Question about Ruud UAKA060 Air Conditioner
Line 2 fuse is bad. How do I fix it? What type of fuse do I buy to replace it? Are the Line 1 and Line 2 fuses supposed to be the same?
  • mriordan Aug 20, 2010
    Both fuses are currently 50 Amp. Only Line 1 is time delay.
  • 38 Answers
Check the pcb board and then put fuse 3.15amps
Posted on Aug 20, 2010
  • 139 Answers
The fuses should be time delay 30 amp both fuses should be the same
  • joe harper
    joe harper Aug 21, 2010
    well look on condensor unit data plate almost always 30 amp unless its like a 5 ton unit but any way time delay fuses for all condensing units
Over heated wont run
Thermal fuses inside prevent fires and, unfortunately, they also prevent you from ever restarting it again. Manufacturers want to protect themselves from liability and increase their sales by using the single use thermal fuses. If you are not familiar with a soldering iron, then you will have to buy a new unit. Otherwise, you can try to replace the fuse (a small silver cylinder about 1 to 2 mm diameter and 10 mm long with a wire out of each end.
Remember, replacing the fuse doesn't fix what caused the fuse to blow - it could be a bad motor bearing that causes a high current draw, or simply feeding vegetables too fast. If it is the motor bearing, then You have another problem.
Mar 13, 2014 | Sharper Image The 8021SI Stainless-Steel...
M38 fuse keep blowing
the parts are shorted, the FUSE stops the fire. and flames.
we fix this buy isolating the shorted part.
we do that with an ammeter. (there are other ways, ask)
i see the ammeter prove short then
i try each door manually , 1 by one form the local door switch lock
to see if one door blows the fuse when activated.
BINGO, so then unplug that door lock solenoid, still blow the fuse
(i use a fuse substitute device (sold in all good auto-stores) called a fuse, circuit breaker converter)
lock sol, removed, still blows?, yes? then harness shorts, (hard work)
if Sol, pulled cures over-current, its bad. a shorted soleniod.
there are other ways, ill just list them.
no ammeter?
no C-Breaker.?
  1. use a light bulb in place of fuse. (i use a head light in a box)
  2. a current limited power supply in place of fuse. (see over current)
  3. Pul all parts, 1 by one on this bad line and a box of fuses.
there are 4 ways.
I always use an amp clamp meter on the line
and the circuit breaker trick.
then pull parts. and conn. on the bad feed. (lots there are)
that's it, for shorts.
Mar 09, 2014 | Jeep Liberty Cars & Trucks
Hello........ looking for a schematic for Bose 501 series 3 speakers. I need to replace the fuse in line with the tweeters.... its blown & does not have a value on it (unmarked, quick blow, twin lead,...
Did you find a solution? Dunno if it's much help, but I just today picked up some 501s - Series I I think - ugly heavy brown material grilles - but with a manual! No fuses in these, but booklet recommends installing your own in-line fuse holders (!?). Specifies a BUSS AGC-3 fuse for amps under 50wpc; or a MDL-2 fuse for amps over 50 wpc. Can be placed is series with either or the two signal wires. Very strange.... Robin
May 14, 2011 | Bose 501V Speaker
Rca bday61w66 convergence board removal
Different possibilities:
1. Bad hv circuit (flyback)
2. Bad connections on flyback & the little fuse next to it
3. Bad fuse near tuner
4. Bad picture tube
This tv is known to have any of these problems.
I believe the solution is: number 2.
I have had a few of these with burned up convergence boards, but it is rare. If you replace one, you must replace both if it has 2.
Check for rings around the flyback solder joints and the little brown fuse next to the flyback (3 are in a line).
Good Luck!
Apr 28, 2011 | RCA HD61W66 61" Projection HDTV
MY WII WONT TURN ON AT ALL THE LIGHT DOESNT EVEN COME ON WHAT COULD THE PROBLEM BE.
There is a fuse and I think the fuse is the problem if you believe that your power supply is good
Buy a tri-crew drive ship on ebay $2
fix it by your self because you have no warranty (it is 6 years old)
open it up then replace the fuse
here is where the fuse should be http://i47.tinypic.com/2lbko7b.png
This will also help to open up the wii http://www.ifixit.com/Guide/Repair/Repairing-Nintendo-Wii-Drive-Board-Fuses/4029/1
Make sure to order the fuse with the screw driver too. It should cost you less than $10
If you don't want to replace the fuse, just use wire and solder the two solder pads for the fuse but this method is bad.
Please rate if this helped you.
Apr 15, 2011 | Nintendo Wii Console
Mitsubshi WS-65909Error code 2-2. i would like to know how to fix
The fuses are not the only problem--if 2,2 error code 95% of the time the Convergence IC that the WS-65909 uses is bad. It is a STK-393-110----fuses are on the same board and near the middle towards the back---they are green in color and look like resistors--if you have this model the location numbers marked on top of the board will be F9A04 and F9A05----both are 5 amp fuses (this will also be marked on the board) they are 2 of about 5 fuses and are towards the rear of the row of pico fuses.
If you check the fuses (just like any other fuse) and either is open--You need to remove the center board and replace the STK chip and the fuses-----not everyone can do this repair themselves--
I have had so many people ask me about this problem that I have composed step by step start to finish instructions for this repair--If you have some skill at soldering and think you can remove the board safely let me know and I will post the instructions here for you to read.
Other than the fuses there are about 12 light blue resistors in front of them that need to be checked--if any are discolored they need to be replaced also--they are all low value resistors--3.9 ohms--they will check like a fuse--no reading and or discolored and you need to replace them.
Considering the parts cost is usually under 20 dollars--I can also tell you the best place to buy the chip--you can if you can do the repair save a lot of money--most shops get 300-400 for this type of repair.
If you find the fuse or fuses bad---do not bypass or replace them--the only thing that gets them is the convergence chip.
If you have any questions or need advice let me know--I am here to help people.
SD TECH
Oct 19, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Chefmate microwave will not heat up anything
A microwave not heating up is caused by one or more of the following -
1) Failed controller board (unlikely if you are getting a clock readout and you can get the various functions to work, just no heat)
2) Failed door switch
3) Failed thermal fuse, when used
4) Blown power fuse that is dedicated to the microwave circuit
5) Bad diode
6) Bad capacitor
7) Bad magnetron
8) Bad transformer
Door switches insure the microwave circuit will not engage when the door is open. Slamming the door of the microwave is hard on the switch.
The thermal due is wired into the microwave harness, and is a melting allow type, based on heat buildup within the oven. Always replace with a fuse of the same thermal rating.
The power fuse is a special type and should only be replaced with that same type and rating. It is easily tested.
The diode is a relatively inexpensive part, and is not easily tested. If a grumble is heard coming from electrical area of the unit, then the diode could be shorted.
A shorted capacitor will blow the fuse immediately. And open capacitor will cause a "no heat" condition.
A bad magnetron will also cause a low level hum or grumble from the transformer. But is may also cause no other identifiable symptom of failure.
A bad transformer will exhibit a grumble or hum, and may or may not blow the fuse. But be careful here, the secondary of the transformer produces very high voltages, up to 2.5Kv. Few people own a meter capable of measuring such voltages.
Service and repair of microwave ovens is dangerous work. If you don't know what your doing, DO NOT ATTEMPT TO SERVICE A UNIT WITHOUT INSTRUCTION.
Feb 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Hitachi 60ux58b projection tv
If there is no power indicator, you could have gotten lucky and only the main fuse insiude the set blew. You can unplug the TV set, take off the back of the TV. Then where the line cord comes out of the TV set and plugs into the wall, look where the line cord enters the set and look for a glass type cylinder fuse. If it is black, most likely there is a short inside the TV set. If it is not black, try replacing the fuse with ONLY the type that is stamped on the side of the fuse. If the set still does not work, or if the fuse blows again, you will need to have the set serviced by a pro. Good Luck
Aug 18, 2007 | Hitachi 55FX48B 55" Rear Projection...
MAYTAG mmv4205aab OVER THE RANGE MICROWAVE
It could easily be a bad line fuse and/or line filter. To access you will need to unplug the unit and remove the outside case. Inside the unit, where the A/C power cord comes in, there should be a small circuit card (part #237068) located somewhere with a fuse mounted on it. This is your input line filter board with line fuse. Replace the fuse, first and see if this fixes your problem. This is a 20amp appliance fuse that you can purchase at any hardware store. Make sure you place the cover back on the unit BEFORE you plug it in. It is not safe to have this area of the microwave exposed with power applied. High potentials in the 4,000 volt range are present! If the fuse does not correct your problem, the circuit card runs about $26.00. Good luck and hope this fixes your problem.
Aug 04, 2007 | Maytag MMV1153A Microwave Oven
Ruud UAKA060 Air Conditioner Logo
271 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
