box, or you're using a satellite receiver or other set-top box, you can use your headphones with those. These devices typically have direct audio and video outputs available on the rear panel, and you can use that audio output to feed the headphone transmitter.
What most people do these days is use a home theater receiver along with the TV. All sources (the cable box, DVD player, video game console, audio CD player, etc.) connect to the receiver, and the receiver's audio and video outputs go to the corresponding input jacks on the TV. This way, the TV is just the end of the line. The receiver also would provide an output for the wireless headphone transmitter. This system offers some advantages. You'll be able to connect the proper speakers to enjoy surround sound when not using headphones. And you'll be able to use your wireless headphones with the tuner and audio sources like music CDs when not watching TV.
Aug 14, 2011 | Audio Players & Recorders
Receiver compatible with tv
yes digital suround sound is optical spdif k like coxial digital if it dont have analog outs or does it have headphone jack in front run a eth in mini jack to rca offf that to video 1 of sterio ok
Feb 10, 2008 | Televison & Video
Stopped consistently producing sound
Try plugging and unplugging a pair of headphones. The headphone jack in these receivers are flaky and sometimes think there are headphones hooked up even when there isn't. Full repair would require the headphone jack to be replaced. If you don't use headphones at all, you can take the top cover off and unplug the cable going to the headphone jack board and eliminate the problem that was as well.
Mar 01, 2017 | Denon AVR-1603 Receiver
Proscan 40LD45Q TV Logo
120 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
