Question about Motorola Mobility RAZR V3
Phone glich hi. my phones keyboard stoped working but i got that fixed and now the service wont connect to the phone.. is there anything i can do??
  • 983 Answers
May be the network pin has got displaced inside the phone or it may not be in contact...
so just you have to do is to open it and put the network pin in order ...
so after doing this it will detect the network service and connect to it ....
any further doubts reply me
i am always here to assist you
thank you
bye ...
Posted on May 03, 2008
Cant connect or anything with this mini bluetooth keyboard
try1234 or 0000 for the pass key #.
What model/maker of keyboard ?
Sep 06, 2014 | Cell Phones
How to fix screen on lg rumor 2
What you need to do is to get a screw driver, open the phone and remove the flex that connect the screen to the panel and put it back.
If the problem continues, then you have to change the screen with a good one.
Thanks
Jul 30, 2010 | LG RUMOR Cellular Phone
LG Voyager keyboard backlight broken
The connection between the keyboard and the mother board are loose. You need to take the phone apart and push the connection all the way back in. the connection is also connected to the screens and that might need a good push. Ive done this fix on many LG voyagers and enV's.
Jun 10, 2010 | LG VOYAGER VX10000 Cellular Phone
I have a hp compaq vista A900 notebooke keyboard stoped workin
there is no reason the keyboard should have stopped working unless something in the form of a liquid solvent was introduced into the keyboard area. Call the store where you purchased it or take it back along with your receipt for a warranty exchange.
Jun 16, 2009 | Compaq Keyboard
Keyboard won't work
try taking the battery out and wait 5 minutes and power it back on, this usually fix most problems and if this dont work try resetting the phone back to factory settings.
May 11, 2009 | HTC Touch Dual Slider Smartphone
My blackjack's keys wont work
First off, how do you know it's the keys, rather than something else? More details are always helpful. An important question is, can you see or hear anything at all, by any means? If someone calls you, does the screen light up?
If you see incoming calls, but can't answer them because the keys don't do anything, then I'd ask if the phone might have the keyboard locked. You'll be able to tell because you'll see "Unlock" in the lower left of the screen when someone calls or you press the power button (top left edge, above the screen). If it's locked, pressing the "..." button to the left of the wheel will tell you how to unlock it (just the "*" button down by the "0" button on my Blackjack).
If you don't see anything when someone calls, you might want to figure out if the phone is working at all.
A couple of ideas (sorry if any of these seem obvious - it's bad form to miss simple solutions):
1. Is the phone powered on? You can turn it on by holding down the power button (top left edge, above the screen) for several seconds. If you make it to 10 without the phone coming on, then it might be the screen, the battery, or the phone itself.
2. Is the battery dead? Try plugging the phone in and then holding down the power button, as above. If it still won't work, try removing the battery, then plugging it in and doing the same thing over again. When you plug the charger in, you should see a Duracell-like image on the screen, even if the phone is turned off. If you still don't get any sounds or anything on the screen, it sounds like the phone has serious trouble - probably needs professional help.
3. If you hear sounds ("swooshing" on mine) when you turn it on or off and the keyboard lights up, but don't see anything on the screen, it sounds like the screen might be bad - probably needs professional help.
4. Finally, you could try connecting it to your computer with the sync cable. I haven't done that with mine, so you'll have to read the instructioins, but it might let you know that the phone is working internally, but having communications problems through the keyboard and/or screen. If that's the case, you can try fixing it yourself or get an estimate from a professional. Good luck!
Mar 29, 2009 | Samsung BlackJack Smartphone
COBY STOPED AFTER IT WAS LYEING NEAR CEL PHONE
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
If the unit is no longer turning on in spite of being fully charged, unfortunately, it needs to be replaced. The unit can not be fixed. The warranty is 90 days from the date of purchase. You would need the receipt in order to receive a warranty replacement.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Dec 17, 2008 | Coby MP-C582 MP3 Player
Sony ericsson k850i won´t start up
hey, i had that issue to, on my k850i , i stoped it to change the sim , and when i started only the keyboard lights were on and the camera blue ring.. same thing like you. You can fix this by updateting the phone. Instal the update service select the k850 and fallow the instruction. after update the phone works fine.. sorry my bad english, hope you understand
Jun 18, 2008 | Cell Phones
Phone glich
taylorc-88 - you need to have the flexcable replaced on the phone
Crossinashes - master clear the phone and also reflash the software on the phone.
Apr 07, 2008 | Motorola Mobility RAZR V3
Phone glich
Hi again,
Have you tried getting in touch with Bajanguru?
Apr 05, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
