Question about Philips Audio Players & Recorders
MY CD PLAYER AK701 HAS A PROBLEM : WHEN IT STAR TO PLAY IT SHOW AN ERROR LIKE "EE" and it stop
SOURCE: Cd player
M-Error is a mechanical error and could have a multitude of causes. just went through it with a TAD-5160 unit where it was a small slip gear moving a tin lever to ingage the transport sled to insert or eject the disk from and to the carusel. You may have to take the unit apart and asess the problem. Harleysp.
Posted on Jun 06, 2007
SOURCE: Error nd after entering cd and pressing play
1. Press Open/Close to open the drawer and insert CD
2. Press Play/Pause and wait over 30 seconds or more for the CD to start playing.
3. Use only original CD, not copies.
Posted on Oct 15, 2008
  • 11 Answers
SOURCE: CD player wont play disks, showing error 1 instead
The original user manual will define the headunits error readings. It is most likely an internal mechanical failure and will need to be repaired or replaced
Posted on May 21, 2009
SOURCE: CD player Error 3
dear,
I have different experiance with the C.Dplayer ( error 3 ) , there is no need to remove it nor send it to the dealer ,all you have to do when you have `` Error 3 `` is to reset the C.D player , by recycling the power supply ,this can be done by disconnecting the main car battery power supply , you must also keep the battery disconnected for at least one hour . then connect the cables to the batteries ,when you start the C.D player you will hear some clicking sound ,and watch the numbers of the C.D`s in the display you will find all what is inside has been detected by the display .
and your C.D player is back to normal..
i discovered ths by chance , when I had this error in the past ,coincidently I had to replace the battery and after installing the new batteries ,i was suprised to see the player back to normal condition by its self.
Posted on Jun 19, 2009
SOURCE: 2002 gmc envoy bose 6cd player does not play, shows player error
how to remove a bose cd/radio from dash of a GMC envoy slt cd's are stuck inside
Posted on Dec 18, 2009
I have a 6 cd changer in my 2005 chysler Pacifica that stopped playing. Shows error message no cd.
My experience with CD/DVD players has been, unfortunately, that when the trays stop opening and/or closing, or when error messages start regularly, it's history. Hope yours turns out differently, but I wouldn't count on it. It will cost you as much or more to fix it than to replace it. if you live near a large junkyard you might try to retrieve one there, but the fact that your car is 13 yrs. old will make that tougher.
Jan 17, 2018 | The Audio Players & Recorders
Cd player shows EE sign when starting to play a cd
Please post on the correct forum, This is the Radio communications forum.
Thnx
Feb 26, 2013 | Radio Communications
My cdp-455x is showing a loading error after the lazer being cleaned
The laser eimission might have stopped. The laser pickup unit [optical pickup unit] should be replaced.
Apr 17, 2012 | Sony CDP-D11 1U professional compact disc...
Spin both directions theb display show table error
Usually CD rotates in the clockwise direction. Whenever you are using CD which your CD player cannot detect then CD is rejected and suddenly CD rotates in anticlockwise direction.
Also, If your player is older and your CD players laser head worn out then CD's which were played good previously cannot be played properly and then stop in middle, when this happens you can see CD rotating in anti direction.
Clean the laser head, with CD cleaner and do not use scratched CD's
Aug 26, 2010 | Sony CDP-CX300 CD Player
Player shows error 4 after succesfully playing new CD. will not eject either.
I had an error 4 on my as well, basically the cd would stop playing and the only way to clear the error was to turn off the car and turn it back on! I ended replacing the audio unit.
Dec 13, 2009 | 2005 Lexus RX330
My kenwood dp-r99 reads ee
I just took my DP-R99 out of the closet and powered it up in my garage. After a short delay it reads EE. I took it apart and the belt that drives the laser head up to the CD and pressure disk to make it spin is slipping and never raising the head enough. It looks like the belt has stretched over the years. I am now going to look for a replacement belt and the belt that rotates the carriage since it is also stretched. I will let you know for sure when I install new belts. Hope this helps...
Jun 06, 2009 | Kenwood CD-206 5-Disc CD Changer
Apr 17, 2009 | 2002 GMC Envoy
Cd player showing error 43
Still under warranty?... check that.
Mar 24, 2009 | 2008 Hyundai Elantra
Emerson PD6810 CD Boombox Error
My older model PD6810 had the spindle that holds the CD on the player missing causing the ER message to show and the player to stop working.
Aug 21, 2007 | Emerson PD6810 CD Boombox
Random stopping while playing CD > error message
yes yes yes clean it if that dont work i would just say "sorry" go with a diffrent brand player. cuz my dad has had 3 or 4 of them and i had 2 of them and they never lasted of held up. they have all fried to easy. i dont trust sony car equipment.
Aug 18, 2007 | Sony CDX-F5510 CD Player
37 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
