Question about Refrigerators
I have a Kenmore refrig Model 106.55632500 The door that pops open at the dispenser when calling for ice is not closing all the way back. Not only that, but the rubber trim around it is bad. I ordered a new door . I'm having a hard time trying to figure out on how to take the outside plastic frame off without breaking it. I believe this has to come out first in order to access the touch panel next. then get behind that to the shute assy. What is the prosedure in doing this job? Any help would be appreciated. thank you
  • 1 more comment
  • Tony Aug 21, 2010
    I understand what you're saying. Does this trim has to come off in order to access the touch panel ?
    Or does the touch panel comes out differently .?
    Thank You
  • Tony Aug 22, 2010
    I responed back before, but I Havent heard anything. If you could go over the comments I wrote and give some avenue I would appreciate it.
    Thank you
  • Tony Aug 24, 2010
    Thank You Sir.
    Now thats what I'm talking about. A person is always afraid to push or pull on plastic parts, For fear of snapping things off. Not like the old days where you have visiable screws.
    Thanks again pal.
    President:
  • 949 Answers
There are two slots on the bottom of the dispenser face (see the first image below where the orange arrows point), put a putty knife or screwdriver in those slots and push up on the tool while pulling out on the bottom of the dispenser face. You may have to hit the handle of the putty knife with your palm to release the tabs.
Once off see the second image below, the part in the top right (15) will come off with 2 screws so you can get to the door you are replacing (6) better.
Posted on Aug 22, 2010
  • 15,935 Answers
Use a plastic putty knife near a corner and pry out gently.
There are pressure clips holding the face trim in place.
Sometimes just getting your fingers behind it is enough to pop it free. If it has never been removed before - it will be a bugger.
Thanks!!
Posted on Aug 20, 2010
Kenmore mod. 106 water does not get to ice maker and when pushing despenor no rotation of ice out door
Hello Jim,
Sorry it has taken me a while toget back to ya i just got.
So on your refrigerator it very likely is the switch forthe cradlethat ya push to dispense ice and water through the door.
Unfortunitly modelnumber 106 asyou have listed is only the source number of whom your Kenmore was made by. Typically the full model# that does start with 106 willbe on a label on the ceiling or side wall of the refrig. section inside of it, reply with complete model number please and i will be able to help ya disassamble the door dispenser as well as provide you with part numbers and such
Thanks for using FixYa.Com
GENE
Sep 29, 2011 | Kenmore Refrigerators
Freezer door pops open about 1/8" when you shut refrig door
this is very normal this means that you have an extremly good seal .. causing air to push threw duct work when closing door .... try changing the levelnes of refrigerator so when door does pop open it falls back closed meaning tilt fridge front higher than back of fridge
Feb 01, 2011 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
Ice maker works but will not discharge ice thru the door.cannot hear the motor running
The motor for the ice discharge is located in the door by removing two screws that hold the panel in place. Then there is a wire harness that plugs into the motor. This many be loose or have bad connection so take it apart and look at the prongs. If that is fine. Try removing the ice bucket and try it. The ice may be frozen in the mechanism. The last thing is there is some sort of toggle or switch that prevents the ice or water from being dispensed when the door is open. It may not be working thus telling the fridge the door is open at all times and preventing electricity from going to the door ice dispenser.
Sep 30, 2010 | Kenmore 52282 / 52284 Side by Side...
Kenmore refrig model #106-56232400 ice maker
the ice maker unit prob' bad and if you sure it is on and the flag is not stoping it from runing you might need a new unit but there are other tests you can do before..
call me 843.789.4824
Im in Charleston S.C but will happy to help you
www.911servicetoday.com
Dec 30, 2009 | Kenmore Refrigerators
Refrig Ice is freezing up on the door dispenser
Most likely the defrost timer or Adaptive defrost. Yours has the defrost timer. I want you to open the fresh food compartment and find a small opening through the control panel. The opening may have a plastic plug covering the hole to hid it. Remove plug and turn timer clockwise slowly until the compressor stops running. The compressor should remain off for about 25 minutes. If it does not turn itself back on then turn the timer slowly again to the right/clockwise until it does. If you need to restart the compressor. this way the timer will need replaced.Defrost timer is part number 482493 Keep me informed on your progress, Sea Breeze
SITE=> http://servicepartstec.blogspot.com/
SITE2=> http://appliancepartseast.blogspot.com/
Jul 11, 2009 | Kenmore Refrigerators
GE refrig Model # GSS25WGMD WW freezer is cool, compressor is running, but food is thawing out, ice has melted...not sure if I left door open ovenight, should I call repair..show long does it take to...
I pulled the refrig out from the wall, turned it off, took off the back panel (that covers the compressor fan and motor) and used the attachment on my vacuum to remove the dust from the area. Then I closed the flapper that allows the ice to release from the ice maker compartment to the dispenser, so no warm air would get into the freezer area. I plugged the refrigerator back in and within an hour it was freezing again! So far this week, I have had to repair the garbage disposal and the refrigerator.....I saved some nice $$$ by figuring this out by myself!
Jun 25, 2009 | GE Refrigerators
Icejams in the drop area.
Ice dispenser will not dispense cubes or crushed ice. Help?
Sep 17, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore side by side refrig model 52514100
water on the floor this morning. freezer not frozen
Aug 08, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore - over under
Adjust the feet to raise the front of the frige, which should be higher than the back. Therefore the weight of the door will keep it shut or at least cause it to shut itself if it pops open.
Jul 08, 2008 | Kenmore 62832 / 62834 / 62839 Bottom...
Refrigerators Logo
95 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
