Question about Dishwashers
Will not drain water out of dishwasher. Even tried to cancel and drain and nothing works. What could be the problem?
  • 128 Answers
Sounds like the pump underneath is no good or clogged
Posted on Aug 20, 2010
Sink backed up went in dishwasher. Then it drain in sink. Fixed sink stopped up but washer keeps draining but nothing in drain
Your post is a little confusing but I'll try my best.
First, it sounds like you fixed the sink problem and now have a dishwasher problem related to the backup.
I would take the drain line off both the sink and the dishwasher and clear anything that got stuck in there while fixing the main sink drain. It could have had something plugged into it by using a plunger on the sink.
If you have any standing water in the dishwasher, pushing the cancel button should activate the water pump and you should see the water drain into the insinkerator, etc whilst hearing the pump. If you hear the pump and see no water draining but still have water in the dishwasher, you have a clogged line. If you don't hear the pump, your pump might not be working or the cancel does not activate the pump.
Jan 17, 2018 | Dishwashers
Dishwasher not draining
The problem is a clog in the hose or the check valve from the drain pump. I will post back shortly with directions to unclog it.
Thanks/Mike
Jan 13, 2008 | Whirlpool 24 in. DU930PWP Built-in...
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
Dishwasher was not draining. I cleaned out everything and now it wont start
I have the same problem with another Kitchenaid model. I've had better results at keeping the water drained by running two back to back water saver cycles than running a full pots and pans cycle.
Nov 06, 2017 | KitchenAid 24 in. KUDS01FLSS Built-In...
Kitchenaid DW KUDS30FXSS Cycle starts then I hear a solenoid actuate 4 times then unit goes into cancel drain cycle
Here's a link for the repair manual for your dishwasher:
http://www.appliancerepair.net/kitchenaid-dishwasher-repair.html
Concentration should be on Chapter 2 subsection 2-3 "No Fill"
Then go to Chapter 6; subsections 6-2, 6-3, 6-3a, 6-3b, 6-3c, and 6-3h for testing procedures on relays, actuator valves, etc.
Nov 30, 2013 | KitchenAid KUDS30FXSS Builtin Dishwasher
Hi, I turned on dishwasher nothing works
If its a Bosch try to drain and cancell unit.make sure the water is turned on under sink. I have seen cases where they had a problem in the building and had to turn off water under the sink and they just forgot to turn it back on.
Feb 25, 2010 | Dishwashers
Dishwasher fills up with dirty water after completing cycle.
does the drain line connect to the disposal?if so and dirty water is inside dishwasher the line must be looped under the sink so nothing can run back into the dishwasher,tie the drain line up higher than the disposal or higher than the point where it connects to the drain pipe so nothing can drain back into the washer.are you sure the water is draining out of the machine?fill it up and hit cancel drain and listen to see if you hear it draining in the sink,if the line isn't looped you could have a block in the drain line or in the pump
Feb 03, 2010 | Kenmore Dishwashers
Our PLD4375RFC2 dishwasher fills up with water but doesn't run
no their is no fuse. sound to me like your motor is not working, however
the pump should still drain out.push cancel only and unit should drain if it does then id say motor bad. you can try to take apart and check motor blade ive seen toothpics, food , other objects hold motor impeller from turning making it seem like its the motor but actually its just stuck..remove btm wash arm and filter cover thentake two or 3 small screws from a plastic cover covering motor impeller, look to see if anything is in their if so remove. warning if you see a white ball down their leave it alone reinstall and see what happens. hope this helps.
Sep 17, 2009 | Frigidaire PLD4375RFC Dishwasher
Whirlpool Dishwasher won't drain during normal cycle
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
May 18, 2009 | Dishwashers
Dishwashers Logo
49 people viewed this question
Top Dishwashers Experts
