Question about SanDisk Sansa e250 MP3 Player
My sensa fell in water and the screen went blank, i dried it off even blow dryed it but no screen yet, what should i do????
    Brigadier General:
  • 5,158 Answers
Hate to say it. unless you can afford to spend the money to have it repaired. you may want to buy a new one
Posted on Aug 20, 2010
The top of my nokia 5230 got dropped in water and now the screen is blank but it still switches on. what can i do to get the screen back again
Open up the phone and dry it in the sun, or do a blow-drying. Ensure that every trace of water is out of the phone. Then try switching it on. If the screen still appears blank, then the water must have severed the connection between the board and the screen. Open up the entire phone (screws and all ) and first with a soldering pin, melt off totally the solder initially joining the screen to the board, then re-solder it.
I hope this helps.
Mar 20, 2011 | Cell Phones
Water spilt on dvd player now the screen is just white but there is sound
open the top and set it where warm, dry air can blow through it for 10-15 minutes. maybe even use a hair dryer. also make sure to blow out the outputs.
good luck!
Jan 31, 2011 | Emerson Dora The Explorer DVD Player
Phone fell in water tub now screen is not working love_life_23@hotmail.com
these were the first 5 things you would have done when it fell
  1. Turn the device off and do not charge it - You want to keep the phone non-operational while it dries out.
  2. Drip dry and shake off as much water as possible
  3. Dismantle whatever you can - If you are able to remove the battery and cover, do so. The more you expose the better it will dry.
  4. Cover your phone in a bowl of rice - Rice will help absorb moisture like how it does in salt shakers.
  5. Draw it away with a vacuum cleaner held over the affected areas for up to 20 minutes in each accessible area, having already removed the majority of liquids and moisture manually and dried all visible moisture by hand, so that none enters the vacuum cleaner. This method is preferable to leaving it to dry naturally as it halts any oxidation from occurring deep inside, such as can result in functional issues later on. This is the fastest way (less than thirty minutes after your phone drowns, it can be completely dry and working, especially if you are able to also partly or fully disassemble it) to quickly get all the internal moisture out of the phone effectively and stop the internals from 'rotting' away. Remember that the goal is to **** all the moisture and humidity out of the phone not to blow it even further in and create even more evil humidity deep inside
now tat its nt working it seems its not sensitive to touch replace
Jan 02, 2011 | LG KC910 Renoir Cell Phone
My Canon A430 Camera got a bit wet when I fell into a Dam this weekend. The camera did not at all touch the water, but a few drops of water did land on the camera. After drying the few drops off, the...
Apparently, Some water worked its way into the camera circuitry. You need to stop trying to get it to work...you're only making things worse. Remove the card and battery. Bury the camera in a bowl of dry rice for a few days to absorb any moisture.
Jun 30, 2010 | Canon PowerShot A430 Digital Camera
My phone screen went blank after dropping in the toilet
You should have left it dry instead of turning it on, you probably have corrosion now, find a local place that works on phones to see if they'd work on it.
If you want to try to completely dry it, put it in rice for 24 hours minimum to draw out all moisture.
Aug 03, 2017 | Motorola Mobility RAZR V3
My samsung rant fell in some water is their any way to fix that or no
disassemble it as much as you can. leave it in a dry warm environment for about a week to dry out. put it back together in about a week. charge up the battery and power it up. cross your fingers it may work.
p.s. was it on when it fell in the water ?
Nov 13, 2009 | Samsung Rant Cell Phone
I dropped my sgh-d807 in water,the screens blank and wont turn on
u broke your phone becus i did the same thing and had to buy a new phone sorrythat happened
Jul 10, 2009 | Samsung SGH-d807 Cellular Phone
I have a Nokia N90 and it fell in a bucket of water,it submerge for about 6 secs after grabbing it out.I dried it off and imediately run a blow dryer on it,but not getting any display on screen,but it...
The best way to treat a phone after water submersion is to remove the battery immediately and allow it to dry near a radiator or other gentle heat source. Sometimes burying the handset in dry rice will speed up the drying out process.
Be prepared to take it in for repair if the above doesn't work.
If it's insured you should be covered for water damage.
Jul 07, 2009 | Nokia Cell Phones
Nothing transfered from the lens (ccd) to the screen/memory card
Greetings Maltheskalle,
Units that experience water damage are normally irrepairable even after drying out. I would take it to a qualified repair center and have them give you an estimate on repairing the unit. You may find that replacing the camera is more economical than repairing it.
Sincerely,
Dorothy
Go Ahead. Use Us.
Jun 10, 2008 | Kodak EasyShare CX7525 Digital Camera
5300 fell in water
open up yor phone clean the phone with the isoprophyl alcohol dry it using the hair dryer avoied heat going to the lcd avoid ipa going to the lcd. advice by dogy
Jan 11, 2008 | Nokia 5300 Grey Cellular Phone
SanDisk Sansa e250 MP3 Player Logo
115 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
