Question about Samsung PCN5425R 54" Rear Projection Television
My samsung tv monitor has turned red shade, it is still plaing and all but everything is red, it only does that on the component input but the analog cable input works fine, there is more than one component wire inputs , i tried them all and still the same red shade, it might be the cable box but i dont know please help, football season is coming up need that high defenition
    Top Expert:
  • Samsung Master
  • 14,553 Answers
IF It only does it from the box either the cables are bad (unlikely) or problem is coming from box.
Two things to do: unplug box and let it reboot.
Have provider bring a new box to correct problem; component is Red, Green, Blue video with info---one messed up and bingo.
If not on regular cable the set does not know what is hooked up to it.
Get another box and get back on line.
SD TECH
Posted on Aug 20, 2010
When i power on tv it say analog rgb searching/monitor going dpms
A guess here---turn on and with TV/video or source or input change the input until (say you have cable hooked also) you see the regular picture again.
The input by accident may have been switched to the RGB(red, green, blue) which is a component or HD input.
Start there and let me know what happens.
Dec 05, 2012 | Hitachi 42HDS69 42 in. Plasma Television
No problem - I hope!!!! Just need to know if Direct TV is compatible.
Direct TV is compatible with all TV's. Just requires the proper cable connections
Mar 10, 2011 | Televison & Video
Hi i am trying to work my 'component' on my samsung tv. How do i get this working
Component video input is a high quality analog video signal separated by the three prime colors, red green and blue. You will need component video cables to make this connection.
Turn the television off.
Plug the connectors of each coaxial cable into their corresponding terminals on the TV.
Plug the other end of the cable into your other device that is also using component video, such as a cable box, video game console or DVD player, etc.
Power on the TV.
Press "component" on the remote.
Power on the device.
Nov 07, 2010 | Samsung PS50C451B2D 50 in. Plasma TV
I Have just bought this reviever (Yamaha Rx-v365)and im just trying to work out how to best connect all my devises. I have Tivo, Lg DVD player with both yellow, red white cables and blue green red cable...
Hi, firstly some terminology:
yellow cable - video composite (worst quality)
white/red - stereo analog audio
blue/green/red - video component (second best quality after HDMI)
You are correct that RX-V365 doesn't do audio over HDMI. Moreover it also doesn't do any video processing, which means composite video input will go only to composite video output (and not to component); compoment input only to component output and HDMI input only to HDMI output.
If you have more devices of same video output (in your example the component blue/green/red), you can connect them to TV via the receiver. But if only one device of same video output, you can connect it directly to TV. There is no reason to go through your receiver for video.
For audio, you can use either the analog stereo white/red cables (rx365 has 5 such inputs) or better use digital SPDIF connection, which is slightly better quality and more importantly supports 5.1 sound. There are 2 types - coaxial (orange RCA plug, can use basic rca cable) and optical (square black connector). Receiver has 1x coax spdif input and 2x optical spdif inputs. Look at your other equipment to decide which cable to use.
For the analog audio inputs, I think you can assign it either to composite video or component video. So for DVD audio white/red plugs, you can choose if either Video composite yellow plug named DVD will be used, or component blue/green/red named DVD will be used.
Jan 03, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
TV HAS GREEN HORZONITAL STRIPES
Check if this happens in analog inputs ( connect a DVD player or any other component uing RCA cables white,yellow,red ) then check if the bars are showing on digital unputs ( connect using HDMI cable )
if it is just an analog problem - replace analog board
if it is just a digital problem - replace digital board
if it is a problem with both -replace DMD board
May 23, 2009 | Samsung Televison & Video
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
Mitsubishi WD-52631 shadows and blurs in dark lit movies
If you are getting the same problem with both TV monitors it could then be assumed it's an input problem to the TV monitor. If you are using a digital output from your receiver it could be the cabling. If you are using an analog output from your receiver it is probably coming from the receiver.
Digital video processing does have issues with darker scenes.
Can you try another video source seperate from the receiver like a DVD or better yet an analog VHS, if you still have one. Good luck and let me know.
Sep 17, 2008 | Samsung HL-R6168W 61" HDTV
Help!!
Do you have your other components wired to the Onkyo. The monitor output isn't the best way to go. If your TV has component inputs or an HDMI you should run one of those instead, running a composite video cable will only get you analog at best.
If you are content with running analog you may need to go into the menu on your tv and select the type of video input you are using. The same goes for your receiver, switch the output to analog out.
Jul 17, 2008 | Onkyo Audio Players & Recorders
MY SAMSUNGS HAD IT I THINK
Sound like a simple and yet common problem. Check your input cables properly. You may have the red Video component jack plug into your audio input, and your audio is plug into the red video component input. Lay the TV flat and look at the input. This i think is your only problem. I see this everyday.
Best regards
Circuitcity
Dec 06, 2007 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Video issues w/ Pioneer VSX-816 AV Receiver
Receivers generally cannot or will not convert from one input type to a different output. That's not to say there may not be some high end models around that do that.
I have this receiver and have it setup as follows. Monitor out Component, S-Video, and the Composite video channel (since I have surround sound I have no interest in getting audio to the TV since I keep its speakers off anyways) to their different inputs on the TV. Warning on some TV's if you plug in S-Video you cannot then use composite on that same input channel as it will override and disable the composite. Then you only need to choose the appropriate input on the TV when you switch sources. In my case Tivo is S-Video, DVD is component, and most of my older video games and VCR are composite.
Having a TV that allows you to change the labels for the input channels is helpful with teaching others that may be less adept, or a snazzy remote that you can program to do everything at once.
Aug 30, 2007 | Pioneer VSX-816-K/S Receiver
Open Questions:
Samsung PCN5425R 54" Rear Projection Television Logo
294 people viewed this question
Jerry Greenberg
Jerry Greenberg
