Question about ASUS P5P800-VM Motherboard
LAN problem between Belkin modem and P5P800-VM MoBo
It could well be something I've done or the new connection (ADSL2+) but, the Belkin connects to my laptop via wireless or LAN no problems.
The P5P800-VM is another story however.
It's running XP and has the NIC on the MoBo (there are no lights near the socket working)
XP is saying the driver is installed and OK.
I've tried different CAT5 cables including the one that works with the laptop.
I've tried all four ports on the back of the modem. (each one works with the laptop)
I guess my question's are "Could XP be lying and the NIC is no good?" and "can you suggest anymore test's or actions I can take to resolve this?"
Best regards,
Robert.
Click Start>RUN>type CMD click OK>type ipconfig on the command prompt if it says disconnected try changing the ethernet cable.
Thanks marked, I've already tried some good ethernet cables and no IP showing up in the Modem setup screens. (it only shows the laptop IP address)
I have got online again by adding a new LAN card to the PC while I keep trying to locate a problem with the on board LAN. Tho it looks pretty much like this is un repairable
Posted on May 10, 2008
  • ASUS Master
  • 6,487 Answers
When you connect the pc to the router does the port number where that pc is connected is there any light on it? if there is check the IP address of the pc.
If you already receive a IP address that's good then try getting online.
Posted on May 09, 2008
Belkin N1 Wireless ADSL2 Model # F5D8631-4 Router router default address (192.168.2.1) is not opening, even i have reset the router
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Dec 09, 2012 | Belkin Computers & Internet
Asus p5p800-vm MOBO, when i power on the CPU the monitor is no display and the red light who's booting the HD is powered on.
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
hope this helps
Jun 10, 2011 | ASUS P5P800-VM Motherboard
P5p800-vm how to disable the onboard vga?
Put the new video card in, connect the monitor to it, boot in the BIOS and in there set the video card to Auto.
Sep 27, 2010 | ASUS P5P800-VM Motherboard
Cannot connect internet as it shows internet is offline
Always check your LAN cable between your modem and the router and try a new cable. Login the make certain your router is configured correctly to connect to your mode.
Jul 13, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
I have a comtrend ADSL2+Ethernet Router hooked to my desktop Pc and a G-Wireless Router made by Belkin.According to the tech I should be able to connect these two to use my Laptops, but any way I've tried...
You dont need a Belkin Disk to set up - this can be done manually you can get a manual from this site http://en-us-support.belkin.com/app/product/list/q/routers/ select G in the first dropdown and then your model - theres two to choose from and then then the version
you have a choice - you could change the comtrend router to just use the modem - bridged mode - they have a few different routers see here http://www.comtrend.com/links/i$residential-adsl2-modem-router$product.htm so not sure which one you have if you can bridge to just use the modem then connect tothe Belkin and all PCs should connect to the Belkin
OR you can connect two routers together Leave the comtrend router set as it is -
Set the IP address of belkin router to same subnet as the comtrend. Depending on the DHCP range of the comtrend router - set the IP outside this range - so if comtrend is set to give an ip of 192.168.0.2 to 192.168.0.100 - set the belkin to 192.168.0.254 Disable the DHCP in the belkin.
Connect the comtrend LAN to one of the Belkin LAN ports - you may need to use a crossover cable. On the belkin the WAN port will be left unconnected
Mar 20, 2010 | Belkin (F5D7231-4) Wireless Router
ASUS P5RD2-VM MOTHER BOARD - lan port is not working not showing led on lan port jpshah j5p10shah65@yahoo.com
You have to install lan card driver to show your lan connection.
Check the cable is connected both end properly and other end pc is connected modem or switch is turned on.
Aug 26, 2008 | ASUS P5RD2-VM Motherboard
Trying to hook up belkin wireless router to cable modem and don't know how the hook-up should be
If you have your pc connected directly to your broadband modem through the ETH/LAN port on your pc then disconnect it from that port on your PC.
Then connect the same cable to your Belkin Routers Internet/WAN port. Then take the extra cable that came with the Belkin router and connect it to 1 of the 4 lan ports on the Belkin router. Then connect the other end to your PC in the LAN port.
After that, restart your PC and everything should be fine.
Thanks
Aug 09, 2008 | Belkin Computers & Internet
Wont connect to the internet
Try this, assuming you're using Internet Explorer: Go to Tools > Internet Options and select the Connections tab. Does it show your old dial-up connection in the list? If so highlight it and click on REMOVE. Close IE and re-open it. It should now use the Belkin LAN connection.
Aug 18, 2007 | Belkin (F5D7231UK4) Wireless Router
ASUS P5P800-VM Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
