Question about Bosch Evolution Pro-Style 700 HDS7282U Stainless Steel Kitchen Range
The outer window of the range door shattered, can I replace it or I do I have the whole door.
Oven door glass shattered
Replacement is likely not to be easy or cheap, but necessary.
Jan 10, 2014 | Tecnik Ovens
My outer glass shattered on lower oven
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Dec 11, 2010 | Ovens
The outer glass on the dooor has shattered, where
Try this link. Price is $92.00. I have replaced some of these and they are not hard to replace.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=250474&diagram_id=98440#d98440
Jan 05, 2010 | Whirlpool GR399LXHS Electric Kitchen Range
Kitchen Aid microwave door -- outer glass
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
Jun 19, 2009 | KitchenAid Architect Series KEMC308KSS...
Glass is shattered to to replace
To replace the door glass do the following:
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Remove the inner screws. Keep all set of screws ordered, and take noteof the order you remove them. You will follow reverse order inreassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
dd5ebd3.gifclick here
Inner Door Glass
May 15, 2009 | Maytag MER5765RAW / MER5765RAQ /...
Outer oven window shattered
sure should be replacable, youo can cll the manufacture for a replacemnt glass, most only held in by a feww screws, cant see it being the end all for you oven
Dec 22, 2008 | Kitchen Ranges
Main oven door outer glass panel shattered
I doubt you will get it cheaper any where, Zanussi is a bit of a closed shop.
If you can let me have the exact model no and the er number, I might be able to help you.
As for the reason it shattered, there are numerous reasons for this to happen, too many to go into, but it is a very common problem with cookers..
They do just go without any warning.
A cold kitchen could indeed be a factor, a badly fitting door is another factor, i could go on and on and on!!!!!
There is no one thing it can be put down to.
Plz let let me have the details I ask, and I will see what I can come up with.
Dec 12, 2008 | Ovens
Oven door outer glass shattered
will need a model number to tell you the correct price ... most will have to replace the door... you can also give sears a call .. if you gripe loud ... they may replace it for you...
Sep 28, 2008 | Ovens
Bosch Evolution Pro-Style 700 HDS7282U Stainless Steel Kitchen Range Logo
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
