Question about Craftsman 21 hp 42 in. Deck Yard Tractor - CA Model
My mower is 3 yrs old and the transmission keeps locking up and grinding when I try to move it, same for reversing??. I plurged the transmission but it do not seem to help, It appears to be locked up.
  • 333 Answers
Oil level in trans. brake locked or key sheared on pulley
Posted on Aug 20, 2010
Cub cadet xt2 reverse just got slow, why
Sounds like it may be a transmission issue. I would think warranty may cover it.
Sep 14, 2017 | Cub Cadet Garden
I have a Toro mower made in 5/09 self propel system it grinds when you pull it in reverse. The selp propel is not working. The belt is on. and it seems to be only the left rear wheel? The cable is not...
Yes it is the transmission. A Mower shop will charge you about $225 to fix.. I order parts online and fixed mine for $90. Transmission consist of 3 gears which turns the rear wheels to self-propel.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 21, 2014 | Toro Lawn Mower. 22 in. Personal Pace with...
Hydrostatic transmission control lever has become sloppy. When shifting now grinds.
my mower did the same thing i used it until it broke and replaced it
Jan 31, 2018 | Craftsman Garden
Grinding sound
Is the knocking sound when the car is moving or sitting still as well? Does the grinding sound happen just as you put the car into reverse or does it keep grinding?
These transmissions are very problematic, especially if they are not properly maintained. The most likely candidates are a cracked flywheel or a broken drum inside the transmission. Either way, it sounds like the transmission will have to be removed to pinpoint the problem.
Mar 30, 2014 | 2003 Chrysler PT Cruiser
Won't drive in reverse
Failed Transmission Again
Part with it
Get something else
Maybe American (Rear Wheel Drive Only)
Dec 12, 2012 | 2001 Mazda Tribute
Tranny trouble??
TRANSMISSION FLUIDS CAN BE CAUSED BY ONLY A COUPLE OF THINGS. MOST COMMON BEING A WORN OR BROKEN SEAL. THE TRANSMISSION SEALS ON MOST CARS ARE MADE FROM RUBBER OR METAL. BEING IN ALL KIND OF EXTREME TEMPS FOR YEARS ON END NOT TO MENTION THE PARTS MOVING AROUND THEM WILL EVENTUALLY CAUSE LEAKS. ALSO FAULTY INSTALLATION (OF A SEAL) CAN ALSO CAUSE A LEAK TO HAPPEN. THE ONLY OTHER THING THAT CAN CAUSE A LEAK TO MY KNOWLEGE WOULD BE IF YOU BOTTOMED OUT A CAR LOW ENOUGH THAT IT CAUSES DAMAGE TO THE TRANS CASE OR PAN. One cause of grinding when shifting into reverse is improper adjustment of the clutch linkage. If the adjustment is correct when the clutch is depressed the gears should stop turning and eliminate the grinding. Make sure there is some free play in the linkage when the clutch is not depressed. Most manual transmissions do not have a sychronized reverse gear. When you try to go into reverse from neutral, the transmission countershaft (which is linked to the pilot shaft) is still turning. The main shaft (which is linked to the tailshaft) is not turning. Therefore, since there is no sychronizer (or clutch brake like on a heavy truck tranny) the sliding cluctch gear (splined to the main shaft) grinds against the main shaft gear (floating over the main shaft but meshing its respecive countershaft gear through the reverse idler). The slider's function is to lock the main shaft gear to the main shaft thereby transmitting power to the rear wheels in the desired gear ratio (depending on which main shaft gear is locked to the main shaft). The way to cure this is to select a forward gear to stop the transmission and then go to reverse, all the while holding the clutch down. If it still won't go into gear you can either slip the clutch ever so slightly to "bump" the gears while gently pushing the stick into reverse (not too hard!! you can bend or break forks!! OUCH!!) or go into neutral, let the clutch all the way out, go into a forward gear and then reverse.
Feb 26, 2010 | 1999 GMC Suburban
My Toro mower is 7 yrs old. 3 speeds, blade
I've noticed that when the blade get dull it work harder a cutting tall grass. I just put a new blade on mine and now it runs and sounds like a brand new mower. also if the inside of the deck is coated with old grass that makes a differance too
Jun 23, 2009 | Toro Lawn Mower With Toro Power Tools
Transmission slipping making noise
If u keep it below 25 miles an hour you should make it, but this loud noise worries me, this noise means something is coming apart, if it does it may lock the trans up, so keep the speed down.
May 27, 2009 | 2003 Mazda Protege
MTD PRO RIDING MOWER/LAWN TRACTOR 18 HP ENGINE HYDROSTATIC DRIVE
In the back of the mower...probably under the seat, there should be a lever to release the transmission, or it is on the back plate. As far as the noise when trying to move drive the mower, the brake in the back, next to the transmission is jammed, use a 1/2 inch wrench to loosen it maybe 1/4 turn and this should unlock the brakes
Apr 22, 2009 | Garden
John Deere LT190 Lawn Tractor transmission problem
is it hydrostatic drive? if so you probably need to change filter and fluid
Oct 01, 2008 | Garden
Craftsman 21 hp 42 in. Deck Yard Tractor - CA Model Logo
100 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
