Question about Zenith R57W46 57" Rear Projection Television
CONVERGENCE THE RED ON THE TELEVISION DOESNT LINE UP WITH THE OTHERS HOW WOULD I FIX THIS PROBLEM
  • paxrat69 Nov 19, 2008
    red light is causing a 3d effect in red on lower half and upper left. it looks as if red light could be adjusted to fix red shadow. just an auto tech by day never fixed any t.v. s
  • TheBanker999 Jan 19, 2009
    re: 46 in. rear proj. Zenith TV:
    Picture is fine, except for the lower left corner - that corner has a round section where the convergence must be off becuase blue is off with the rest of the picture, creating a sort of 3D picture. Nothing else is impacted. I paid $900 new year ago, so if can't be fixed for $100 or so, time to upgrade. A new 50 in plasma 720 (not 1080) is only $900!
Lower half and upper left have red shadow
Posted on Nov 19, 2008
  • Zenith Master
  • 8,617 Answers
You need to replace both convergence ICs. You can get replacement ICs at the following link and they provide free instalation instructions as well as free tech support so you can do the repair yourself.
Posted on May 03, 2008
Double image on television with blue hue
<SPAN id=ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution>Projection <A href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#" target=_blank><FONT color=#0033cc>TV</FONT></A> sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look <A href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#" target=_blank><FONT color=#0033cc>3D</FONT></A>, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. <BR><BR>This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem. <BR><BR><B>Common Symptoms include....</B><BR><UL class=h_mi><LI class=h_mi>Screen looks 3D <LI class=h_mi>Colors don't line up <LI class=h_mi>One or more colors can't be adjusted when using the convergence menu. <LI class=h_mi>Screen is bowed or warped. <LI class=h_mi>TV shuts off after powering on. Power light will blink. TV may also make a chirping noise. </LI></UL>Here are some <A href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#" target=_blank><FONT color=#0033cc>photos</FONT></A> of convergence problems.<BR><BR><IMG class=h_mi src="/uploads/images/42D3683.jpg"><BR><BR><IMG class=h_mi src="/uploads/images/7859B01.jpg"><BR><BR><IMG class=h_mi src="/uploads/images/E87380C.jpg"><BR><B>Here is a quick tes</B><B>t....</B><BR><BR>Using your original remote go-to the settings menu then goto the convergence section.<BR><BR>Try to adjust the red and then the blue convergence.<BR><BR>You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight. <BR><BR>If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem. <BR><BR>Note: If you TV has as flash <A href="http://www.fixya.com/#" target=_blank><FONT color=#0033cc>focus</FONT></A> or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix<BR><BR><B><IMG class=h_mi src="/uploads/images/69189A5.png">CONVERGENCE SOLUTION<BR><BR></B>You can see some more examples and find a fix using this link on Fixya <A href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull" target=_blank><FONT color=#0033cc>http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull</FONT></A></SPAN>
Aug 28, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Color seperation
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Feb 25, 2010 | Hitachi 43FWX20B 43" Rear Projection...
I have a hitachi 53fdx20b and the red and green colors line up fine, but the blue is droopy at the top and doesnt line up elsewhere, any help?? :)
Ur convergence is dead.U know how to solders?Try this website,Tv repair World.com.to buy a convergence kit,replace what in that kit.
Oct 20, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Can not line up red convergence
The convergence chips are toast. This is a common problem. Goto the site www.TvRepairKits.com to get a repair kit with instructions.
Dec 22, 2008 | Philips 60PP9202 60" Rear Projection...
Red is out of alignment
when i go to convergence and align the white cross with the blue its ok ,but when i try the red it doesnt line up and if l get it close enough it get misaligned only with the red ,green and blue fine
Nov 15, 2008 | Mitsubishi WS-65809 65" Rear Projection...
After replacing stk392-110 convergence chips
behind your front panel is two rows of small black knobs that adjust the lamps brightness and focus. a phillips screwdriver might be needed to turn them. you need to adjust the red guns focus.
Feb 09, 2008 | JVC AV-56WP74 56" Rear Projection...
Convergence problems
Well I would say the convergence amps are the culpits in your case. A common problem with all rear projection sets these days. Be real careful about buying replacements as I would go OEM only. They sell counterfits and low cost knock offs that will just frustrate you and raise the chances of damaging the board.
Dec 27, 2007 | Toshiba TZ50V51 50" Rear Projection...
CONVERGENCE
http://www.digitalhome.ca/forum/showthread.php?t=21847
convergence ic bad
Dec 03, 2007 | RCA P46812BL 46" Rear Projection...
Convergence
The convergence output IC's are bad. Need to call a service shop.
Sep 04, 2007 | Hitachi 46F500 46" Rear Projection...
Zenith R57W46 57" Rear Projection Television Logo
89 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
