Question about HP LaserJet 6mp Printer
I have a HP 6MP printer and it is now constantly jamming the paper and making harsh roller noises?
    Problem Solver:
  • 17 Answers
Can't be positive without hearing and seeing myself but the main motor makes a terrible sound whrn the gear on it cracks or it locks up. The jamming could also be because a piece of paper is jammed under the paper guide directly underneath the toner cartridge. If you look down in the machine you will see one silver screw on the left side, that is all you need to remove to take out the guide.
Posted on Aug 20, 2010
Hp Lazerjet 4L constant paper jams
These machines can be problematic. They are old. Pick up rollers is the common issue. Remove the tray and look up into the machine and you will see the rollers. If they have a slick place on them, replacing them will probably solve your problem. Also make sure the paper path is clean from any paper dusk and or small bits of paper. Doesn't take much to cause a jam.
Mar 10, 2013 | Dell 924 All-in-One InkJet Printer
Tip
How to troubleshoot paper jam problem in printers?
Most common reason are as follows:-- Among the most common problems with any make of printer are paper jams. A printer will jam for any number of reasons: It’s dirty, the wrong paper type is being used, or the rollers on the printer that feed the paper through its pathway are worn down. While cleaning the printer periodically and using the correct paper type are easy fixes, roller replacement can be a difficult job depending on the model of HP printer. For some HP printers, the rollers are easily accessible, but you'll need to completely tear down other models to remove the rollers. Regardless of the cause, when removing a paper jam, always pull the paper in the direction of the paper path, because pulling it backwards can severely damage the printer.
Certain HP printers are more susceptible to paper jams than others. In my experience, any printer that holds the paper vertically and then pulls it down through the printer invariably ends up having paper jam problems. These models aren't designed for heavy use, but many organizations make use of them on individual systems and should be aware of this flaw. In addition, some people have trouble with the newer HP 4000 series printers' paper pickup rollers—which is odd, because the older 4000 and 5000 series HP printers are considered rock solid and don't seem to have any trouble with their pickup rollers.
This will help.good luck.
on Mar 05, 2010 | Office Equipment & Supplies
HP LJ 2420 wont pickup paper from tray 2
Replace try2 paper pick up roller..
Dec 01, 2011 | HP LaserJet 2420 Printer
I have an hp p3005 with the jam code 13.01.00. It has had the feed rollers and sep pads replaced. When it runs it appears to catch on the separation pad itself since it shows a small buckle in the middle...
Replaced seperation pad?. separation pad work is to block multiple paper feeding,but in yourcase paper not at all feeding means paper pickup roller not picking up the papers.replace both 2 & 3 paper pickup rollers..
See the snap shot,view from under.
Pickup roller( red)
Un lock to remove pick up roller(blue),observe the angle of the roller & same way insert new one other wise it wont fix..
Bee care full while removing roller, paper sensor flag should not distubed(yellow)
bee pateince dont do harsh..best of luck.
Oct 11, 2011 | HP LaserJet P3005 Printer
Have an HP LJM9050 MFP printer. Getting almost constant jam in transfer roller and any successful prints have a crease. We were told by a tech that the issue is the paper we are using. We use Staples...
It is better to try with good brand printing paper as the lower thickness of the paper will only make the paper crinkle within the roller as it will BITE into the roller and be pulled into with different tension.
So test with another brand to confirm. If not the roller alignment must be checked.
Sep 03, 2011 | HP Office Equipment & Supplies
Problem with Deskjet 895cxi
You may open the rear door to check for any paper jam in side
or if it still gives error rotate the roller in upward direction till you get one locking sound, restart printer and check printing
if you still find grinding noise from printer, its pickup roller gear may be worn-out generally and need to be replaced
contact service person for further repair
Nov 08, 2009 | HP DeskJet 895cxi InkJet Printer
All of the sudden, constant paper jams & no paper signal when ful
You can clean them from the rear access/jam cover. Just be careful when turning the rollers, must be slow and smooth movement.
Aug 04, 2009 | HP PSC 1610 All-In-One InkJet Printer
Hp laserjet 1320 paper jams constantly. not even one page prints. what could be the problem?
could actually be the paper your using. make sure your using at the very least multipurpose paper or laser paper. check to make sure your settings for paper is also set to regular paper and not cardstock or special paper or anything else
Jul 30, 2009 | HP LaserJet 1320 Printer
HP G85 PAPER JAM ERROR ,but still prints from scanner fine
Remove the rear cover...clean the rubber rollers with alcohol
Feb 17, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
Open Questions:
See all HP LaserJet 6mp Printer Questions
HP LaserJet 6mp Printer Logo
60 people viewed this question
Seeker5211
Seeker5211
