Question about Sharp Microwave Ovens
Inside plate doesn't turn It doesn't warm up
  • Sharp Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 20, 2010
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
Turntable stopped turning
This is quite a common problem and often associated with a recent spill (boiling over) of liquid in the microwave. Liquid overflows the glass dish, onto the floor of the microwave and down the hole where the drive motor that turns the plate is located. Liquid runs down the shaft of the motor and into the drive motor which then stops it functioning. Because the drive motors on most microwaves are induction motors, and not driven by a traditional armature with brushes, about 75% of the time you can fix this by drying the motor out (Though this depends on the liquid spilled).
You will have to get into the underside of the microwave, often this means snipping a bit of the casing directly under the drive motor (Which is of course directly beneath the drive shaft that pokes up beneath the glass plate).
Once you gain access, you will see the motor clearly and it is usually held in place by 2, 3 or 4 screws, unscrew from mountings, unplug the power wires (They usually have a couple of wires from the motor with a little plug on the end that you can pull out).
Give the motor a good shake to remove any liquid and then go put it on top of your boiler, in your airing cupboard, out in the warm sun or even (If you trust yourself not to cook it!) in your oven on a very very low heat. Leave in the warm place for a day (not that long with the oven option!!) until it is thoroughly dry. To test, plug it back in, but don't bother to reassemble yet. Turn on the microwave and see if the spindle turns. If it does, it's fixed, if it doesn
Aug 23, 2011 | Microwave Ovens
Carousel does not turn
Jul 22, 2011 | Maytag MMV4203D 1100 Watts Microwave Oven
PANASONIC GENIE NN S615WFX TURNTABLE DOES NOT TURN
Jul 20, 2011 | Microwave Ovens
Does not rotate
Give the motor a good shake to remove any liquid and then go put it on top of your boiler, in your airing cupboard, out in the warm sun or even (If you trust yourself not to cook it!) in your oven on a very very low heat. Leave in the warm place for a day (not that long with the oven option!!) until it is thoroughly dry. To test, plug it back in, but don't bother to reassemble yet. Turn on the microwave and see if the spindle turns. If it does, it's fixed, if it doesn't then you are most of the way to a strip down so you can go buy a new motor and replace it.
Jul 12, 2011 | Microwave Ovens
My Corelle plate (round) is wedged in my round Rival stoneware crockpot - have tried everything I can think of to unstick it - soap, oil, hot water, cold water -- only the tip of a thin knife fits between...
suggestion to try, depending on how far the plate is down in the stoneware, try filling the Crockpot with warm water. Then plug in the Crockpot and turn it on to a medium heat. Then keep close watch on it, as the stoneware warms up it may expand enough to release the plate.
May 24, 2011 | Microwave Ovens
Sparks in microwave/convection oven
Remove the plate and clean it with warm water
Jun 22, 2009 | Panasonic Microwave Ovens
Kenmore 1200 watt sparking when warming empty plates
Unless specifically stated in the manual, you shouldn't use the microwave for warming plates. That is not it's intended use.
I suspect the microwave circuit has failed in some manner.
Reply the specific Sears model number (in the form xxx.yyyyyyyy), and I can help further.
Jan 23, 2009 | Kenmore 63252 Microwave Oven
Microwave Ovens Logo
21 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
