Question about Malber WD1000 Front Load Washer/Dryer
What kind of detergent do you use and how to operate?
  • 712 Answers
You can use almost any type of detergents, preferably 'Automatics' which are specially designed for washing machines. The operation logic is simple and is well explained in the user's manual.
Posted on Aug 20, 2010
  • scvjbb99 Aug 20, 2010
    we don't have a users manual new apt
  • Sebin Punnacheril
    Sebin Punnacheril Aug 20, 2010
    You don't want an user manual for selecting the detergent. When you purchase a detergent, look its cover and see if the word 'AUTOMATIC' is inscribed on it. If yes, that is the detergent you are looking for.
Error code f35
Too much detergent or wrong kind of detergent. If you use non HE detergent this will happen. You can remove the excess suds by running a cleaning cycle and adding cooking oil. The detergent will attatch itself to the oil and remove all soap residue, add an extra rinse to the cycle. Also run it empty.
Sep 02, 2014 | Maytag Washing Machines
Troy bilt pressure washer 020207 won't draw soap
Below is a list of the MOST COMMONLY reported troubleshooting issues.
you might want to try these steps:
No detergent
Reservoir is empty
Add more detergent
No detergent
Detergent suction tube not properly connected to the machine
Check connection
No detergent
Detergent is too thick Dilute detergent
No detergent
Filter on detergent suction tube is closed
Open the filter by turning it to the desired detergent intake
No detergent
Filter on detergent suction tube is clogged
Run warm water through filter to remove debris
No detergent
Damaged or clogged detergent suction tube
Remove obstruction or replace detergent suction tube
No detergent
Spray wand is in high pressure position
Turn spray wand tip to low pressure position
No detergent
Discharge nozzle is obstructed Blow out or remove debris with a fine needle
reference from:
http://troybilt.custhelp.com/app/answers/detail/a_id/10652/~/basic-troubleshooting---pressure-washers-%28gasoline-powered%29
please consult the operators manual you can get from link below:
Parts Manual Finder
or a Professional Shop Manual for model specific technical information.
If professional service is needed, please utilize the Authorized Service Center Directory to have the equipment professionally inspected and serviced.
You may also contact our Customer Technical Support department at:
Toll-Free Sales and Support (U.S.A. Only) 800.828.5500
Hours of Operation (EST)
Monday-Friday: 8:00am - 8:00pm
Saturdays: 9:00am - 8:00pm
Sundays: 10:00am-6:00pm
May 11, 2014 | Comet BXD2527 Pressure Washer Pump
I do not know what soaps i can use for a prjent
Emaily,
I am guessing you are asking what kind of detergent to use in your GE dishwasher. Well, you need to buy Dishwasher detergent. You can NOT use the kind of dish soap you use to wash dishes with in the sink. If you do, you will have a huge mess on your hands to clean up. It will make too much suds, and it will leak out of your machine. Cascade makes a nice dishwashing "pod" that you just set in the detergent tray, and close it up. I like to use the pods that have both detergent, and rinse aid in them. You can also buy dishwashing detergent in powder form that you just pour into the detergent tray.
Apr 10, 2014 | GE Dishwashers
Message "suds" appeared on my Magtag laundry machine
There is a panel at the bottom front of your machine. Remove the 3 - 4 screws at the bottom of the panel. Inside the panel you will find Service Codes and other useful info. It's a good place to keep them so my advice is to put them back when done with them. It is indicating "suds" because you are either using too much detergent, wrong kind of detergent (make sure it's high-efficiency detergent) or you need to clean the catch basket on the drain pump.
The owner's manual can be downloaded here:
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/user-manuals/manual-downloads/Model-MAH2400AWW/3048/0153200?modelNumber=MAH2400AWW&diagramPageId=&documentId=
Hope this helps.
Dec 24, 2012 | Maytag Washing Machines
My washer suddenly started saying SUD and I can't figure out why??? Can you help?
You have 2 issues here.
1. Using too much detergent and or the wrong kind of detergent.
H E detergent ONLY should be used and the amount posyed on the container.
H E detergent is very low sudsing. Cleaning ability is the same as other detergents.
2. Remove the bottom front panel to access the drain pump and clean out any debris in the pump.
Aug 10, 2010 | Maytag EPIC MFW9700S Front Load Washer
Can you use regulure detergent instead of the HD kind? The type of maytags I purchased are MEDE500VW and MHWE450WW washer
High Efficiency detergent is strongly recommended for front-load washers. This detergent is a "low sudsing" detergent as opposed to the regular detergent. If you use regular detergent is a front-load unit, you may have issues down the road!
Apr 13, 2010 | Maytag MEDE500W Dryer
Dishwasher detergent clumps in pre-wash and main wash compartments
Make certain that there are no apparent obstructions between water and detergent. If no obstructions and the detergent dispenser and spray arms are operable, then the detergent should dissolve during wash. Otherwise, try using a different kind and amount of detergent (e.g.: powder vs. gel or gel vs. powder, and less detergent). If still clumping, contact an appliance service company.
Feb 20, 2010 | Maytag Dishwashers
Oil for yardman lawn mower
Only 30wt DETERGENT HIGH QUALITY oil, never use NON detergent or 10-40. Takes approx. 20 ounces to fill
May 27, 2009 | Mtd LAWN MOWER PART # 782-0082A-0638 DECK...
Detergent
Yes! any kind of liquid soap is ok for your front loader. HE soaps are just a little better in the front loaders so yes you can still use your liquid soap.
Feb 20, 2009 | Frigidaire ATF6000ES Front Load Washer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
83 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Dan Webster
Dan Webster
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
