Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
I have a Briggs and Stratton 22 hp els 725 vertical v-twin engine on a craftsman gt 5000 50# mower. has worked fine all summer. now starts great. runs great at idle. If I throtle up fast or engage the blades (put it under some kind of a load) the engine bogs down and a dark black, rich smelling smoke comes out of the exaust. If I engage the blades at a lower rpm then ramp up thee rpms the engine sounds fine until I go up a hill then engine bogs again. Help
  • 1 more comment
  • bbrooks67676 Aug 20, 2010
    I replaced both spark plugs prior the previous post. I checked for spark, and both produce spark just fine. When I pull the wire off of one spark plug at a time the engine starts and runs just fine on one cylinder. I am wondering if it could be in the governor.
    please see additional comment
  • bbrooks67676 Aug 22, 2010
    I have checked that I have spark on both cylinders at the same time. sparks looks good. I took the carb off sprayed carb cleaner in the ports leading to the bowl as suggested. sprayed carb cleaner through the seat and sprayed off the needle. the carb looked clean but i did it any way. the problem does not seem like it is not not getting enough fuel. I put it all back together and am having the same problem. I cut about 4 acres of grass and have two four wheelers. My gas never "sits" for more than a week or two. and my 4 wheelers are not having any problems. the lawn mower runs at high rpms with thee blades running if I slowly ramp up the throtle. It is when I go up a hill it goes in to this phase where the it starts to puff out black smoke and sounds like i am trying to pull a two ton block behind the mower. It will not stop even if I stop moving forward and disengage the blades (take the load off) until I lower the throtle to half. after the mower "regains composure" I can do it all over again. It seems like the engine is flooding itself out to me.
  • 760 Answers
Sounds like you're running on only one cylinder. Black smoke= unburned fuel. You can test by unplugging one sparkplug at a time. If you try to start it with one off and it won't start, try the other one. If one makes no difference, you've found the one that is the trouble. If you find this is the case test spark on both plugs. If you're getting spark on both, then check valves. You may have either a stuck vavle, or the rocker arm might have come loose.
Posted on Aug 20, 2010
What is the air gap between the flywheel and coil on 22 hp
.030 (thirty thousands). I use brass shim material as it is not magnetic.
Jul 19, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Why is my 22 hp 42 inch deck craftsman rider mower oil leaking somewhere in th fron of the engine
i need more info where is the leak near also check oil level if its to full it will blow by to the intake
Jul 29, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Low power when under load lt1024 cub cadet 24 hp els 725 ohv
always check spark and compression first spark needs to be blue and compression should be 120 but will barely run on 80psi if both are fine rebuild and acid dip carb also check muffler for carbon build up clogged muffler means no power
May 16, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Have a 22 ohv B&S els 725 v twin want recharge a new battery
If you want to recharge a "new" battery you should use a trickle charger and leave it on over night. Remove the ground side wire from the battery before charging. let us know
Sep 22, 2010 | Briggs & Stratton Briggs Stratton Intek V...
My friend has a 18.5 briggs stratton v- twin that
The engine fuel needs to be primed into the carburator and the choke set.
Sep 17, 2009 | Briggs & Stratton Briggs Stratton Intek V...
I craftsman 20 hp twin mower quits after waarm up
SOUNDS LIKE A FUEL PROBLEM OR DIRT WHAT OTHER SYMPTONS DOES IT HAVE
Jul 08, 2009 | Briggs & Stratton Briggs Stratton Intek V...
My Biggs and stratton446777 rockers dont move as it spins over
you my have a broken rod pull spark plugs out and see if pistons are moving,if so check for bent push rods,if push rods aren't bent then you may have bad cam
Apr 28, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
1,462 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
