Question about UC-Logic WP8060U (689076313025)
My tablet wp 8060 cannot work ,there is green led blink when the pen touch pad ,but nothing show on monitor. I try to install tablet driver also software many times ,but still nothing change. vachara
4 Suggested Answers
early1234
  • 871 Answers
SOURCE: Intermittent functioning ...
hi there, you may have a faulty sensor or a loose wire on your tablet. this is the usual cause for tablets to malfunction and eventually die. so my advice to you, if its still under warranty, have it replaced. hope this helps you. ... fixya!!!
Posted on Jan 31, 2008
SOURCE: pen does not work and the LED light on the graphic tablet is constantly blinking
I purchased the same tool, and it did not work, later I went back to the shop where I bought, and showed him the problem.
the technical guy there tried it, it was not functioning, so, he opened another one and tried it, it worked on my same laptop.
because it was under guarantee!, the shop gave me instantly the working piece and took back the malfunctioning one.
I advice you to check with your vendor, it happens ;)
Sanousy Howari
Posted on May 07, 2009
I just fixed the same problem, my tabled was working fine since 3 years, suddently same problem cable. As it is not in warrenty any more, so i opened it and found the usb connecting wires, were some how a) getting short at the tablet entry end, b) the cable was sort of pushing the cabnet out ( on Top left Corner). Initially i brought the ckt bord out of the plastic cabnit, and placed such that the cables are not under any force ( free ) moving, it started working, then, i placed back it in cabnet, with wire properly routet and such that it is not putting any preasure on while i was putting the screws back. and it has been last 1 hour it is working perfectly fine.
Thanks Shree Ammu
Posted on Jan 12, 2013
Manhattan 177405 graphics tablet LED blinking.
The LED light is supposed to turn on when the pen is not being used. When you press the pen on the tablet the LED will turn off, only until you take the pen off the tablet. I believe this is mainly for troubleshooting, meaning if you press the pen on the tablet, the LED stays on, and the PC doesn't take in Input. This means you have either ran out of battery or the pen has been damaged internally. I believe it also tells you the tablet is powered on, again, meaning if the LED does not turn on when you plug the tablet into your PC then the tablet may be internally damaged, or the cord may be broken.
As for me; the LED doesn't bother me. When you're drawing with the tablet you should be looking up at the screen, not the tablet. So you shouldn't notice the LED.
I am not an expert, but I have been using this tablet for quite some time. I hope this helped.
Jun 03, 2013 | Manhattan 177405 GRAPHICS TABLET...
How to make Aiptek HP 12000U show up on computer
This needs a driver for Windows XP, which can be downloaded from Aipteks site. As I recall, you install the driver before the tablet and let XP "find" the hardware and install it.
Please clarify which OS you are using
Feb 09, 2010 | Aiptek HyperPen 12000U (HYPERPEN12000U)...
Touch Screen not working or Pen?
in my opinon. you should be re instal this touch pad driver.
Mar 09, 2009 | Toshiba Portege 3500 Tablet PC
My computer doesn't see the device
I am glad it worked!
Have A Very Happy International Day of Mother!
Your Welcome From U.S.A.
Mar 08, 2009 | Genius G-Pen 4500, 4x 5.5 4x 5.5 tablet...
G-Pen F610 blind spot (pen won't move over particular section)
Sometimes it is caused by a metal plate coming in contact with the sensor pad inside of the tablet. It is only fixable by dismanteling the tablet and putting an A4 sheet of paper between the back side (the one that has the metal plate which can be the culprit) and the green pad (do not touch it!). This issue usually appears after continuous use when the green sensitivity pad is pushed down a little and is short-circuited by the metal pad on the inner side.
Dec 28, 2008 | Genius G-Pen F610 (31100050100)
Pen doesn't work
have u tried re-installing the driver... if thats the case even if u tried different pens it wouldnt work... plus even if ur driver was fine a different pen wouldnt work for that driver... after re-installation if the pen still doesnt work then theres a 50% chance ur pens not working... One more thing does ur monitor support it???
Aug 30, 2008 | Eaton 30311 Tablet PC
Wacom tablet won't recognize pen
Hmm. I've had a similar thing happen with my tablet. Have you tried removing the tablet pen from the list of tools in tablet preferences and then adding it to the list again before checking the 'About' section of the tablet pen set-up and clicking the 'diagnose' button there in? As that worked for me when my tablet pen was not working. The pen was recognized by the tablet after that.
Aug 20, 2008 | Wacom Intuos3 Graphic Tablet
Intuos3 Tablet's pen is not working
Try reinstalling the software that came with the tablet.
Dec 29, 2007 | Eaton 30311 Tablet PC
Adesso cybertablet 12000 mouse and pen problem
I had the same problem way back with my wacom tablet. Mine was due to mouseware drivers. Soon as I got rid of them it was fine. So if you have mouseware drivers it may be interfering with the wintab drivers
Nov 25, 2006 | Adesso (CYBERTABLET12000) Graphic Tablet
UC-Logic WP8060U (689076313025) Logo
144 people viewed this question
Top UC-Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Chris
Are you an UC-Logic Computer and Internet Expert? Answer questions, earn points and help others
