Question about Denon AVR-1600 Receiver
My AVR 1600 suddenly stop working. THe front panel does not display anything and I can not turn the unit on. The standby light fickers and then goes solid but the panel no longer appears.
  • 3 Answers
SOURCE: on standby
Mine does the same thing..........
If anybody knows the problem ........please e-mail me.
StageRulz@Yahoo.com
Posted on Nov 13, 2007
SOURCE: on standby
Troubleshooting without a schematic. I found two 1 ohm resistors open in the positive 15 volt regulator circut. Located between associated power supply rectifiers and the 15 Volt Regulator. After checking for any short circuits I replaced the resistors. Ths restored operation of the unit. Owner thought the "Cable Guy" may have plugged something in wrong.
Posted on Dec 09, 2007
  • 54 Answers
SOURCE: Denon AVR-1601
This is a very common problem with denon receivers of the 2001-2-3 vintage. On almost every one, there are 4 little "surge" resistors in the power supply. These werent quite robust enough from the factory and one day would just burn open for no reason. Well, actually there is a reason, the "surge" that happens every time you power the unit up eventually weakens the resistors and then they pop. You need to take this to a denon service shop as I GUARANTEE they have seen this before. They need to check resistors in the picture, locarde above the **** rectangular connector. Resistors numbers R141, 142, 148, 149: 75f69d7.jpg These resistors when measured, should be less than 10 ohms each. If they are more, then they are blown. If they are blown, then have the shop check the channels for blown output transistors. If the outputs are OK, then these resistors should be replaced with 1 ohm 1/2 watt metal -film flameproof resistors. You might need to be prepared for a large bill, because the entire unit must come apart to replace the resistors, however, just checking them takes only about 10 minutes... Good luck and don't try this at home. Rob
Posted on Apr 08, 2008
Foxyjay
  • 13 Answers
SOURCE: Denon AVR-1508
If your amp looks like it's going to work as normal (ie the front display lights up as it should etc), but then the amp goes into protection mode when the anti-thud circuit times out, then I know what's likely to be wrong.
It's one of the power amplifier channels which has gone faulty.
I just found this out after having this problem with my AVR-1906.
I took the amp apart and de-soldered the suspected channel power transistors (centre channel in my case).....and hey-presto! it fired up as normal (obviously the centre channel would be out of service).
I have ordered the replacement transistors from Farnell (UK) at a miserly cost of around £2-£3 each.
Just waiting for them to arrive.
An alternative is, if you don't use all your channels, take the transistors from a known working but not needed channel and swap them over with the duff ones.
Hope thats of use!
Posted on Aug 16, 2008
SOURCE: Denon AVR-1705 won't power up
when i turn it on it stays on for 3-4 seconds then shuts down
Posted on Oct 16, 2008
HOW TO RESET HARMAN KARDON AVR70
Hi, Try this. Hope this helps and I have the link here to the manual.
Processor Reset
If the AVr behaves erratically after a power surge, first turn off the front-panel
main
power switch and unplug the Ac power cord for at least 3 minutes. plug the cord back
in and turn the AVr on. If this procedure doesn't help, reset the AVr's processor as
described below.
note: resetting the processor will erase all user configurations, including speaker and
level settings, and tuner presets. After a reset, reenter all of these settings from your
notes in the Appendix worksheets.
To reset the AVR's processor:
1. press the front-panel Standby/on switch to place the unit in the Standby mode (the
Standby Indicator led will turn amber).
2. press and hold the front-panel Standby and memory/folder buttons until the reSet
message appears on the front-panel message display.
3. press the memory/folder button again to reset the AVr's processor.
If the AVr does not function correctly after a processor reset, contact an authorized
harman
kardon service center for assistance.
to locate an authorized service center,
visit our web site at www.harmankardon.com.
https://www.harmanaudio.com/on/demandware.static/-/Sites-masterCatalog_Harman/default/dw409ee4c9/pdfs/AVR700NEW_OM_EN.pdf
Jul 28, 2016 | Harmon Kardon Harman / Kardon Avr 70...
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
Denon AVR-1908 won't power on
Are you getting a standby light at all? Is it flashing? Do you here a click when you plug the unit in? If the answer is no to all of these then you blew a fuse. If you do have soome sort of standby light, then your set is in protect mode. More than likely for a blown channel. If no lights, but you ar egetting a click, you could have a bad transformer. Use a DVM and see if it is open or not. Good luck
Aug 23, 2012 | Denon AVR-1908
I've just bought HK AVR 260 and have the following problem: Sometimes the sound disappears while changing the channels on my sat decoder, or while pausing and playing again on PS3, or while changing the...
This is clearly a manufacture defect right off the assembly line. From your description you have a serious intermittent problem with the AVR unit when it comes to selection and other choices and it will only get worse, I strongly suggest you return the item in favor of another.
Feb 09, 2011 | Harman Kardon AVR 2600
After turning ON the power/standby switch, the unit(receiver) display comes ON (green light) then after approx.4-5 seconds the display goes OFF and the unit defaults back to the standby mode (red light). I...
Is the red light flashing at first?
The unit may be going into protect mode. Lets hope it has done the job and the receiver has protected itself from failure.
Protect mode can result from speaker wires touching each other or the Amps2_bing.gif metal case. Check that first.
It can also be caused by unstable ohm loads if too many speakers2_bing.gif are connected to any of the outputs especially zone 2.
If you can remove all speaker wires and turn the unit back on. If it stays on, turn the volume down on the main zone and zone 2 if connected. Then reconnect speaker wires.
Nov 16, 2009 | Denon AVR-485 Receiver
When Denon AVR-5803 Is powered on, it's making a clicking sound
Some of these unit have a dimmer for the display however this doesn't sound like your problem, I sure your unit is going bad. needs repair
Jan 24, 2009 | Denon AVR-5803 Receiver
Jun 27, 2008 | Denon AVR-1705 Receiver
HK AVR 225 front display not working
thats not good power transformers in it went bad do u have it on a nice power strip or direct to wall
Jan 19, 2008 | Harman Kardon AVR 225 Receiver
Denon AVR-1600 Receiver Logo
51 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
