My new insignia tv is zoomed in and will not zoom out. I have tried the TV mode and it changes the picture size but not the zoom. ns-46l550a11
5 Suggested Answers
SOURCE: Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
Posted on May 30, 2008
budmrtn
  • 11361 Answers
SOURCE: I just bought a 32" insignia tv ns-32l430a11 and I
You do not need to buy anything, just look at the owner manual, or look at yor remote control for the button with 'DISPLAY', 'ASPECT', 'ZOOM' for adjusting the aspect ratio.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Nov 30, 2010
  • 11 Answers
SOURCE: picture sometimes goes to zoom mode when changing satellite channels
I'm assuming that you are using Sky ,because I've come across a few similar problems lately involving Sky(a software glich I think)
Go into the Sky set up menu (the services button on the remote)Press option 4 then 1 this should get you into picture settings.Check that this is set to 16:9 as it should be for your set.
Here comes the silly part ,change the settings to 4:3 L and save the settings exit the menu and then re enter it .Now change the settings back to 16:9 and save it and exit.
This should solve your problem
Posted on Nov 04, 2007
SOURCE: Panasonic TV 50 inch plasma
I had the same problem and found that I was viewing the TV input instead of the composite input. Once I changed it back, the aspect setting would hold.
Posted on Feb 10, 2008
My panasonic dvd player will not show the whole screen when in dvd mode
Hi
First make sure your Panasonic has 16:9 TV mode selected within its menu. Then try chainging the picture size on your TV. You didn't say what model TV you have. On my Samsung you would press the menu key then select picture, scroll down and select picture size. From hear you can select 16:9, wide zoom, zoom, 4:3. Try looking for picture size and selecting 16:9 on your TV.
Jun 03, 2014 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
My wife was cleaning the front of our flat screen tv ....she must of hit one of the buttons on the front of the TV ....the picture went smaller How do i get it back to normal size?
Can't changes tv picture screen sizes,when the tv is off.She is cleaning the tv,when it is off wright?Yes.Than the tv programming u are watching stay small screen size the whole entire times even different seen or in commercials?Tv even in difference tv channels,screen sizes are small too?Sometimes tv changes screen sizes by itself to fit the tv programming it is playing to fit it prgramming format it displaying.Still have all small screen sizes all the tv channels.Tv must be on and playing.U have the tv original remote wright?Yes.Try looking on ur tv remote control look for a buttons said like Aspect Ratio,Picture Sizes,ZOOM or VIEWMODE buttons,by pushing one of these buttons on the remote should able to changes tv picture screen sizes.
Apr 13, 2011 | Insignia IS-LCDTV32 32 in. Television
I just bought a new insignia LCD TV and the picture does not cover the entire screen. Instead of the 32 inch. diagnal I should, I have a 24 inch picture. Is there something I can do about it?
The "picture size" on the TV needs to be set correctly. You should have a "ZOOM" button on your remote. Press it a few times, cycling through the options... see if this fixes the problem.
Be advised, many (most) HD channels do not show HD content all the time. At the broadcasters discretion, they may choose to ADD the black bars to either side (and/or top an bottom) of the image. This is what the "ZOOM" button is actually for... to allow you to correct this, filling the screen with the image.
*Note: many cable box have a "FORMAT" or "HD ZOOM" button. When used in conjunction with the TVs zoom feature, you can end up having one device set correctly, while the other is not. The result is often a picture that is expanded far beyond the bounds of the displayable area of the screen. If you can not find a solution using the "ZOOM" button, pick the setting which shows the most image. Now adjust the cable box setting (FORMAT / HD ZOOM).
Mar 06, 2011 | Insignia Televison & Video
My plasma has the screen distorted after my son pressed something on the remote. It is like the picture is three times the size.
Ur tv are to much zooming in mode.Look on the remote control for a button that said like VIEW MODE,ZOOMING,PICTURE SIZES.Press one of these buttons to changes ur tv picture sizes.
Feb 26, 2011 | LG 50PG20 50 in. Plasma HDTV
How do I change it from wide screen to regular? I have a black area above and below the picture.
Hello
You can set the picture size by remote control itself.
You can vide 480i format programmes in three picture sizes. 4:3, 16:9, and ZOOM
You can change the picture size by pressing the PICTURE SIZE button on the remote control.
4:3 Picutre size
To fill the screen, the top and bottom edges are extedted more widely, although the center of the picture remains near the former ratio.
If receiving a 4:3 programme, the image size is displayed in its originally formatted proportion.
16:9 picure size
This image displays the size of standard 16:9 with black bars at the top and bottom.
If receiving a 4:3 programme, the image is displayed with black bars at the top and bottom and stretched wider.
NOTE: If a fixed bar remains on the screen for a long period of time, the image can become parmanantly engrained in the screen and cause subtle but permanent ghost images. Never leave your TV for long periods of time while it is displaying these images.
Zoom picture size [for 16:9 formats]
The entire picture is uniformly enlarged --it is stretched the same amount both wider and taller (retains its original proportion). The right and left edges of the picture may be hidden.
OK.
Dec 14, 2010 | Insignia NS- 27" TV27 TV
Nov 30, 2010 | Insignia IS-LCDTV32 32 in. Television
There is about an inch on each side of my screen that is cut off and I can't see it. What do I do because I don't have the remote? I have the Insignia NS-27HDT 27". thank you.
you need to set pix format you might try using a universal remote or check menu on tv for pix format and size like full zoom etc.
Oct 10, 2010 | Insignia NS-27 TV TV
How do I change the aspect ratio
Aspect Ratio–Selects the screen aspect ratio: Normal, Wide, Zoom, or
Cinema. You can also press the ZOOM button to select the aspect ratio.
Aug 16, 2009 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
How to make the picture be on the whole screen
Just try to ZOOM IN the screen of you TV, by pressing the zoom option of the remote or going to picture options in the Tv menu. This affect the picture you get but makes it bigger!
May 10, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
May 29, 2008 | Televison & Video
Televison & Video Logo
652 people viewed this question
Top Televison & Video Experts
Electro Med Services...
