Question about LG RU-44SZ51D 44" Rear Projection HDTV-Ready Television
Hello, I have an issue with my TV, it keeps turning itself off and when I turn it back on, it makes a whirring sound for a minute or so and then sometimes comes back on but a lot of the time, it switches itself off again. I even bought a new lamp for it as I thought that was the problem, but it still says 'replace the lamp' in the bottom right hand corner. Please could you let me know what I'm dealing with? If I need a spare part and it's easily fixed or if my TV is really and truly dead?! Yours sincerely Kyri Christodoulou
  • LG Master
  • 8,617 Answers
Sounds like the color wheel or fan is causing the squealing and shutdown. Color wheel is the most likely of the two.
Posted on Aug 20, 2010
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
My humax pvr 9300t is affecting my programmes and switching itself on and off every few minutes
Try switching it off at the mains for a few minutes.
If that doesn't fix it, I suspect that the disk is faulty or corrupted.
Aug 06, 2014 | Humax PVR9300T HD DVR
Samsung HLS5086WX/XAA made popping noise and shut off, then made whirring noise.
When my TV did this in the past it ended up being the color wheel. I had someone replace it and it worked fine. I asked it if had to be calibrated after it is installed and he said no. Also make sure the door switch is pushed down when you install the back bulb door. Sometimes this switch can go bad as well.
Jan 10, 2013 | Samsung HLS5086WX/XAA
My 2 year old tv has just started to go wild. Just put it on today and where u select the source on the menu option, this keeps scrolling through.. no responce from the remote and when switched off at the...
Hello mrdavidmetca,
Welcome, and thank you for using FixYa!
I would start by pulling the batteries from the remote control. Manually turn the TV off and then back on, manually. If the issue resolves, replace the remote.
If the issue continues; you will need to find a local TV Repair Shop and have the Tuner Board replaced.
Have a great day!
Sep 09, 2011 | Televison & Video
TV turns itself off after about 5 minutes (green light remains on). I can turn off the TV and turn it back on immediately, however, the TV turns itself back off after a few minutes. It started turning off...
Check and make sure your fans are working and there is sufficiant cooling to the back of the set. Sounds like it is overheating and going into protection mode.
May 04, 2011 | Mitsubishi WS-65513 65" Rear Projection...
My projector lcd tv turns on and then turns itself off and the lamp light flashes it makes a whirring sound and is still on and still has power however no picture is that a sign that the bulb has blown or...
It is quite likely that the lamp is defective. The whirring sound is possibly the fan doing its cool down cycle. If the lamp has failed, it is likely that you may need a ballast unit as well as a lamp.
Mar 27, 2011 | Televison & Video
Tv keeps switching on and off and will not stop
unplug tv for 2 minutes and plug it back in. problem should go away. if not, call toshiba.
Jul 22, 2009 | Toshiba 27AF41 27" TV
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
Zenith 27inch B28A11Z keeps powering itself off
Hi Pswglaw,
From the way you describe the problem, it seems you have a high voltage leak. To check this, make the room dark and look into the back of the TV while turning it on. If you see something like lighting jumping around you have this high voltage problem. The TV will eventually destroy itself under this condition. I would suggest not using it until you get it repaired. The repair cost will be much lower if the TV is still working when you take it in. The high voltage leak will destroy more parts and cause the TV to stop working. Then it will blow a fuse.
MyTvGuy
Jan 23, 2008 | Zenith B27A11Z 27" TV
Open Questions:
LG RU-44SZ51D 44" Rear Projection HDTV-Ready Television Logo
97 people viewed this question
Computer Repairing
Computer Repairing
