Question about Mitsuba HDC-505 Camcorder
I try to use the camcorder and all i get is memory full, no matter what i try, I have tried to format over and over again but it will only seems to record for just a few seconds then it comes back with the same message of memory full, it even has an sd card installed, Please help!!!
    Genius:
  • 1,035 Answers
Hi. Try to save/use first the built in memory of the camcorder instead of using the Memory card when saving video. In this way we can determine whether the memory card is having the problem or the camcorder. If you were able to save/record a video thru the built in memory of your camcorder, then there could be a problem on your memory card. If you are not successful in saving video on your camcroder itself, then this could be a camcorder problem.
All the best!
Posted on Aug 20, 2010
When I power up my Aiptek 720P camcorder the screen tells me the memory is full although I have emptied the memory
Try reformatting the media, if using an SD card, replace it with another and use a PC and format it FAT16 with a PC and USB dongle return it to the unit it should be OK, you may have to format again after you put it in sometimes too.
Oct 06, 2011 | Aiptek A-HD 720P Flash Media Camcorder
My polaroid DVF-720 digital camcorder wont turn on.the battery is fully charged and it is in the right way.
1.Remove battery
2.Remove memory(EXTERNAL MEMORY)
3.Plug in the power ,CLICK BUTTON ON in 10 second.
4.Plug out the power
5.Insert back battery.
6.Click button ON IN 10 SECONDS AGAIN.if it will ON MOVE TO STEP 7. IF NOT,GO TO STEP
7.OFF CAMERA AND THEN BACKUP YOUR MEMORY(EXTERNAL) to pc
8.CHECK AND FORMAT
9.INSERT BACK EXTERNAL MEMORY
10. ON BACK AGAIN.
11.TRY CHANGE BATTERY . SOMETIMES BATTERY WAS ISSUED FOR THAT. IT NEED OPTIMUM POWER. BATTERY FULL DOESN'T MEAN THAT IS OKAY.
however, mostly issue are cause from external memory, if that can ON without external memory that mean your memory was problem. backup, checking disk.
FORMAT, USING PC .IF SUCCESS IN FORMAT USING PC, THEN FORMAT AGAIN IN YOUR CAMERA. IN FORMATTING USING PC, TRY USE FAT32 THAN FAT.
TRY IT...out
May 28, 2011 | Cameras
I bought a new Memory stick for my Sony DCR-TRV320 Camcorder and when i switch my device to memory mode, it tells me "Memory Stick Error."
Check the following:
Memory Stick is inserted in correct position and orientation in camcorder. Try re-inserting several times.
Write-protect tab is switched to allow writing to memory stick (on back of memory stick)
Memory Stick is formatted in FAT file system (this should already be done except if memory stick has been formatted in a computer in a different format)
Memory Stick is not over the maximum capacity memory stick of the camcorder.
Memory Stick is not full.
Memory Stick is clean and dry.
The dcr-trv320 is a 2000 yr. model and came with a 4mb capacity stick and can probably only use up to a 128mb capacity stick or possibly 256mb. Most memory sticks you can buy today are 1GB, 4GB, 8GB etc. memory stick pro duo. and are probably incompatible. E-Bay has some of the old memory sticks like the 128mb for sale.
There is a slight possibility that static electricity discharge zapped the stick. Try another memory stick or try the stick in another device.
May 02, 2011 | Sony Handycam DCR-TRV320 Digital Camcorder
When i try to format the SDHC 8GB memory card the recording screen display's (Waiting....) for about 1 to 2 second's, then goe's to the normal recording screen and when i push the record button it...
Hi, look here's what to do, get yourself, or access to, A Computer, and a USB SD card reader, now, insert your 8GB SD card into the reader/writer, It will show up as a HDD in My Computer, and then, Format it FAT32. Now return it to the Camcorder, when turned on again, the Camera NOW should "See" the SD card. You may even be asked if you wish to Format,again,say YES, and do so, if NOT asked that;s OK too. as, you should now be able to, in either case, be able to have access to the SD card, and can change your phone settings accordingly, the extra storage will simply be "Picked Up" by the Camcorders software.
If this doesn't happen, then there maybe a problem with THAT SD card or the Camcorder? try another SD card before thinking the camcorder has a problem though.
Aug 29, 2010 | Jazz Cameras
I keep getting the folowing message after taking two pictures your disk is full.
First see how much memory your camera have, then see if your camera have memory card in it, then go to setting and set your default save to memory card if it not helps then format you memory card and try again
Feb 16, 2010 | Vivitar DVR 810HD Flash Media Camcorder
Memory full message
Hi There
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jan 15, 2009 | Aiptek A-HD 720P Flash Media Camcorder
    Not recording
    i have a camcorder just like yours. by the way im not using memory stick because its pretty easy to use a dv tape.
    try to switch from the menu your storage device like dv to memory card or stick. format it to your camera and computer. hope that helps!
    CHARCOIS
    Jul 28, 2008 | Samsung SC-D353 Mini DV Digital Camcorder
    HD 720 does not seem to detect 4 gig SD memory card.
    I think it will only take SD memory cards not a PNY.
    Jan 12, 2008 | Aiptek A-HD 720P Flash Media Camcorder
    Audiovox dc400 memory full
    try formatting your memory cards?
    also try and search for errors
    Nov 16, 2007 | Audiovox DC400 Camcorder
    Mitsuba HDC-505 Camcorder Logo
    59 people viewed this question
    Top Mitsuba Video Cameras Experts
    prouddad_1
    Are you a Mitsuba Video Camera Expert? Answer questions, earn points and help others
