Question about HP Computers & Internet
My hp g60 will not start. the screen is black except to attempt to restart by pressing control + alt + delete what do i do?
    Sergeant:
  • 238 Answers
  1. Check your power cord & adapter.
  2. If its working then check the battery, reseat the battery & check.
  3. If available then check with another battery
  4. If no, then remove the battery & switch on the PC in AC mode.
  5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
  6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
Posted on Aug 20, 2010
Why is there a black screen on hp pavillion windows 7 "boot mnr missing"?
Windows 7 - black screen with blinking cursor
  1. Remove any CDs, DVDs, or memory cards from the computer.
  2. Disconnect all devices from the computer except the original mouse, monitor, and keyboard. Leave the power cord connected.
    1. Restart the computer.
    If it starts normally, start plugging devices in one at a time until you find one that may be causing the black screen
    1. Press the F10 key repeatedly during the first startup screen until the Entering setup message displays.
    2. Press the F5 key to restore the defaults. Use the arrow keys to select YES , and press Enter .
    3. Press the F10 key to save the changes and exit. Use the arrow keys to select YES , and press Enter .
      The computer restarts.
    4. If a Windows Error Recovery screen displays when the system restarts, select Start Windows Normally , and press Enter .
  • If this doesn't resolve it, follow the procedure below.
  • Aug 17, 2014 | HP 5188-7103 Compaq Motherboard Gl8e...
    Hp site
    Use Recovery Console
    When a Windows XP boot problem is severe, you'll need to usea more drastic approach. The Windows XP CD is bootable and will provide youwith access to a tool called Recovery Console.
    To boot from the Windows XP CD, insert it into the CD-ROMdrive on the problem system and press [Ctrl][Alt][Delete] to reboot thecomputer. Once the system begins booting from the CD, simply follow the promptsthat will allow the loading of the basic files needed to run Setup. When yousee the Welcome To Setup screen, press R to start the Recovery Console.
    You'll then see a Recovery Console menu. It displays the foldercontaining the operating system's files and prompts you to choose the operatingsystem you want to log on to. Just press the menu number on the keyboard, andyou'll be prompted to enter the Administrator's password. You'll then findyourself at the main Recovery Console prompt.
    Use system utility software like RegInOut after restarting windows.
    OR
    Use Last known Good Configuration:
    To use the Last Known Good Configuration feature, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Select the Last Known Good Configuration item from the menu and press [Enter].
    Keep in mind that you get only one shot with the Last KnownGood Configuration feature. In other words, if it fails to revive your WindowsXP on the first attempt, the backup copy is also corrupt.
    Jan 01, 2012 | HP Computers & Internet
    Windows xp black screen problem
    Use the Last Known Good Configuration feature, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Select the Last Known Good Configuration item from the menu and press [Enter].
    Dec 31, 2011 | Microsoft Windows XP Professional
    HP black screen will not start windows how come
    Restore your PC to Last Known Good Configuration:
    To use the Last Known Good Configuration feature, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows advanced Options menu. Select the Last Known Good Configuration item from the menu and press [Enter].
    Dec 27, 2011 | HP Computers & Internet
    Black screen will not start windows only diagnostic
    Restore your computer to Last Good Known Configuration:
    Black screen on aspire one
    Restore to Last Known Good Configuration:
    Dec 17, 2011 | Acer Aspire One Netbook 8.9" Notebook
    I have a HP G60. When i hit the power button automatically a grey screen pops up and I dont hear any boot attempt from the laptop or fan. just the cd drive adjusting. and it stays like this no buttons...
    windows Vista or W7? (oldest G60 is 2008 G60-100)
    so never any text at the screen battery main out.
    run on AC power only, batteries are very unreliable things.
    no text , like "Hit F10 to enter BIOS" as seen for 10 years. now.
    this shows if the PC is alive or not. is it?
    if that fails. show text then check for a dead black lamp.
    no fan running means no power or its packed solid in lent.
    try a new power pack.? the fan must run. or there is no power.
    battery out tests ALL, leave it out. so we dont have 2 problems.
    run on AC power only.
    i use a thing called a volt meter to see of the 19vdc actual lands
    on the main board. from that powre pack.
    there are many steps, after 19vdc hits main board
    we strip the whole PC down to PROVE no modules are shorted.
    please test the LT with battery MAIN removed.
    and report action of screen, any thing there.
    and if FAN works, as it must. or will overheat FAST>
    ever clean the vents on the PC? (with can-o-air)
    Sep 21, 2017 | HP G60 Notebook
    My toshiba l450d black screens after turn on
    TRY START UP IN SAFEMODE ( USING THE F8 KEY ) KEEP PRESSED DOWN WHILE ON START UP OR RESTART ! THIS WILL SHOW A DIFFERENT SCREEN AND YOU SHOULD BE ABLE TO SORT IT OUT ! IF NOT THEN TRY PRESSING CNTROL ALT AND DELETE TO BRING THE CONTROL MANAGER UP AND AGAIN SOMETHING COULD BE RUNNING THAT SHOULD NOT !
    Feb 05, 2011 | Toshiba Satellite Pro L450 Notebook
    HP G60 PC Notebook is slow
    go to run or start search and write temp ,hit enter.and delete all the temporary files...
    open your internet explorer..go to tools nd internet options and at top go to advanced settings and uncheck the option which says enable third party browsing....click on ok or apply...
    close the internet explorer ..restart the notebook...
    the os will run much faster now
    May 30, 2010 | HP G60 Notebook
    Computers & Internet Logo
    129 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
