Question about Sport & Outdoor - Others
Trying to put instant fisherman parts together?
Images of 1967 viking sport fisherman
here you go. A guy at my marina has one. I recognise that funny filled in cabin window.
1967 viking sport fisherman Google Search
Jun 05, 2017 | Sport & Outdoor - Others
Landcruiser diesel 4wd - error message on the display says "High Water Level" what does that mean?
just ignore it ,another one of these over complicated electronic controls .was it good diesel ? on the fuel filter under the bonnet underneath the nfilter should be a water drain off plug ,crack it open and let it run for a few seconds .iam wondering if in the filler tank area where their will be a drain for when you overfill it if it has a water level sensor in the tube for driving in a river ,like that aussie fisherman fella ,cannot remember his name but he kises the fish and puts them back .
Sep 27, 2016 | Toyota LandCruiser Cars & Trucks
Which battery for my wellcraft 180 Fisherman
you need to check the manual for the engine. get the cold cranking amps. I run two batteries with dual battery switch so you can isolate the batteries from each other or double up on cold days. don't get a car battery as it wont hold up to the pounding get a deep cycle marine battery
Apr 17, 2014 | Cars & Trucks
When I put the film in, it ejects the paper like normal, then instantly spews out every photo in the pack! Is there anywhere I can send it to be repaired?
No. The camera is an obsolete model and there are no spare parts. It also has an entirely clip together body which was never designed to be dismantled: the clips usually break if you try.
But there are millions of unused but perfectly functional Polaroid 600 cameras around, and as they are now all but useless (unless using the new film from The Impossible Project) they're worthless. The charity shop I work in throws away a few every week.
Just ask on your local FreeCycle or Freegle groups and you'll probably find another very quickly.
Sep 21, 2010 | Polaroid One600 Pro Instant Camera
Need a Popeil Pocket fisherman manual
For the original pocket fisherman. I believe the design has not changed. Once you do it the first time it is actually quite easy.
Two things to note. Read this whole thing first.
1) the location of the bail spring (Keeps the metal bail cover up so line does not get stuck when casting.
Note: This is important cause the metal bail cover must rise enough so that the line casts smoothly. (A complaint about this product. But when calibrated correctly it is quite good for what it is)
2) The little **** that the crank gear plastic housing will fit into (Must be on top when you put the whole bail back in. The crank shaft lip fits into that ****.You'll get it when you see it.
Remove the panel screws (2) as you did. Pop out the crank shaft (copper). **** is in top when replacing. (remember that). Remove the bail. On the top of the bail there is a screw. ( becareful and remember how the little metal bail spring in situated here. Turn upside down with metal bail cover in your palm as it conects to the bail spring). Pull off metal bail cover. The plastic line holder actually comes apart and holds a lot more line than you think. Replace line. Feed the line back up the rod. Assemble the opposite.
Feb 05, 2010 | Sport & Outdoor - Others
How do i restring my zebco real
hi,
If the bottom portion of the metal disk inside is "curvy"the line is wound by the curves.Its kinda hard to explain.Try twisting the metal "disk and pressing down lightly while turning the handle,this should put the take up parts in the right alignment.That being said,I would go spend 15 bucks at wal-mart or similar store and buy a real reel.I am a semi-professional fisherman and I dont use real expensive gear,but zebco is probably the worst equipment available.I use Okuma or Diawa...they have some low end models that are very inexpensive and work just fine.
thank you,(vote for me)
vijay
Sep 23, 2009 | Zebco Sport & Outdoor - Others
Fisherman digital music and music box (mp4 player)
If you want to you can send me an e-mail. My son has one and he loves it. He had a hard time figuring it out but he loves it now. He was just using it as a camera with FM player but now he figured out how to put songs on it. I'm not sure about video. Here is my e-mail: emerychase@excite.com. If not, good luck with that.
Apr 24, 2008 | Audio Players & Recorders
Labels are not printing correctly
Brother P-Touch tape label maker doesn't print right.
I believe it's a faulty tape. I put in a new tape, reset the machine and it's now printing fine. It wasn't the reseting - I tried that before.
Mar 11, 2008 | Brother P-Touch 2200 Thermal Printer
Sport & Outdoor - Others Logo
325 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
