Sony Trinitron kv-2966 tv will not start ,no standby light,makes start up noise high pitch.
  • 76 Answers
Have you checked your curcuit bord??? Usually it means that the tube is blown out unless its a LCD Tv then I don't know that much about , sorry.
Posted on May 03, 2008
    Genius:
  • 1,447 Answers
Turn off tv and check all connections and unplug it from power supply. make sure that everything is connected tightly on the back of tv( cables and stuff) turn it back on, if you see a red flashing light or red solid light, chances are there might be a problem on the capacitor or wirings inside it.
Sony trinitron 32 inch television model no. KV-32FS13 doesnt have any video nor audio and standby light just blinks about 4 times
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check for any loose sodering points at the vertical output section.
Mar 27, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Why does my sony trinitron makes a high pitch noise when on and/or off ?
It's the flyback transformer. Check for bad connections on the flyback and on horizontal output circuit.
Nov 08, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My Sony tv will not turn on. The standby/timer light keeps flashing red.
Problem with the Sony Trinitron KV-J16PF 20" TV The standby/timer light keeps flashing red
Jun 07, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV is stuck on standby light flashes 7 times and making a clicking noise
High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Mar 11, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
The standby botton blink 7 in my sony trinitron
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
May 07, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
"High Pitch Squealing" from my tv.
this most likely a coil or transformer that is doing this
And yes this is worth fixing , shouldn't be to bad on the cost of the repair
Dec 01, 2008 | Sony Televison & Video
Sony trinitron KV-27FS100
probably, you have to call for a technician to check for it, the switch of the tv might have some dis alignment of cables
Oct 30, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony kv-30xbr910 my tv won't turn on and the standby fashes 7 times
Good day.
Your unit has issues with the high voltage section. Particularly the vertical and horizontal sections. Blinking lights indicates that your flyback is not osscilating to distribute the supply to the sections. Please have it checked by a repaiman.
chris
Mar 21, 2008 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
High pitch sound for Sony FD Trinitron WEGA KV-27HS420 27" TV
The high pitch squeal you hear is usually caused by a coil vibrating, normally in the horizontal circuit. I've also seen the ferrite bead on the horizontal output transistor do this, but, it is rare. I normally will repair this by finding the coil and "tightening" it. To tighten a coil, technicians use different chemicals, such as, a hot glue gun, rubber silicone or even finger nail polish. I will find the coil that screams by starting with the usual suspects and using a wooden dowel, barely touch the coil and if the pitch of the noise changes, then, thats the coil that needs repaired. If you do not know your way around the inside of a television, I never recommend you do so, since, this procedure must be done with the set turned on and you poke your hands around the inside of the set by the high voltage circuit. Hope this helps your decision.
Mar 04, 2007 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Televison & Video Logo
129 people viewed this question
Top Televison & Video Experts
Electro Med Services...
